查看: 708|回复: 6
[供应] USB CONNECTOR 选型推荐表
24
90
609
发表于 2018-4-11 20:33:56 | 显示全部楼层 |阅读模式
USB CONNECTOR 选型推荐表 供大家参考。
USB2.0, USB3.0, USB3.1 Type A/B/C 连接器选型推荐表
USB2.0 CONNECTOR
NO.
PART NO.
SPEC.
Current Rating
Data transmission standard
SMT/DIP
Drawingsfile:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1056.png
Remark
C-ST-001-1-04
USB CON, SERIES A, SINGLE DECK.
VERTICAL ANGLE THROUGH HOLE TYPE
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1075.png
E-U2A194-01
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1067.png
E-U2A167-02
USB 2.0 CONN, SERIES A, SINGLE DECK. RIGHT ANGLE THROUGH HOLE TYPE
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1066.png
E-U2A276-02
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1073.png
E-U2A272-04
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1071.png
E-U2A275-04
USB 2.0 CONN, SERIES A, SINGLE DECK. RIGHT ANGLE THROUGH HOLE TYPE(L=11.71)
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1072.png
E-U2A001-05
USB 2.0 CONNECTOR, SERIES A,SINGLE DECK,RIGHT ANGLE THROUGH HOLE TYPE
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1061.png
E-U2A208-0A
USB CONN, SERIES A, SINGLE DECK.
      VERTICAL ANGLE THROUGH TYPE FOR PCB ONLY
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1064.png
E-U2A263-0D
USB 2.0 CONN, SERIES A, SINGLE DECK. VERTICAL SOLDER PCB TYPE
1.5A @ 250VAC
USB2.0
SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1063.png
E-U2A251-0E
USB 2.0 CONN., SERIES A, SINGLE DECK. VERTICAL ANGLE SOLDER PCB TYPE
1.5A @ 250VAC
USB2.0
SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1068.png
E-U2A265-0E
USB CONNECTOR, SERIES A,SINGLE DECK VERTICAL ANGLE THROUGH TYPE FOR PCB ONLY
1.5A @ 250VAC
USB2.0
SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1070.png
E-U2A278-0G
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1062.png
13
E-U2A162-0M
USB TYPE A UPRIGHT (OR VERTICAL),  FLANGE-OUT, R/A, TH TYPE, ROHS
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1065.png
14
E-U2A259-0M
USB 2.0 CONN, SERIES A, SINGLE DECK. RIGHT ANGLE THROUGH HOLE TYPE(L=11.00)
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1069.png
15
C-ST-001-P-06
USB CONN, SERIES A, FEMALE SINGLE DECK. RIGHT ANGLE THROUGH HOLE TYPE L=10.3
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1074.png
16
E-U2A172-0P
USB 2.0 CONN, SERIES A, DOUBLE DECK. RIGHT ANGLE SMT TYPE(L=10.3)
1.5A @ 250VAC
USB2.0
SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1060.png
17
E-U2A142-0X
USB 2.0 CONN, SERIES A, SINGLE DECK. VERTICAL ANGLE THROUGH HOLE TYPE
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1059.png
C-U2B005-00
USB CONNECTOR, SERIES B, 4 POSITIONS, R/A, THUR-HOLE TYPE
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1057.png
19
E-U2C140-01
1.5A @ 250VAC
USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1058.png
USB3.0 CONNECTOR
C-U3C003-00
USB3.0 DOUBLE 90° A TYPE FEMALE
1.5A @ 250VAC
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1026.png
C-U3C005-00
1.5A @ 250VAC
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1027.png
C-U3A096-00
USB3.0 180°  A TYPE FEMALE
1.8A FOR PIN1&PIN4,0.25A FOR OTHER PIN
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1029.png
C-U3A069-00
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1030.png
C-U3A049-00
USB3.0 UPRIGHT ANGLE THROUGH HOLE TYPE
1.5A @ 250VAC
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1031.png
C-U3B001-00
USB3.0  B TYPE FEMALE
1.5A @ 250VAC
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1032.png
C-U3A023-00
USB3.0 A TYPE RIGHT ANGLE
1.8A @ 250VAC
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1033.png
C-U3A052-00
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1040.png
C-U3A041-00
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1037.png
C-U3A028-00
USB3.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1039.png
Large current USB Connector
C-U3A109-00
USB 3.0 RECEPTACLE, SERIES A, 9      POSITIONS R/A DIP TYPE
5A @ 250VAC
USB3.0 TYPE A
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1041.png
C-U3A158-0S
USB 3.0 CONNECTOR, SINGEL DECK RIGHT ANGLE (12.70) DIP TYPE 5PIN
8A @ 250VAC
USB PD TYPE A
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1042.png
C-UTC003-01
USB FULL-FEATURED TYPE C RECEPTACLE,RIGHT ANGLE DIP AND SMT TYPE
5A @ 100VAC
USB3.1 TYPE C
DIP+SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1043.png
C-UTC038-01
5A @ 100VAC
USB3.1 TYPE C
DIP+SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1044.pngfile:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1077.png
C-UTC0037-05
USB 3.0 TYPE C RECEPTACLE,
5A @ 100VAC
USB 3.0 TYPE C
DIP
C-UTC027-02
USB 2.0 TYPE C RECEPTACLE,
5A @ 100VAC
USB 2.0 TYPE C
SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1045.png
C-UTC016-02
5A @ 100VAC
USB 2.0 TYPE C
SMT
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1076.png
Multi-function Type C Connector.
C-U3C012-OF
USB3.0 DOUBLE 90°TYPE C TO A FEMALE
1.5A @ 250VAC
USB3.0,USB3.1 GEN1
DIP
C-U3C010-OF
1.5A @ 250VAC
USB3.0,USB3.1 GEN1
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1048.pngfile:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1049.png
C-U3C011-OF
1.5A @ 250VAC
USB3.0,USB3.1 GEN1
DIP
C-U3A134-OF
USB3.0 单层 90°TYPE C TO A FEMALE
1.5A @ 250VAC
USB3.0,USB3.1 GEN1
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1047.png
C-U3C015-OF
USB3.0 DOUBLE 90°TYPE C TO A FEMALE 33P
1.5A @ 250VAC
USB3.0,USB3.1 GEN1
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1051.png
C-U3C014-0F
USB3.0 双层90度(L=17.50) TYPE C TO A 上C2.0下A
1.5A @ 250VAC
USB3.0,USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1052.png
C-U3C017-0F
USB3.0 双层90度(L=17.50) TYPE C TO A 上C下C2.0
1.5A @ 250VAC
USB3.0,USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1053.png
C-U3C018-0F
USB3.0 双层90度(L=17.50) TYPE C TO A 上A下C2.0
1.5A @ 250VAC
USB3.0,USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1054.png
C-U3C019-0F
USB3.0 双层90度(L=17.50) TYPE C TO A 上A下C只带充电功能
1.5A @ 250VAC
USB3.0,USB2.0
DIP
file:///C:/Users/xiepeng/AppData/Local/Temp/ksohtml/clip_image1055.png
如需PDF图纸文档,敬请联络我们。
QQ:523212653
Mail:xie@chb-hk.comdavid@chb-hk.compelexie@palconn.net
128
1468
1737
3260
管理团队白尾巴玩家ANKER粉丝团CHOETECH烧友团QC2.0快充达人
发表于 2018-4-12 13:40:10 | 显示全部楼层
看不懂
[url=]点击此处第一时间获取最新优惠信息 惆怅带你薅羊毛[/url]
111
14
129
发表于 2018-4-20 17:37:03 | 显示全部楼层
應該直接發PDF上來的
23
14
发表于 2018-12-12 15:06:31 | 显示全部楼层
上海上市企业长园旗下上海长园维安微电子有限公司 旗下CYG WAYON长园维安原厂授权正规代理商(深圳市光与电子有限公司)只寻OEM ODM配合!
现在很多国内企业的产品局限于国外的供货长,以及价格贵等因素,而影响国内电子企业发展受制于人,维安拥有一支强大的研发团队,国产品牌质量保证性价比高,交货好等优势,提供原厂技术支持和研发测试,在深圳办事处有实验室,欢迎OEM ODM去设计,希望多支持民族事业,才是国家发展的长久之路!上海长园维安一级代理商有维安原厂直发的授权代理证书,致力配合ODM OEM,我们代理的不是产品,而是爱国情怀,希望祖国多支持国产实业。代理长园集团[600525]旗下上海长园维安电子线路保护有限公司也是李嘉诚入股,我相信在强大的上市企业支持下,我们的事业会越做越强,一定会成为国产半导体行业的骄傲,深圳光与电子有限公司代理长园集团[600525]旗下上海长园维安电子线路保护有限公司深圳市长园维安电子有限公司上海长园维安微电子有限公司
上海长园维安电子线路保护有限公司,CYG Wayon Circuit Protection Co., Ltd.由上海材料研究所创建于1996年,2007年上海证券交易所上市公司长园集团为控股股东。
维安大陆代理商 TEL:075582574660 邮箱:Joshua@szkoyu.com
WMK115N10T1        N-Channel Trench MOSFET        TO-220        100        4.5        115        273        90        20        3
WMM115N10T1        N-Channel Trench MOSFET        TO-263        100        4.5        115        273        90        20        3
WMK115N08T1        N-Channel Trench MOSFET        TO-220        85        4.5        115        250        71        20        3
WMM115N08T1        N-Channel Trench MOSFET        TO-263        85        4.5        115        250        71        20        3
WMS11N06T1        N-Channel Trench MOSFET        SOP-8        60        15        11        3.5        52.5        20        2
WMK08N70DM        N-Channel Enhanced VDMOSFET        TO-220        700        1.2        8        140        26.11        30        3
WML08N70DM        N-Channel Enhanced VDMOSFET        TO-220F        700        1.2        8        52        26.11        30        3
WMM08N70DM        N-Channel Enhanced VDMOSFET        TO-263        700        1.2        8        140        26.11        30        3
WMN08N70DM        N-Channel Enhanced VDMOSFET        TO-262        700        1.2        8        140        26.11        30        3
WML06N70DM        N-Channel Enhanced VDMOSFET        TO-220F        700        1.7        6        45        21.8        30        3
WMM06N70DM        N-Channel Enhanced VDMOSFET        TO-263        700        1.7        6        130        21.8        30        3
WMN06N70DM        N-Channel Enhanced VDMOSFET        TO-262        700        1.7        6        130        21.8        30        3
WMO06N70DM        N-Channel Enhanced VDMOSFET        TO-252        700        1.7        6        128        21.8        30        3
W06N70DM        N-Channel Enhanced VDMOSFET        TO-251        700        1.7        6        128        21.8        30        3
WMG06N70DM        N-Channel Enhanced VDMOSFET        TO-251S3        700        1.7        6        128        21.8        30        3
WMH06N70DM        N-Channel Enhanced VDMOSFET        TO-251S2        700        1.7        6        128        21.8        30        3
WML04N70DM        N-Channel Enhanced VDMOSFET        TO-220F        700        2.7        4        33        10.34        30        3
WMO04N70DM        N-Channel Enhanced VDMOSFET        TO-252        700        2.7        4        77        10.34        30        3
W04N70DM        N-Channel Enhanced VDMOSFET        TO-251        700        2.7        4        77        10.34        30        3
WMG04N70DM        N-Channel Enhanced VDMOSFET        TO-251S3        700        2.7        4        77        10.34        30        3
WMH04N70DM        N-Channel Enhanced VDMOSFET        TO-251S2        700        2.7        4        77        10.34        30        3
WMK10N65DM        N-Channel Enhanced VDMOSFET        TO-220        650        1        10        150        28.5        30        3
WML10N65DM        N-Channel Enhanced VDMOSFET        TO-220F        650        1        10        50        28.5        30        3
WMM10N65DM        N-Channel Enhanced VDMOSFET        TO-263        650        1        10        150        28.5        30        3
WMN10N65DM        N-Channel Enhanced VDMOSFET        TO-262        650        1        10        150        28.5        30        3
WML07N65DM        N-Channel Enhanced VDMOSFET        TO-220F        650        1.4        7        46        21.2        30        3
WMM07N65DM        N-Channel Enhanced VDMOSFET        TO-263        650        1.4        7        120        21.2        30        3
WMN07N65DM        N-Channel Enhanced VDMOSFET        TO-262        650        1.4        7        120        21.2        30        3
WMO07N65DM        N-Channel Enhanced VDMOSFET        TO-252        650        1.4        7        89        21.2        30        3
W07N65DM        N-Channel Enhanced VDMOSFET        TO-251        650        1.4        7        89        21.2        30        3
WMG07N65DM        N-Channel Enhanced VDMOSFET        TO-251S3        650        1.4        7        89        21.2        30        3
WMH07N65DM        N-Channel Enhanced VDMOSFET        TO-251S2        650        1.4        7        89        21.2        30        3
WML04N65DM        N-Channel Enhanced VDMOSFET        TO-220F        650        2.7        4        30        12.5        30        3
WMN04N65DM        N-Channel Enhanced VDMOSFET        TO-262        650        2.7        4        90        12.5        30        3
WMO04N65DM        N-Channel Enhanced VDMOSFET        TO-252        650        2.7        4        77        12.5        30        3
W04N65DM        N-Channel Enhanced VDMOSFET        TO-251        650        2.7        4        77        12.5        30        3
WMG04N65DM        N-Channel Enhanced VDMOSFET        TO-251S3        650        2.7        4        77        12.5        30        3
WMH04N65DM        N-Channel Enhanced VDMOSFET        TO-251S2        650        2.7        4        77        12.5        30        3
WMK10N60DM        N-Channel Enhanced VDMOSFET        TO-220        600        0.9        10        156        28.3        30        3
WML10N60DM        N-Channel Enhanced VDMOSFET        TO-220F        600        0.9        10        50        28.3        30        3
WMM10N60DM        N-Channel Enhanced VDMOSFET        TO-263        600        0.9        10        156        28.3        30        3
WMN10N60DM        N-Channel Enhanced VDMOSFET        TO-262        600        0.9        10        156        28.3        30        3
WML07N60DM        N-Channel Enhanced VDMOSFET        TO-220F        600        1.2        7        45        21.1        30        3
WMM07N60DM        N-Channel Enhanced VDMOSFET        TO-263        600        1.2        7        122        21.1        30        3
WMN07N60DM        N-Channel Enhanced VDMOSFET        TO-262        600        1.2        7        122        21.1        30        3
WMO07N60DM        N-Channel Enhanced VDMOSFET        TO-252        600        1.2        7        90        21.1        30        3
W07N60DM        N-Channel Enhanced VDMOSFET        TO-251        600        1.2        7        90        21.1        30        3
WMG07N60DM        N-Channel Enhanced VDMOSFET        TO-251S3        600        1.2        7        90        21.1        30        3
WMH07N60DM        N-Channel Enhanced VDMOSFET        TO-251S2        600        1.2        7        90        21.1        30        3
WML04N60DM        N-Channel Enhanced VDMOSFET        TO-220F        600        2.4        4        33        12.5        30        3
WMN04N60DM        N-Channel Enhanced VDMOSFET        TO-262        600        2.4        4        95        12.5        30        3
WMO04N60DM        N-Channel Enhanced VDMOSFET        TO-252        600        2.4        4        77        12.5        30        3
W04N60DM        N-Channel Enhanced VDMOSFET        TO-251        600        2.4        4        77        12.5        30        3
WMG04N60DM        N-Channel Enhanced VDMOSFET        TO-251S3        600        2.4        4        77        12.5        30        3
WMH04N60DM        N-Channel Enhanced VDMOSFET        TO-251S2        600        2.4        4        77        12.5        30        3
WMR01N60DM        N-Channel Enhanced VDMOSFET        SOT-223        600        10        0.4        3.3        4.4        30        3
WMJ80N60C2        N-Channel SJ-MOS C2        TO-247        600        0.04        80        480        260        30        3
WMJ53N60C2        N-Channel SJ-MOS C2        TO-247        600        0.07        53        378        88.5        30        3
WML53N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.07        53        34        88.5        30        3
WMJ38N60C2        N-Channel SJ-MOS C2        TO-247        600        0.099        38        277        60        30        3
WMK38N60C2        N-Channel SJ-MOS C2        TO-220        600        0.099        38        277        60        30        3
WML38N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.099        38        34        60        30        3
WMM38N60C2        N-Channel SJ-MOS C2        TO-263        600        0.099        38        277        60        30        3
WMN38N60C2        N-Channel SJ-MOS C2        TO-262        600        0.099        38        277        60        30        3
WMJ26N60C2        N-Channel SJ-MOS C2        TO-247        600        0.19        20        147        34.5        30        3.3
WMK26N60C2        N-Channel SJ-MOS C2        TO-220        600        0.19        20        147        34.5        30        3.3
WML26N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.19        20        34        34.5        30        3.3
WMM26N60C2        N-Channel SJ-MOS C2        TO-263        600        0.19        20        147        34.5        30        3.3
WMN26N60C2        N-Channel SJ-MOS C2        TO-262        600        0.19        20        147        34.5        30        3.3
WMK20N60C2        N-Channel SJ-MOS C2        TO-220        600        0.3        15        86        20.3        30        3.3
WML20N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.3        15        31        20.3        30        3.3
WMM20N60C2        N-Channel SJ-MOS C2        TO-263        600        0.3        15        86        20.3        30        3.3
WMN20N60C2        N-Channel SJ-MOS C2        TO-262        600        0.3        15        86        20.3        30        3.3
WMO20N60C2        N-Channel SJ-MOS C2        TO-252        600        0.3        15        86        20.3        30        3.3
W20N60C2        N-Channel SJ-MOS C2        TO-251        600        0.3        15        86        20.3        30        3.3
WMK16N60C2        N-Channel SJ-MOS C2        TO-220        600        0.32        13        86        19.9        30        3.3
WML16N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.32        13        31        19.9        30        3.3
WMM16N60C2        N-Channel SJ-MOS C2        TO-263        600        0.32        13        86        19.9        30        3.3
WMN16N60C2        N-Channel SJ-MOS C2        TO-262        600        0.32        13        86        19.9        30        3.3
WMO16N60C2        N-Channel SJ-MOS C2        TO-252        600        0.32        13        86        19.9        30        3.3
W16N60C2        N-Channel SJ-MOS C2        TO-251        600        0.32        13        86        19.9        30        3.3
WMK14N60C2        N-Channel SJ-MOS C2        TO-220        600        0.405        11        85        18.7        30        3.3
WML14N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.405        11        31        18.7        30        3.3
WMM14N60C2        N-Channel SJ-MOS C2        TO-263        600        0.405        11        85        18.7        30        3.3
WMN14N60C2        N-Channel SJ-MOS C2        TO-262        600        0.405        11        85        18.7        30        3.3
WMO14N60C2        N-Channel SJ-MOS C2        TO-252        600        0.405        11        85        18.7        30        3.3
W14N60C2        N-Channel SJ-MOS C2        TO-251        600        0.405        11        85        18.7        30        3.3
WMK11N60C2        N-Channel SJ-MOS C2        TO-220        600        0.54        9        63        13.7        30        3.3
WML11N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.54        9        28        13.7        30        3.3
WMM11N60C2        N-Channel SJ-MOS C2        TO-263        600        0.54        9        63        13.7        30        3.3
WMN11N60C2        N-Channel SJ-MOS C2        TO-262        600        0.54        9        63        13.7        30        3.3
WMO11N60C2        N-Channel SJ-MOS C2        TO-252        600        0.54        9        63        13.7        30        3.3
W11N60C2        N-Channel SJ-MOS C2        TO-251        600        0.54        9        63        13.7        30        3.3
WMK10N60C2        N-Channel SJ-MOS C2        TO-220        600        0.69        8        57        13.6        30        3.3
WML10N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.69        8        27        13.6        30        3.3
WMM10N60C2        N-Channel SJ-MOS C2        TO-263        600        0.69        8        57        13.6        30        3.3
WMN10N60C2        N-Channel SJ-MOS C2        TO-262        600        0.69        8        57        13.6        30        3.3
WMO10N60C2        N-Channel SJ-MOS C2        TO-252        600        0.69        8        57        13.6        30        3.3
WMN09N60C2        N-Channel SJ-MOS C2        TO-262        600        0.94        6        45        6.8        30        3.3
WMF09N60C2        N-Channel SJ-MOS C2        SOT-223-2L        600        0.98        6        6        6.8        30        3.3
WML07N60C2        N-Channel SJ-MOS C2        TO-220F        600        1.14        5        23        5.8        30        3.3
WMM07N60C2        N-Channel SJ-MOS C2        TO-263        600        1.14        5        42        5.8        30        3.3
WMO07N60C2        N-Channel SJ-MOS C2        TO-252        600        1.14        5        42        5.8        30        3.3
W07N60C2        N-Channel SJ-MOS C2        TO-251        600        1.14        5        42        5.8        30        3.3
WMG07N60C2        N-Channel SJ-MOS C2        TO-251S3        600        1.14        5        42        5.8        30        3.3
WMH07N60C2        N-Channel SJ-MOS C2        TO-251S2        600        1.14        5        42        5.8        30        3.3
WMK07N60C2        N-Channel SJ-MOS C2        TO-220        600        1.14        5        42        5.8        30        3.3
WMN07N60C2        N-Channel SJ-MOS C2        TO-262        600        1.14        5        42        5.8        30        3.3
WMF07N60C2        N-Channel SJ-MOS C2        SOT-223-2L        600        1.2        5        5        5.8        30        3.3
WMO04N60C2        N-Channel SJ-MOS C2        TO-252        600        1.9        3        29        6.7        30        3.3
W04N60C2        N-Channel SJ-MOS C2        TO-251        600        1.9        3        29        6.7        30        3.3
WMG04N60C2        N-Channel SJ-MOS C2        TO-251S3        600        1.9        3        29        6.7        30        3.3
WMH04N60C2        N-Channel SJ-MOS C2        TO-251S2        600        1.9        3        29        6.7        30        3.3
WMK04N60C2        N-Channel SJ-MOS C2        TO-220        600        1.9        3        29        6.7        30        3.3
WMN04N60C2        N-Channel SJ-MOS C2        TO-262        600        1.9        3        29        6.7        30        3.3
WMM04N60C2        N-Channel SJ-MOS C2        TO-263        600        1.9        3        29        6.7        30        3.3
WML04N60C2        N-Channel SJ-MOS C2        TO-220F        600        1.9        3        20        6.7        30        3.3
WMF04N60C2        N-Channel SJ-MOS C2        SOT-223-2L        600        2        3        4.6        6.7        30        3.3
WMK15N60VD        N-Channel SJ-MOS VD        TO-220        600        0.53        10.5        63        13.7        30        3.3
WML15N60VD        N-Channel SJ-MOS VD        TO-220F        600        0.53        10.5        28        13.7        30        3.3
WMM15N60VD        N-Channel SJ-MOS VD        TO-263        600        0.53        10.5        63        13.7        30        3.3
WMN15N60VD        N-Channel SJ-MOS VD        TO-262        600        0.53        10.5        63        13.7        30        3.3
WMO15N60VD        N-Channel SJ-MOS VD        TO-252        600        0.53        10.5        63        13.7        30        3.3
W15N60VD        N-Channel SJ-MOS VD        TO-251        600        0.53        10.5        63        13.7        30        3.3
WMK12N60VD        N-Channel SJ-MOS VD        TO-220        600        0.69        10        57        13.6        30        3.3
WML12N60VD        N-Channel SJ-MOS VD        TO-220F        600        0.69        10        27        13.6        30        3.3
WMM12N60VD        N-Channel SJ-MOS VD        TO-263        600        0.69        10        57        13.6        30        3.3
WMN12N60VD        N-Channel SJ-MOS VD        TO-262        600        0.69        10        57        13.6        30        3.3
WMO12N60VD        N-Channel SJ-MOS VD        TO-252        600        0.69        10        57        13.6        30        3.3
W12N60VD        N-Channel SJ-MOS VD        TO-251        600        0.69        10        57        13.6        30        3.3
WML10N60VD        N-Channel SJ-MOS VD        TO-220F        600        0.92        8        26        6.8        30        3.3
WMM10N60VD        N-Channel SJ-MOS VD        TO-263        600        0.92        8        45        6.8        30        3.3
WMO10N60VD        N-Channel SJ-MOS VD        TO-252        600        0.92        8        45        6.8        30        3.3
W10N60VD        N-Channel SJ-MOS VD        TO-251        600        0.92        8        45        6.8        30        3.3
WMG10N60VD        N-Channel SJ-MOS VD        TO-251S3        600        0.92        8        45        6.8        30        3.3
WMH10N60VD        N-Channel SJ-MOS VD        TO-251S2        600        0.92        8        45        6.8        30        3.3
WMK10N60VD        N-Channel SJ-MOS VD        TO-220        600        0.92        8        45        6.8        30        3.3
WMN10N60VD        N-Channel SJ-MOS VD        TO-262        600        0.92        8        45        6.8        30        3.3
WML09N60VD        N-Channel SJ-MOS VD        TO-220F        600        1.13        6.5        23        5.8        30        3.3
WMM09N60VD        N-Channel SJ-MOS VD        TO-263        600        1.13        6.5        42        5.8        30        3.3
WMO09N60VD        N-Channel SJ-MOS VD        TO-252        600        1.13        6.5        42        5.8        30        3.3
W09N60VD        N-Channel SJ-MOS VD        TO-251        600        1.13        6.5        42        5.8        30        3.3
WMG09N60VD        N-Channel SJ-MOS VD        TO-251S3        600        1.13        6.5        42        5.8        30        3.3
WMH09N60VD        N-Channel SJ-MOS VD        TO-251S2        600        1.13        6.5        42        5.8        30        3.3
WMK09N60VD        N-Channel SJ-MOS VD        TO-220        600        1.13        6.5        42        5.8        30        3.3
WMN09N60VD        N-Channel SJ-MOS VD        TO-262        600        1.13        6.5        42        5.8        30        3.3
WMO05N60VD        N-Channel SJ-MOS VD        TO-252        600        1.89        4        29        6.7        30        3.3
W05N60VD        N-Channel SJ-MOS VD        TO-251        600        1.89        4        29        6.7        30        3.3
WMG05N60VD        N-Channel SJ-MOS VD        TO-251S3        600        1.89        4        29        6.7        30        3.3
WMH05N60VD        N-Channel SJ-MOS VD        TO-251S2        600        1.89        4        29        6.7        30        3.3
WML05N60VD        N-Channel SJ-MOS VD        TO-220F        600        1.89        4        20        6.7        30        3.3
W10N60C2        N-Channel SJ-MOS C2        TO-251        600        0.69        8        57        13.6        30        3.3
WML09N60C2        N-Channel SJ-MOS C2        TO-220F        600        0.94        6        26        6.8        30        3.3
WMM09N60C2        N-Channel SJ-MOS C2        TO-263        600        0.94        6        45        6.8        30        3.3
WMO09N60C2        N-Channel SJ-MOS C2        TO-252        600        0.94        6        45        6.8        30        3.3
W09N60C2        N-Channel SJ-MOS C2        TO-251        600        0.94        6        45        6.8        30        3.3
WMG09N60C2        N-Channel SJ-MOS C2        TO-251S3        600        0.94        6        45        6.8        30        3.3
WMH09N60C2        N-Channel SJ-MOS C2        TO-251S2        600        0.94        6        45        6.8        30        3.3
WMK09N60C2        N-Channel SJ-MOS C2        TO-220        600        0.94        6        45        6.8        30        3.3
WMF10N60C2        N-Channel SJ-MOS C2        SOT-223-2L        600        0.72        8        57        13.6        30        3.3
WMJ80N65C2        N-Channel SJ-MOS C2        TO-247        650        0.04        80        480        260        30        3
WMJ53N65C2        N-Channel SJ-MOS C2        TO-247        650        0.07        53        378        88.5        30        3
WML53N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.07        53        34        88.5        30        3
WMJ38N65C2        N-Channel SJ-MOS C2        TO-247        650        0.099        38        277        60        30        3
WMK38N65C2        N-Channel SJ-MOS C2        TO-220        650        0.099        38        277        60        30        3
WML38N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.099        38        34        60        30        3
WMM38N65C2        N-Channel SJ-MOS C2        TO-263        650        0.099        38        277        60        30        3
WMN38N65C2        N-Channel SJ-MOS C2        TO-262        650        0.099        38        277        60        30        3
WMJ26N65C2        N-Channel SJ-MOS C2        TO-247        650        0.19        20        147        34.5        30        3.3
WMK26N65C2        N-Channel SJ-MOS C2        TO-220        650        0.19        20        147        34.5        30        3.3
WML26N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.19        20        34        34.5        30        3.3
WMM26N65C2        N-Channel SJ-MOS C2        TO-263        650        0.19        20        147        34.5        30        3.3
WMN26N65C2        N-Channel SJ-MOS C2        TO-262        650        0.19        20        147        34.5        30        3.3
WMK20N65C2        N-Channel SJ-MOS C2        TO-220        650        0.3        15        86        20.3        30        3.3
WML20N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.3        15        31        20.3        30        3.3
WMM20N65C2        N-Channel SJ-MOS C2        TO-263        650        0.3        15        86        20.3        30        3.3
WMN20N65C2        N-Channel SJ-MOS C2        TO-262        650        0.3        15        86        20.3        30        3.3
WMO20N65C2        N-Channel SJ-MOS C2        TO-252        650        0.3        15        86        20.3        30        3.3
W20N65C2        N-Channel SJ-MOS C2        TO-251        650        0.3        15        86        20.3        30        3.3
WMK16N65C2        N-Channel SJ-MOS C2        TO-220        650        0.32        13        86        19.9        30        3.3
WML16N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.32        13        31        19.9        30        3.3
WMM16N65C2        N-Channel SJ-MOS C2        TO-263        650        0.32        13        86        19.9        30        3.3
WMN16N65C2        N-Channel SJ-MOS C2        TO-262        650        0.32        13        86        19.9        30        3.3
WMO16N65C2        N-Channel SJ-MOS C2        TO-252        650        0.32        13        86        19.9        30        3.3
W16N65C2        N-Channel SJ-MOS C2        TO-251        650        0.32        13        86        19.9        30        3.3
WMK14N65C2        N-Channel SJ-MOS C2        TO-220        650        0.405        11        85        18.7        30        3.3
WML14N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.405        11        31        18.7        30        3.3
WMM14N65C2        N-Channel SJ-MOS C2        TO-263        650        0.405        11        85        18.7        30        3.3
WMN14N65C2        N-Channel SJ-MOS C2        TO-262        650        0.405        11        85        18.7        30        3.3
WMO14N65C2        N-Channel SJ-MOS C2        TO-252        650        0.405        11        85        18.7        30        3.3
W14N65C2        N-Channel SJ-MOS C2        TO-251        650        0.405        11        85        18.7        30        3.3
WMK11N65C2        N-Channel SJ-MOS C2        TO-220        650        0.54        9        63        13.7        30        3.3
WML11N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.54        9        28        13.7        30        3.3
WMM11N65C2        N-Channel SJ-MOS C2        TO-263        650        0.54        9        63        13.7        30        3.3
WMN11N65C2        N-Channel SJ-MOS C2        TO-262        650        0.54        9        63        13.7        30        3.3
WMO11N65C2        N-Channel SJ-MOS C2        TO-252        650        0.54        9        63        13.7        30        3.3
W11N65C2        N-Channel SJ-MOS C2        TO-251        650        0.54        9        63        13.7        30        3.3
WMK10N65C2        N-Channel SJ-MOS C2        TO-220        650        0.69        8        57        13.6        30        3.3
WML10N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.69        8        27        13.6        30        3.3
WMM10N65C2        N-Channel SJ-MOS C2        TO-263        650        0.69        8        57        13.6        30        3.3
WMN10N65C2        N-Channel SJ-MOS C2        TO-262        650        0.69        8        57        13.6        30        3.3
WMO10N65C2        N-Channel SJ-MOS C2        TO-252        650        0.69        8        57        13.6        30        3.3
W10N65C2        N-Channel SJ-MOS C2        TO-251        650        0.69        8        57        13.6        30        3.3
WML09N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.94        6        26        6.8        30        3.3
WMM09N65C2        N-Channel SJ-MOS C2        TO-263        650        0.94        6        45        6.8        30        3.3
WMO09N65C2        N-Channel SJ-MOS C2        TO-252        650        0.94        6        45        6.8        30        3.3
W09N65C2        N-Channel SJ-MOS C2        TO-251        650        0.94        6        45        6.8        30        3.3
WMG09N65C2        N-Channel SJ-MOS C2        TO-251S3        650        0.94        6        45        6.8        30        3.3
WMH09N65C2        N-Channel SJ-MOS C2        TO-251S2        650        0.94        6        45        6.8        30        3.3
WMK09N65C2        N-Channel SJ-MOS C2        TO-220        650        0.94        6        45        6.8        30        3.3
WMN09N65C2        N-Channel SJ-MOS C2        TO-262        650        0.94        6        45        6.8        30        3.3
WMF09N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        0.98        6        6        6.8        30        3.3
WML07N65C2        N-Channel SJ-MOS C2        TO-220F        650        1.14        5        23        5.8        30        3.3
WMM07N65C2        N-Channel SJ-MOS C2        TO-263        650        1.14        5        42        5.8        30        3.3
WMO07N65C2        N-Channel SJ-MOS C2        TO-252        650        1.14        5        42        5.8        30        3.3
W07N65C2        N-Channel SJ-MOS C2        TO-251        650        1.14        5        42        5.8        30        3.3
WMG07N65C2        N-Channel SJ-MOS C2        TO-251S3        650        1.14        5        42        5.8        30        3.3
WMH07N65C2        N-Channel SJ-MOS C2        TO-251S2        650        1.14        5        42        5.8        30        3.3
WMK07N65C2        N-Channel SJ-MOS C2        TO-220        650        1.14        5        42        5.8        30        3.3
WMN07N65C2        N-Channel SJ-MOS C2        TO-262        650        1.14        5        42        5.8        30        3.3
WMF07N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        1.2        5        5        5.8        30        3.3
WMO04N65C2        N-Channel SJ-MOS C2        TO-252        650        1.9        3        29        6.7        30        3.3
W04N65C2        N-Channel SJ-MOS C2        TO-251        650        1.9        3        29        6.7        30        3.3
WMG04N65C2        N-Channel SJ-MOS C2        TO-251S3        650        1.9        3        29        6.7        30        3.3
WMH04N65C2        N-Channel SJ-MOS C2        TO-251S2        650        1.9        3        29        6.7        30        3.3
WML04N65C2        N-Channel SJ-MOS C2        TO-220F        650        1.9        3        20        6.7        30        3.3
WMK04N65C2        N-Channel SJ-MOS C2        TO-220        650        1.9        3        29        6.7        30        3.3
WMM04N65C2        N-Channel SJ-MOS C2        TO-263        650        1.9        3        29        6.7        30        3.3
WMN04N65C2        N-Channel SJ-MOS C2        TO-262        650        1.9        3        29        6.7        30        3.3
WMF04N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        2        3        4.6        6.7        30        3.3
WMK15N65VD        N-Channel SJ-MOS VD        TO-220        650        0.53        10.5        63        13.7        30        3.3
WML15N65VD        N-Channel SJ-MOS VD        TO-220F        650        0.53        10.5        28        13.7        30        3.3
WMM15N65VD        N-Channel SJ-MOS VD        TO-263        650        0.53        10.5        63        13.7        30        3.3
WMN15N65VD        N-Channel SJ-MOS VD        TO-262        650        0.53        10.5        63        13.7        30        3.3
WMO15N65VD        N-Channel SJ-MOS VD        TO-252        650        0.53        10.5        63        13.7        30        3.3
W15N65VD        N-Channel SJ-MOS VD        TO-251        650        0.53        10.5        63        13.7        30        3.3
WMK12N65VD        N-Channel SJ-MOS VD        TO-220        650        0.69        10        57        13.6        30        3.3
WML12N65VD        N-Channel SJ-MOS VD        TO-220F        650        0.69        10        27        13.6        30        3.3
WMM12N65VD        N-Channel SJ-MOS VD        TO-263        650        0.69        10        57        13.6        30        3.3
WMN12N65VD        N-Channel SJ-MOS VD        TO-262        650        0.69        10        57        13.6        30        3.3
WMO12N65VD        N-Channel SJ-MOS VD        TO-252        650        0.69        10        57        13.6        30        3.3
W12N65VD        N-Channel SJ-MOS VD        TO-251        650        0.69        10        57        13.6        30        3.3
WML10N65VD        N-Channel SJ-MOS VD        TO-220F        650        0.92        8        26        6.8        30        3.3
WMM10N65VD        N-Channel SJ-MOS VD        TO-263        650        0.92        8        45        6.8        30        3.3
WMO10N65VD        N-Channel SJ-MOS VD        TO-252        650        0.92        8        45        6.8        30        3.3
W10N65VD        N-Channel SJ-MOS VD        TO-251        650        0.92        8        45        6.8        30        3.3
WMG10N65VD        N-Channel SJ-MOS VD        TO-251S3        650        0.92        8        45        6.8        30        3.3
WMH10N65VD        N-Channel SJ-MOS VD        TO-251S2        650        0.92        8        45        6.8        30        3.3
WMK10N65VD        N-Channel SJ-MOS VD        TO-220        650        0.92        8        45        6.8        30        3.3
WMN10N65VD        N-Channel SJ-MOS VD        TO-262        650        0.92        8        45        6.8        30        3.3
WML09N65VD        N-Channel SJ-MOS VD        TO-220F        650        1.13        6.5        23        5.8        30        3.3
WMM09N65VD        N-Channel SJ-MOS VD        TO-263        650        1.13        6.5        42        5.8        30        3.3
WMO09N65VD        N-Channel SJ-MOS VD        TO-252        650        1.13        6.5        42        5.8        30        3.3
W09N65VD        N-Channel SJ-MOS VD        TO-251        650        1.13        6.5        42        5.8        30        3.3
WMG09N65VD        N-Channel SJ-MOS VD        TO-251S3        650        1.13        6.5        42        5.8        30        3.3
WMH09N65VD        N-Channel SJ-MOS VD        TO-251S2        650        1.13        6.5        42        5.8        30        3.3
WMK09N65VD        N-Channel SJ-MOS VD        TO-220        650        1.13        6.5        42        5.8        30        3.3
WMN09N65VD        N-Channel SJ-MOS VD        TO-262        650        1.13        6.5        42        5.8        30        3.3
WMO05N65VD        N-Channel SJ-MOS VD        TO-252        650        1.89        4        29        6.7        30        3.3
W05N65VD        N-Channel SJ-MOS VD        TO-251        650        1.89        4        29        6.7        30        3.3
WMG05N65VD        N-Channel SJ-MOS VD        TO-251S3        650        1.89        4        29        6.7        30        3.3
WMH05N65VD        N-Channel SJ-MOS VD        TO-251S2        650        1.89        4        29        6.7        30        3.3
WML05N65VD        N-Channel SJ-MOS VD        TO-220F        650        1.89        4        20        6.7        30        3.3
WMF10N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        0.72        8        57        13.6        30        3.3
WMK20N70C2        N-Channel SJ-MOS C2        TO-220        700        0.4        13        86        19.8        30        3.3
WML20N70C2        N-Channel SJ-MOS C2        TO-220F        700        0.4        13        31        19.8        30        3.3
WMM20N70C2        N-Channel SJ-MOS C2        TO-263        700        0.4        13        86        19.8        30        3.3
WMN20N70C2        N-Channel SJ-MOS C2        TO-262        700        0.4        13        86        19.8        30        3.3
WMO20N70C2        N-Channel SJ-MOS C2        TO-252        700        0.4        13        86        19.8        30        3.3
W20N70C2        N-Channel SJ-MOS C2        TO-251        700        0.4        13        86        19.8        30        3.3
WMK16N70C2        N-Channel SJ-MOS C2        TO-220        700        0.42        12        86        19.4        30        3.3
WML16N70C2        N-Channel SJ-MOS C2        TO-220F        700        0.42        12        31        19.4        30        3.3
WMM16N70C2        N-Channel SJ-MOS C2        TO-263        700        0.42        12        86        19.4        30        3.3
WMN16N70C2        N-Channel SJ-MOS C2        TO-262        700        0.42        12        86        19.4        30        3.3
WMO16N70C2        N-Channel SJ-MOS C2        TO-252        700        0.42        12        86        19.4        30        3.3
W16N70C2        N-Channel SJ-MOS C2        TO-251        700        0.42        12        86        19.4        30        3.3
WMK14N70C2        N-Channel SJ-MOS C2        TO-220        700        0.53        11        85        18.7        30        3.3
WML14N70C2        N-Channel SJ-MOS C2        TO-220F        700        0.53        11        31        18.7        30        3.3
WMM14N70C2        N-Channel SJ-MOS C2        TO-263        700        0.53        11        85        18.7        30        3.3
WMN14N70C2        N-Channel SJ-MOS C2        TO-262        700        0.53        11        85        18.7        30        3.3
WMO14N70C2        N-Channel SJ-MOS C2        TO-252        700        0.53        11        85        18.7        30        3.3
W14N70C2        N-Channel SJ-MOS C2        TO-251        700        0.53        11        85        18.7        30        3.3
WMK11N70C2        N-Channel SJ-MOS C2        TO-220        700        0.68        8        63        13.3        30        3.3
WML11N70C2        N-Channel SJ-MOS C2        TO-220F        700        0.68        8        28        13.3        30        3.3
WMM11N70C2        N-Channel SJ-MOS C2        TO-263        700        0.68        8        63        13.3        30        3.3
WMN11N70C2        N-Channel SJ-MOS C2        TO-262        700        0.68        8        63        13.3        30        3.3
WMO11N70C2        N-Channel SJ-MOS C2        TO-252        700        0.68        8        63        13.3        30        3.3
W11N70C2        N-Channel SJ-MOS C2        TO-251        700        0.68        8        63        13.3        30        3.3
WMK10N70C2        N-Channel SJ-MOS C2        TO-220        700        0.92        7.5        57        13.6        30        3.3
WML10N70C2        N-Channel SJ-MOS C2        TO-220F        700        0.92        7.5        27        13.6        30        3.3
WMM10N70C2        N-Channel SJ-MOS C2        TO-263        700        0.92        7.5        57        13.6        30        3.3
WMN10N70C2        N-Channel SJ-MOS C2        TO-262        700        0.92        7.5        57        13.6        30        3.3
WMO10N70C2        N-Channel SJ-MOS C2        TO-252        700        0.92        7.5        57        13.6        30        3.3
W10N70C2        N-Channel SJ-MOS C2        TO-251        700        0.92        7.5        57        13.6        30        3.3
WML09N70C2        N-Channel SJ-MOS C2        TO-220F        700        1.2        5.3        26        6.8        30        3.3
WMM09N70C2        N-Channel SJ-MOS C2        TO-263        700        1.2        5.3        45        6.8        30        3.3
WMO09N70C2        N-Channel SJ-MOS C2        TO-252        700        1.2        5.3        45        6.8        30        3.3
W09N70C2        N-Channel SJ-MOS C2        TO-251        700        1.2        5.3        45        6.8        30        3.3
WMG09N70C2        N-Channel SJ-MOS C2        TO-251S3        700        1.2        5.3        45        6.8        30        3.3
WMH09N70C2        N-Channel SJ-MOS C2        TO-251S2        700        1.2        5.3        45        6.8        30        3.3
WMN09N70C2        N-Channel SJ-MOS C2        TO-262        700        1.2        5.3        45        6.8        30        3.3
WMK09N70C2        N-Channel SJ-MOS C2        TO-220        700        1.2        5.3        45        6.8        30        3.3
WMF09N70C2        N-Channel SJ-MOS C2        SOT-223-2L        700        1.28        5.3        6        6.8        30        3.3
WML07N70C2        N-Channel SJ-MOS C2        TO-220F        700        1.45        4        23        5.8        30        3.3
WMM07N70C2        N-Channel SJ-MOS C2        TO-263        700        1.45        4        42        5.8        30        3.3
WMO07N70C2        N-Channel SJ-MOS C2        TO-252        700        1.45        4        42        5.8        30        3.3
W07N70C2        N-Channel SJ-MOS C2        TO-251        700        1.45        4        42        5.8        30        3.3
WMG07N70C2        N-Channel SJ-MOS C2        TO-251S3        700        1.45        4        42        5.8        30        3.3
WMH07N70C2        N-Channel SJ-MOS C2        TO-251S2        700        1.45        4        42        5.8        30        3.3
WMK07N70C2        N-Channel SJ-MOS C2        TO-220        700        1.45        4        42        5.8        30        3.3
WMN07N70C2        N-Channel SJ-MOS C2        TO-262        700        1.45        4        42        5.8        30        3.3
WMF07N70C2        N-Channel SJ-MOS C2        SOT-223-2L        700        1.5        4        5        5.8        30        3.3
WML04N70C2        N-Channel SJ-MOS C2        TO-220F        700        2.45        2.6        20        6.7        30        3.3
WMM04N70C2        N-Channel SJ-MOS C2        TO-263        700        2.45        2.6        29        6.7        30        3.3
WMN04N70C2        N-Channel SJ-MOS C2        TO-262        700        2.45        2.6        29        6.7        30        3.3
WMK04N70C2        N-Channel SJ-MOS C2        TO-220        700        2.45        2.6        29        6.7        30        3.3
WMO04N70C2        N-Channel SJ-MOS C2        TO-252        700        2.45        2.6        29        6.7        30        3.3
W04N70C2        N-Channel SJ-MOS C2        TO-251        700        2.45        2.6        29        6.7        30        3.3
WMG04N70C2        N-Channel SJ-MOS C2        TO-251S3        700        2.45        2.6        29        6.7        30        3.3
WMH04N70C2        N-Channel SJ-MOS C2        TO-251S2        700        2.45        2.6        29        6.7        30        3.3
WMF04N70C2        N-Channel SJ-MOS C2        SOT-223-2L        700        2.55        2.6        4.6        6.7        30        3.3
WMF10N70C2        N-Channel SJ-MOS C2        SOT-223-2L        700        0.94        7.5        57        13.6        30        3.3
WMK02N90C2        N-Channel SJ-MOS C2        TO-220        900        7        1.5        29        6.4        30        3.3
WML02N90C2        N-Channel SJ-MOS C2        TO-220F        900        7        1.5        20        6.4        30        3.3
WMM02N90C2        N-Channel SJ-MOS C2        TO-263        900        7        1.5        29        6.4        30        3.3
WMN02N90C2        N-Channel SJ-MOS C2        TO-262        900        7        1.5        29        6.4        30        3.3
WMO02N90C2        N-Channel SJ-MOS C2        TO-252        900        7        1.5        29        6.4        30        3.3
W02N90C2        N-Channel SJ-MOS C2        TO-251        900        7        1.5        29        6.4        30        3.3
WMK03N90C2        N-Channel SJ-MOS C2        TO-220        900        5.2        2.6        42        10.5        30        3.3
WML03N90C2        N-Channel SJ-MOS C2        TO-220F        900        5.2        2.6        23        10.5        30        3.3
WMM03N90C2        N-Channel SJ-MOS C2        TO-263        900        5.2        2.6        42        10.5        30        3.3
WMN03N90C2        N-Channel SJ-MOS C2        TO-262        900        5.2        2.6        42        10.5        30        3.3
WMO03N90C2        N-Channel SJ-MOS C2        TO-252        900        5.2        2.6        42        10.5        30        3.3
W03N90C2        N-Channel SJ-MOS C2        TO-251        900        5.2        2.6        42        10.5        30        3.3
WMK05N90C2        N-Channel SJ-MOS C2        TO-220        900        3.1        4        45        11.2        30        3.3
WML05N90C2        N-Channel SJ-MOS C2        TO-220F        900        3.1        4        26        11.2        30        3.3
WMM05N90C2        N-Channel SJ-MOS C2        TO-263        900        3.1        4        45        11.2        30        3.3
WMN05N90C2        N-Channel SJ-MOS C2        TO-262        900        3.1        4        45        11.2        30        3.3
WMO05N90C2        N-Channel SJ-MOS C2        TO-252        900        3.1        4        45        11.2        30        3.3
W05N90C2        N-Channel SJ-MOS C2        TO-251        900        3.1        4        45        11.2        30        3.3
WMK06N90C2        N-Channel SJ-MOS C2        TO-220        900        2.5        5        57        13.1        30        3.3
WML06N90C2        N-Channel SJ-MOS C2        TO-220F        900        2.5        5        27        13.1        30        3.3
WMM06N90C2        N-Channel SJ-MOS C2        TO-263        900        2.5        5        57        13.1        30        3.3
WMN06N90C2        N-Channel SJ-MOS C2        TO-262        900        2.5        5        57        13.1        30        3.3
WMO06N90C2        N-Channel SJ-MOS C2        TO-252        900        2.5        5        57        13.1        30        3.3
W06N90C2        N-Channel SJ-MOS C2        TO-251        900        2.5        5        57        13.1        30        3.3
WMK07N90C2        N-Channel SJ-MOS C2        TO-220        900        2        6.3        63        12.1        30        3.3
WML07N90C2        N-Channel SJ-MOS C2        TO-220F        900        2        6.3        28        12.1        30        3.3
WMM07N90C2        N-Channel SJ-MOS C2        TO-263        900        2        6.3        63        12.1        30        3.3
WMN07N90C2        N-Channel SJ-MOS C2        TO-262        900        2        6.3        63        12.1        30        3.3
WMO07N90C2        N-Channel SJ-MOS C2        TO-252        900        2        6.3        63        12.1        30        3.3
W07N90C2        N-Channel SJ-MOS C2        TO-251        900        2        6.3        63        12.1        30        3.3
WMK09N90C2        N-Channel SJ-MOS C2        TO-220        900        1.37        8        85        18        30        3.3
WML09N90C2        N-Channel SJ-MOS C2        TO-220F        900        1.37        8        31        18        30        3.3
WMM09N90C2        N-Channel SJ-MOS C2        TO-263        900        1.37        8        85        18        30        3.3
WMN09N90C2        N-Channel SJ-MOS C2        TO-262        900        1.37        8        85        18        30        3.3
WMO09N90C2        N-Channel SJ-MOS C2        TO-252        900        1.37        8        85        18        30        3.3
W09N90C2        N-Channel SJ-MOS C2        TO-251        900        1.37        8        85        18        30        3.3
WMK10N90C2        N-Channel SJ-MOS C2        TO-220        900        1.2        9        86        21        30        3.3
WML10N90C2        N-Channel SJ-MOS C2        TO-220F        900        1.2        9        31        21        30        3.3
WMM10N90C2        N-Channel SJ-MOS C2        TO-263        900        1.2        9        86        21        30        3.3
WMN10N90C2        N-Channel SJ-MOS C2        TO-262        900        1.2        9        86        21        30        3.3
WMO10N90C2        N-Channel SJ-MOS C2        TO-252        900        1.2        9        86        21        30        3.3
W10N90C2        N-Channel SJ-MOS C2        TO-251        900        1.2        9        86        21        30        3.3
WML12N90C2        N-Channel SJ-MOS C2        TO-220F        900        0.75        11        34        34        30        3.3
WMM12N90C2        N-Channel SJ-MOS C2        TO-263        900        0.75        11        147        34        30        3.3
WMN12N90C2        N-Channel SJ-MOS C2        TO-262        900        0.75        11        147        34        30        3.3
WMK12N90C2        N-Channel SJ-MOS C2        TO-220        900        0.75        11        147        34        30        3.3
WMJ12N90C2        N-Channel SJ-MOS C2        TO-247        900        0.75        11        147        34        30        3.3
WML15N90C2        N-Channel SJ-MOS C2        TO-220F        900        0.45        14        34        63        30        3
WMM15N90C2        N-Channel SJ-MOS C2        TO-263        900        0.45        14        277        63        30        3
WMN15N90C2        N-Channel SJ-MOS C2        TO-262        900        0.45        14        277        63        30        3
WMK15N90C2        N-Channel SJ-MOS C2        TO-220        900        0.45        14        277        63        30        3
WMJ15N90C2        N-Channel SJ-MOS C2        TO-247        900        0.45        14        277        63        30        3
WML21N90C2        N-Channel SJ-MOS C2        TO-220F        900        0.31        20        34        95        30        3
WMJ21N90C2        N-Channel SJ-MOS C2        TO-247        900        0.31        20        378        95        30        3
WMJ80N65FD        N-Channel SJ-MOS FD        TO-247        650        0.047        80        480        260        30        3
WMJ53N65FD        N-Channel SJ-MOS FD        TO-247        650        0.078        53        378        88.5        30        3
WML53N65FD        N-Channel SJ-MOS FD        TO-220F        650        0.078        53        34        88.5        30        3
WMJ38N65FD        N-Channel SJ-MOS FD        TO-247        650        0.115        38        277        60        30        3
WMK38N65FD        N-Channel SJ-MOS FD        TO-220        650        0.115        38        277        60        30        3
WML38N65FD        N-Channel SJ-MOS FD        TO-220F        650        0.115        38        34        60        30        3
WMM38N65FD        N-Channel SJ-MOS FD        TO-263        650        0.115        38        277        60        30        3
WMN38N65FD        N-Channel SJ-MOS FD        TO-262        650        0.115        38        277        60        30        3
WMJ26N65FD        N-Channel SJ-MOS FD        TO-247        650        0.215        20        147        34.5        30        3.3
WMK26N65FD        N-Channel SJ-MOS FD        TO-220        650        0.215        20        147        34.5        30        3.3
WML26N65FD        N-Channel SJ-MOS FD        TO-220F        650        0.215        20        34        34.5        30        3.3
WMM26N65FD        N-Channel SJ-MOS FD        TO-263        650        0.215        20        147        34.5        30        3.3
WMN26N65FD        N-Channel SJ-MOS FD        TO-262        650        0.215        20        147        34.5        30        3.3
WMK16N65FD        N-Channel SJ-MOS FD        TO-220        650        0.34        13        86        19.9        30        3.3
WML16N65FD        N-Channel SJ-MOS FD        TO-220F        650        0.34        13        31        19.9        30        3.3
WMM16N65FD        N-Channel SJ-MOS FD        TO-263        650        0.34        13        86        19.9        30        3.3
WMN16N65FD        N-Channel SJ-MOS FD        TO-262        650        0.34        13        86        19.9        30        3.3
WMO16N65FD        N-Channel SJ-MOS FD        TO-252        650        0.34        13        86        19.9        30        3.3
W16N65FD        N-Channel SJ-MOS FD        TO-251        650        0.34        13        86        19.9        30        3.3
WMK11N65FD        N-Channel SJ-MOS FD        TO-220        650        0.58        9        63        13.7        30        3.3
WML11N65FD        N-Channel SJ-MOS FD        TO-220F        650        0.58        9        28        13.7        30        3.3
WMM11N65FD        N-Channel SJ-MOS FD        TO-263        650        0.58        9        63        13.7        30        3.3
WMN11N65FD        N-Channel SJ-MOS FD        TO-262        650        0.58        9        63        13.7        30        3.3
WMO11N65FD        N-Channel SJ-MOS FD        TO-252        650        0.58        9        63        13.7        30        3.3
W11N65FD        N-Channel SJ-MOS FD        TO-251        650        0.58        9        63        13.7        30        3.3
WMK07N65FD        N-Channel SJ-MOS FD        TO-220        650        1.24        5        42        5.8        30        3.3
WML07N65FD        N-Channel SJ-MOS FD        TO-220F        650        1.24        5        23        5.8        30        3.3
WMM07N65FD        N-Channel SJ-MOS FD        TO-263        650        1.24        5        42        5.8        30        3.3
WMN07N65FD        N-Channel SJ-MOS FD        TO-262        650        1.24        5        42        5.8        30        3.3
WMO07N65FD        N-Channel SJ-MOS FD        TO-252        650        1.24        5        42        5.8        30        3.3
W07N65FD        N-Channel SJ-MOS FD        TO-251        650        1.24        5        42        5.8        30        3.3
WMJ80N60FD        N-Channel SJ-MOS FD        TO-247        600        0.047        80        480        260        30        3
WMJ53N60FD        N-Channel SJ-MOS FD        TO-247        600        0.078        53        378        88.5        30        3
WML53N60FD        N-Channel SJ-MOS FD        TO-220F        600        0.078        53        34        88.5        30        3
WMJ38N60FD        N-Channel SJ-MOS FD        TO-247        600        0.11        38        277        60        30        3
WMK38N60FD        N-Channel SJ-MOS FD        TO-220        600        0.11        38        277        60        30        3
WML38N60FD        N-Channel SJ-MOS FD        TO-220F        600        0.11        38        34        60        30        3
WMM38N60FD        N-Channel SJ-MOS FD        TO-263        600        0.11        38        277        60        30        3
WMN38N60FD        N-Channel SJ-MOS FD        TO-262        600        0.11        38        277        60        30        3
WMJ26N60FD        N-Channel SJ-MOS FD        TO-247        600        0.215        20        147        34.5        30        3.3
WMK26N60FD        N-Channel SJ-MOS FD        TO-220        600        0.215        20        147        34.5        30        3.3
WML26N60FD        N-Channel SJ-MOS FD        TO-220F        600        0.215        20        34        34.5        30        3.3
WMM26N60FD        N-Channel SJ-MOS FD        TO-263        600        0.215        20        147        34.5        30        3.3
WMN26N60FD        N-Channel SJ-MOS FD        TO-262        600        0.215        20        147        34.5        30        3.3
WMK16N60FD        N-Channel SJ-MOS FD        TO-220        600        0.34        13        86        19.9        30        3
WML16N60FD        N-Channel SJ-MOS FD        TO-220F        600        0.34        13        31        19.9        30        3
WMM16N60FD        N-Channel SJ-MOS FD        TO-263        600        0.34        13        86        19.9        30        3
WMN16N60FD        N-Channel SJ-MOS FD        TO-262        600        0.34        13        86        19.9        30        3
WMO16N60FD        N-Channel SJ-MOS FD        TO-252        600        0.34        13        86        19.9        30        3
W16N60FD        N-Channel SJ-MOS FD        TO-251        600        0.34        13        86        19.9        30        3
WMK11N60FD        N-Channel SJ-MOS FD        TO-220        600        0.58        9        63        13.7        30        3.3
WML11N60FD        N-Channel SJ-MOS FD        TO-220F        600        0.58        9        28        13.7        30        3.3
WMM11N60FD        N-Channel SJ-MOS FD        TO-263        600        0.58        9        63        13.7        30        3.3
WMN11N60FD        N-Channel SJ-MOS FD        TO-262        600        0.58        9        63        13.7        30        3.3
WMO11N60FD        N-Channel SJ-MOS FD        TO-252        600        0.58        9        63        13.7        30        3.3
W11N60FD        N-Channel SJ-MOS FD        TO-251        600        0.58        9        63        13.7        30        3.3
WMK07N60FD        N-Channel SJ-MOS FD        TO-220        600        1.24        5        42        5.8        30        3.3
WML07N60FD        N-Channel SJ-MOS FD        TO-220F        600        1.24        5        23        5.8        30        3.3
WMM07N60FD        N-Channel SJ-MOS FD        TO-263        600        1.24        5        42        5.8        30        3.3
WMN07N60FD        N-Channel SJ-MOS FD        TO-262        600        1.24        5        42        5.8        30        3.3
WMO07N60FD        N-Channel SJ-MOS FD        TO-252        600        1.24        5        42        5.8        30        3.3
W07N60FD        N-Channel SJ-MOS FD        TO-251        600        1.24        5        42        5.8        30        3.3
WMK03N80M3        N-Channel SJ-MOS M3        TO-220        800        4        2.5        29        6.7        30        3.3
WML03N80M3        N-Channel SJ-MOS M3        TO-220F        800        4        2.5        20        6.7        30        3.3
WMM03N80M3        N-Channel SJ-MOS M3        TO-263        800        4        2.5        29        6.7        30        3.3
WMN03N80M3        N-Channel SJ-MOS M3        TO-262        800        4        2.5        29        6.7        30        3.3
WMO03N80M3        N-Channel SJ-MOS M3        TO-252        800        4        2.5        29        6.7        30        3.3
W03N80M3        N-Channel SJ-MOS M3        TO-251        800        4        2.5        29        6.7        30        3.3
WMK05N80M3        N-Channel SJ-MOS M3        TO-220        800        2.3        4        45        10.7        30        3.3
WML05N80M3        N-Channel SJ-MOS M3        TO-220F        800        2.3        4        23        10.7        30        3.3
WMM05N80M3        N-Channel SJ-MOS M3        TO-263        800        2.3        4        45        10.7        30        3.3
WMN05N80M3        N-Channel SJ-MOS M3        TO-262        800        2.3        4        45        10.7        30        3.3
WMO05N80M3        N-Channel SJ-MOS M3        TO-252        800        2.3        4        45        10.7        30        3.3
W05N80M3        N-Channel SJ-MOS M3        TO-251        800        2.3        4        45        10.7        30        3.3
WMK06N80M3        N-Channel SJ-MOS M3        TO-220        800        2        5        50        10.7        30        3.3
WML06N80M3        N-Channel SJ-MOS M3        TO-220F        800        2        5        23        10.7        30        3.3
WMM06N80M3        N-Channel SJ-MOS M3        TO-263        800        2        5        50        10.7        30        3.3
WMN06N80M3        N-Channel SJ-MOS M3        TO-262        800        2        5        50        10.7        30        3.3
WMO06N80M3        N-Channel SJ-MOS M3        TO-252        800        2        5        50        10.7        30        3.3
W06N80M3        N-Channel SJ-MOS M3        TO-251        800        2        5        50        10.7        30        3.3
WMK07N80M3        N-Channel SJ-MOS M3        TO-220        800        1.8        6.8        55        6.8        30        3.3
WML07N80M3        N-Channel SJ-MOS M3        TO-220F        800        1.8        6.8        26        6.8        30        3.3
WMM07N80M3        N-Channel SJ-MOS M3        TO-263        800        1.8        6.8        55        6.8        30        3.3
WMN07N80M3        N-Channel SJ-MOS M3        TO-262        800        1.8        6.8        55        6.8        30        3.3
WMO07N80M3        N-Channel SJ-MOS M3        TO-252        800        1.8        6.8        55        6.8        30        3.3
W07N80M3        N-Channel SJ-MOS M3        TO-251        800        1.8        6.8        55        6.8        30        3.3
WMK08N80M3        N-Channel SJ-MOS M3        TO-220        800        1.38        7        70        13.3        30        3.3
WML08N80M3        N-Channel SJ-MOS M3        TO-220F        800        1.38        7        29        13.3        30        3.3
WMM08N80M3        N-Channel SJ-MOS M3        TO-263        800        1.38        7        70        13.3        30        3.3
WMN08N80M3        N-Channel SJ-MOS M3        TO-262        800        1.38        7        70        13.3        30        3.3
WMO08N80M3        N-Channel SJ-MOS M3        TO-252        800        1.38        7        70        13.3        30        3.3
W08N80M3        N-Channel SJ-MOS M3        TO-251        800        1.38        7        70        13.3        30        3.3
WMK10N80M3        N-Channel SJ-MOS M3        TO-220        800        1.03        10        85        13.9        30        3.3
WML10N80M3        N-Channel SJ-MOS M3        TO-220F        800        1.03        10        31        13.9        30        3.3
WMM10N80M3        N-Channel SJ-MOS M3        TO-263        800        1.03        10        85        13.9        30        3.3
WMN10N80M3        N-Channel Trench MOSFET        TO-262        800        1.03        10        85        13.9        30        3.3
WMO10N80M3        N-Channel SJ-MOS M3        TO-252        800        1.03        10        85        13.9        30        3.3
W10N80M3        N-Channel SJ-MOS M3        TO-251        800        1.03        10        85        13.9        30        3.3
WMK11N80M3        N-Channel SJ-MOS M3        TO-220        800        0.8        10.5        85        18.7        30        3.3
WML11N80M3        N-Channel SJ-MOS M3        TO-220F        800        0.8        10.5        31        18.7        30        3.3
WMM11N80M3        N-Channel SJ-MOS M3        TO-263        800        0.8        10.5        85        18.7        30        3.3
WMN11N80M3        N-Channel SJ-MOS M3        TO-262        800        0.8        10.5        85        18.7        30        3.3
WMO11N80M3        N-Channel SJ-MOS M3        TO-252        800        0.8        10.5        85        18.7        30        3.3
W11N80M3        N-Channel SJ-MOS M3        TO-251        800        0.8        10.5        85        18.7        30        3.3
WMK12N80M3        N-Channel SJ-MOS M3        TO-220        800        0.62        12        86        19        30        3.5
WML12N80M3        N-Channel SJ-MOS M3        TO-220F        800        0.62        12        31        19        30        3.5
WMM12N80M3        N-Channel SJ-MOS M3        TO-263        800        0.62        12        86        19        30        3.5
WMN12N80M3        N-Channel SJ-MOS M3        TO-262        800        0.62        12        86        19        30        3.5
WMO12N80M3        N-Channel SJ-MOS M3        TO-252        800        0.62        12        86        19        30        3.5
W12N80M3        N-Channel SJ-MOS M3        TO-251        800        0.62        12        86        19        30        3.5
WMJ12N80M3        N-Channel SJ-MOS M3        TO-247        800        0.62        12        86        19        30        3.5
WMK13N80M3        N-Channel SJ-MOS M3        TO-220        800        0.48        13        130        20        30        3.5
WML13N80M3        N-Channel SJ-MOS M3        TO-220F        800        0.48        13        33        20        30        3.5
WMM13N80M3        N-Channel SJ-MOS M3        TO-263        800        0.48        13        130        20        30        3.5
WMN13N80M3        N-Channel SJ-MOS M3        TO-262        800        0.48        13        130        20        30        3.5
WMO13N80M3        N-Channel SJ-MOS M3        TO-252        800        0.48        13        130        20        30        3.5
W13N80M3        N-Channel SJ-MOS M3        TO-251        800        0.48        13        130        20        30        3.5
WMJ13N80M3        N-Channel SJ-MOS M3        TO-247        800        0.48        13        130        20        30        3.5
WMK15N80M3        N-Channel SJ-MOS M3        TO-220        800        0.36        15        150        34        30        3.5
WML15N80M3        N-Channel SJ-MOS M3        TO-220F        800        0.36        15        35        34        30        3.5
WMM15N80M3        N-Channel SJ-MOS M3        TO-263        800        0.36        15        150        34        30        3.5
WMN15N80M3        N-Channel SJ-MOS M3        TO-262        800        0.36        15        150        34        30        3.5
WMJ15N80M3        N-Channel SJ-MOS M3        TO-247        800        0.36        15        150        34        30        3.5
WMK25N80M3        N-Channel SJ-MOS M3        TO-220        800        0.26        21        250        45        30        3.5
WML25N80M3        N-Channel SJ-MOS M3        TO-220F        800        0.26        21        38        45        30        3.5
WMM25N80M3        N-Channel SJ-MOS M3        TO-263        800        0.26        21        250        45        30        3.5
WMN25N80M3        N-Channel SJ-MOS M3        TO-262        800        0.26        21        250        45        30        3.5
WMJ25N80M3        N-Channel SJ-MOS M3        TO-247        800        0.26        21        250        45        30        3.5
WMK30N80M3        N-Channel SJ-MOS M3        TO-220        800        0.195        25        277        60        30        3
WML30N80M3        N-Channel SJ-MOS M3        TO-220F        800        0.195        25        34        60        30        3
WMM30N80M3        N-Channel SJ-MOS M3        TO-263        800        0.195        25        277        60        30        3
WMN30N80M3        N-Channel SJ-MOS M3        TO-262        800        0.195        25        277        60        30        3
WMJ30N80M3        N-Channel SJ-MOS M3        TO-247        800        0.195        25        277        60        30        3
WML35N80M3        N-Channel SJ-MOS M3        TO-220F        800        0.128        34        34        90        30        3
WMJ35N80M3        N-Channel SJ-MOS M3        TO-247        800        0.128        34        378        90        30        3
23
14
发表于 2018-12-12 15:09:44 | 显示全部楼层
主要产品如下
百兆网口雷击防护器件/差模
PPTC IC TVS ESD&EOS ProtectionTSS
GDT Power MOSFET Schottky
CESD SPG PCM SMD FUSE
Over Temperature Protection Devices
PTC过流保护方案
WS05-4R2P
WE12DRF-B
WS14P4SMA-B
WS18DTF-B
LPISML300
LPNSML350
LPNSML400
LPNSML450
CMIL300
LSML400
WS03DLCB
WS054R
WS054R2P
WS58P20SMBBH
5.0SMDJ22AL
WES806S2MC
WE0S100/400D
WE05DLCF FBP0402 1PF 2周 手机USB口
WE05DUCF FBP0402 0.5PF 2周 手机FM天线
WS054R2P DFN10L 0.3PF 2周 HDMI
WEPXXXRF0402 402 0.15PF 2周
ESDWE05D5BCB SOD523 10PF(双向) 2周 车载DVD,GPS,音频口
WE05D5MC SOD523 1.0PF 2周 USB,
VGAWE05D5UC SOD523 0.5PF 2周 天线,
DVIWS12M2T,WS15M2T SOT23 2周 CAN 总线
WE05R SOT143 0.7PF 2周
USBWE05M5LC SOT523(两路单向) 0.6PF(线间) 2周
USBWEPXXXRF0603 603 0.15PF 2周 数据线
WS30P30SMCB SMD 电源口
WSXXDLCB SOD323 1.2PF 信号线差模
WS2.84LVU SO8 3PF 100网 RJ45口差模
WS054RUL SOT236L RJ45口差模
WE054RVLC SOT236L 0.8PF RJ45口次级差摸
WE054RVLCH SOT236L 0.8PF RJ45口次级差摸
WS05R SOT143 T1/E1WS054R SOT236L RJ45口差摸
WE05R SOT23 0.6PF(线间) 2周 USB
WS2.88LVU SO8 1000M 口
WEOS480/270AS SMB 不关注 RJ45口共模,ADSL
SPLITERWEOS480/300AS SMB 不关注 RJ45口共模,ADSL
SPLITERWEOS61089-17 SO8 不关注 RJ11
SLICWS58P15SMCB SMC 不关注 POE 电源口
GDTN2RS390 1812 RJ45口共模WE05D5BCB SOD523 10PF VGA, 音频,按键
WS03DLCB SOD323 1.5PF(双向) RJ45,视频矩阵, 对应GBLC03C,
BV03CWE05D3LCB SOD323 1.5PF(双向) 2周 VGA, 音频W
E0R4RVLC SOT236L VGA,DVIWS054R SOT236L 0.3PF(线间) 2.5周
RJ45口WE05R SOT143 视频口,
USBWS054R2P DFN10L HDMI
WES806S SMB BNC,4KV
WS712M SOT23
RS485WS6.5P6SMBB SMB RS485WS18P6SMBB SMB RS232WE05MLC SOT23 0.6PF(线间) 2.5周 USBWS05M2T,WS12M2T SOT23 100PF 2.5周 视频输入口,RS485, 232,对应PSOT05智能手机和平板电脑车载娱乐设备网络通信设备安防监控报警Doucument:WTA006,REV:E 1/共 12上海长园维安电子线路保护有限公司过压产品推荐表 Low Cap TVSPart NumberVRWM(V)VBR(V)Cj(PF)Ipp(A)Vc(V)@IppIR(μA) P(W)MPQ(pcs)PhotoMax Min Max 8/20μs 8/20μs MaxWE05DUCF 5.0 6.0 0.8 1 12.5 15000DFN10062LWE05DLCF 5.0 6.0 2.5 1 100WE05DLCFB 5.0 6.0 2.5 1 12.5 15000WE05DUCFB 5.0 6.0 0.8 1 12.5 1WE05DFB 5.0 6.0 10 4 17 1 1005000WE05DRFB 5.0 6.0 0.5 1 12.5 1WS054R2P 5.0 6.0 0.8 5 20 1 100 3000 DFN251010LWS05R 5.0 6.0 2 12 22 1 2503000 SOT143WE05R 5.0 6.0 1 6.5 17.6 1 100WE05D5UC 5.0 6.0 0.8 5.0 13.6 1 1005000 SOD523WE05D5BC 5.0 6.0 20 6.5 13.5 1 100WE05D5MC 5.0 6.0 1 7.0 13.5 1 1005000 SOD523WE12D5 12.0 13.3 40 6.0 31.0 1 200WS2.8DLCB 2.8 3 1.2 20 15 1 3503000 SOD323WS03DLCB 3.3 4.0 1 20 19 1 350WS03DLCXB 3.0 4.0 3.0 20 15 1 350WS08DLCB 8.0 8.5 1 20 26.8 1 500WS12DLCB 12 13.3 1 11 28.6 1 350WS15DLCB 15.0 16.7 1 10 31.8 1 350WE15D3BCB 15.0 16.7 3 2.5 38 1 100WE05D3LCB 5.0 6.0 3.5 1 100WS05DLV 5.0 6.0 210 28 17 1 450 3000 SOD323WTA006,REV: 2/共 12 Low Cap TVSPart NumberVRWM(V)VBR(V)Cj(PF)Ipp(A)Vc(V)@IppIR(μA) P(W)MPQ(pcs)PhotoMax Min Max 8/20μs 8/20μs MaxWE05M5LC 5.0 6.0 2 1 100 3000 SOT523WE05MLC 5.0 6.0 0.6 1 100 SOT23WS05M2TB 5.0 6.0 100 15 16.7 1 2503000 SOT23WS24M2TB 24 26.7 15 6 40 1 250WS712M 12 13.3 45 12 26 1 400WE054R2S 5.0 6.0 0.3 5 15 1 100 3000 SOT236LWS054RULC 5.0 6.0 3 24 16.5 1WE054RVLCH 5.0 6.0 1.5 7 14.5 1 120WE054RVLC 5.0 6.0 1.5 4 12 1 60WS2.88LVU 2.8 3.0 2.5 30 17 1 600 2500 So8WS2.84LVU 2.8 3.0 5 24 17 1 4002500 So8WS2.84LVUB 2.8 3.0 0.8 25 25 1 500WS264R6N 26 28.9 0.5 9.6 42.1 0.1 260 3000 DFN6LDoucument:WTA006 3/共 12 Low Cap TVSPart NumberVRWM(V)VBR(V)Cj(PF)Ipp(A)Vc(V)@IppIR(μA) P(W)MPQ(pcs)PhotoMax Min Max 8/20μs 8/20μs MaxWE053RVP 5.0 6.0 0.8 5 15 1 100 3000 DFN16166LWS3.34R1N 3.3 3.5 2 25 18 1 450 3000DFN2.6x2.610LWS2.54R7N 2.5 2.7 3.8 40 20 0.5 1000 3000 DFN302010LWE0514R2P 5.0 6 0.8 5 15 1 100 3000 DFN18LDoucument:WTA006,REV: 4/共 12 ThyristorPart NumberVDRM(V)VBO(V)10/1000us(A)10/700us(V)The referencemodelMPQ(pcs)   PhotoWES806S 6 25 80 4000 P0080SB2500 SMBWES1006S 6 25 100 6000 P0080SCWEOS4100/25AS 25 30 100 6000 P0300SCWEOS480/58AS 58 64 80 4000 P0640SBWEOS4100/58AS 58 64 100 6000 P0640SCWEOS480/170AS 170 180 80 4000 P1800SBWEOS4100/170AS 170 180 100 6000 P1800SCWEOS480/190AS 190 230 80 4000 P2300SBWEOS480/220AS 220 260 80 4000 P2600SBWEOS480/270AS 270 310 80 4000 P3100SBWEOS4100/270AS 270 310 100 6000 P3100SCWEOS480/300AS 300 350 80 4000 P3500SBWES306S1 6 15 30 1500 P00803000 SOD123WES506S1 6 15 50 3000 P0080WES80H6S2 6 25 80 5000 P0080 5000 SMAPart NumberVDRM(V)VBO(V)10/1000us(A)10/700us(V)Co (Pf)Typ.MPQ(pcs)   PhotoWES506SMC 6 8 50 3000 30WES806SMC 6 8 80 4000 30 2500 SMBWES1006SMC 6 8 100 6000 30Doucument:WTA006,REV:EWebsite  5/共 12 Power TVSPart NumberVRWM(V)VBR(Volts) @IT Vc@IPP(V)Ipp(A)IR @VRWM(μA)Ppp(W)MPQMIN MAX (pcs)   PhotoSMF5.0A 5 6.4 7 9.2 21.7 400 200SMF18A 18 20 22.1 29.2 6.8 1 200 3000 SOD123SMF26A 26 28.9 31.9 42.1 4.8 1 200WS13P4SMA 13 14.4 15.9 21.5 18.6 1 4005000 SMAWS15P4SMA 15 16.7 18.5 24.4 16.4 1 400WS24P4SMAB 24 26.7 29.5 38.9 10.3 1 400WS26P4SMA 26 28.9 31.9 42.1 9.5 1 400WS33P4SMA 33 36.7 40.6 53.3 7.5 1 400WS36P4SMA 36 40 44.2 58.1 6.9 1 400WS58P4SMA 58 64.4 71.2 93.6 4.3 1 400WS6.0P6SMBB 6 6.67 7.37 10.3 58.3 800 6003000SMBWS6.5P6SMBB 6.5 7.22 7.98 11.2 53.6 500 600WS13P6SMB 13 14.4 15.9 21.5 27.9 1 600WS15P6SMB 15 16.7 18.5 24.4 24.6 1 600WS24P6SMBB 24 26.7 29.5 38.9 15.4 1 600WS26P6SMBB 26 28.9 31.9 42.1 14.3 1 600WS33P6SMB 33 36.7 40.6 53.3 11.3 1 600WS58P6SMBB 58 64.4 71.2 93.6 6.4 1 600WS20P15SMC 20 22.2 24.5 32.4 46.3 1 1500SMCWS28P15SMCB 28 31.1 34.4 45.4 33.1 1 1500WS36P15SMCB 36 40 44.2 58.1 25.9 1 1500WS58P15SMCB 58 64.4 71.2 93.6 16.1 1 1500WS15P30SMCB 15 16.7 18.5 24.4 123 2 3000Doucument:WTA006, 6/共 12 Power TVSPart NumberVRWM(V)VBR(Volts) @IT Vc@IPP(V)Ipp(A)IR @VRWM(μA)Ppp(W)MPQMIN MAX (pcs)   PhotoWS36P30SMCB 36 40 44.2 58.1 51.6 2 30003000 SMCWS58P30SMCB 58 64.4 71.2 93.6 32.1 2 30005.0SMDJ22CA 22 24.4 26.9 35.5 141 5 50005.0SMDJ24CA 24 26.7 29.5 38.9 129 5 50005.0SMDJ40CA 40 44.4 49.1 64.5 77.6 5 50005.0SMDJ58CA 58 64.4 71.2 93.6 53.5 5 5000SM8S24A 24 26.7 30.7 38.9 170 10 6600750DO218ABSM8S33A 33 36.7 42.2 53.3 124 10 6600SM8S36A 36 40 46 58.1 114 10 66005KP36CA 36 40 44.2 58.1 87.8 2 5000300 P600P8S24CA 24 26.7 30.7 38.9 308.48 5 8000P8S33CA 33 36.7 42.2 53.3 225.14 5 8000P8S36CA 36 40 46 58.1 206.54 5 8000Doucument:WTA006,REV: 7/共 12 IC PartNumberVIN VOUT IOUT RONMPQMin (V) Max (pcs)   Photo(V)Min (V)Max(V)Min (A)Max(A)Min (mΩ ) Max (mΩ)WP1403P 4.5 40 4.5 40 0.5 3 60 80 2500 ESOP8WP1403P  Internal Circuit Diagram Features Wide supply voltage range: 4.5~40V Wide working current range: 0.5~3A Programmable overcurrent range: 1.5~4A Programmable overvoltage Rapid response: μs Low RON: 50~80mΩ Low quiescent current :ESOP8Doucument:WTA006,RE 8/共 12 SLIC Part NumberVDRM(V)VBO(V)10/1000us(A)10/700us(V)The referencemodelMPQ(pcs)   PhotoWEOS9110D 120 125 30 4500 2000 SOP8WEOS6108917 170 175 30 4000 2500 SOP8WEOS9110D  information WEOS6108917  informationDoucument:WTA006,REV: 9/共 12 GDT Part numberDCSparkover VoltageMaximumImpulseSparkoverVoltageServiceLifeInsulationresistanceCapacitanceionComplianceMPQ(mm)Photo100V/s 1kv/μs8/20μs10times@100VDC @ 1 MHz(V) (V) (KA) (MΩ) (pF)GDTN2RS3B90 90 550 0.5  1000  0.6 UL497B20001206(3.2×1.6×1.6)GDTN2RS3B150 150 550 0.5  1000  0.6 UL497BGDTN2RS3B200 200 600 0.5  1000  0.6 noneGDTN2RS3B230 230 650 0.5  1000  0.6 UL497BGDTN2RS390 90 550 1  1000  1 UL497B1812(4.2×3.2×2.7)GDTN2RS390H 90 550 2  1000  1 noneGDTN2RS3150 150 600 1  1000  1 UL497BGDTN2RS3150H 150 600 2  1000  1 noneGDTN2RS3200 200 600 1  1000  1 noneGDTN2RS3230 200 600 1  1000  1 UL497BGDTN2RS3300 300 700 1  1000  1 noneGDTN2RS3400+ 400  600 950 1  1000  1 noneGDTN2RS3470 470 1000 1  1000  1 UL497BGDTN2RS590 90 550 5  1000  1 UL497B1000 4.2×5.0×5.0GDTN2RS5350 350 900 5  1000  1 UL497BGDTA2RD5B90 90 600 5  1000  1.5 UL497B500 5.5×T6.0GDTA2RD5B230 230 700 5  1000  1.5 UL497BGDTN3RD590 90 600 5  1000  1.2 UL497B1000 5.0×T7.6GDTN3RD5470 470 1000 5  1000  1.2 UL497BDoucument:WTA006, 10/共 12 GDT Part numberDCSparkover VoltageMaximumImpulseSparkoverVoltageServiceLifeInsulationresistanceCapacitanceionComplianceMPQ(mm)Photo100V/s 1kv/μs8/20μs10times@100VDC @ 1 MHz(V) (V) (KA) (MΩ) (pF)GDTA2RD590 90 600 5  1000  1.5 UL497B5.5×T4.0GDTA2RD5230 230 700 5  1000 1.5UL497BGDTA2RD890 90 600 20  1000 UL497B8.0×T6.0GDTA2RD8600 600 1000 20  1000  1.5 UL497BGDTA2RD890N 90 600 10  1000  1.5None 8.0×T6.0GDTA2RD8600N 600 1000 10  1000  1.5GDTR3RD690 90 550 10  1000  1.5 UL497B5006.0×T8.0GDTRF3RD6230with FailSafe 230 600 10  1000  1.5 None 6.0×T8.0GDTR3RD790 90 600 10  1000  1.5 UL497B 7.5×T11.5GDTR3RD7230 230 700 10  1000  1.5 UL497B 7.5×T11.5GDTRF3RD7230with FailSafe 230 700 10  1000  1.5 UL497B 7.5×T11.5GDTR3RD890 90 550 10  1000  1.5 UL497B 8.0×T10.0Doucument:WTA006,REV: 11/共 12 SPG Part numberDC SparkoverVoltageInsulationresistance@100 VDCCapacitance@ 1 KHz,6VSurge currentcapacity MPQ (mm)  Photo(Vs) IR (MΩ) (pF) 8/20μS(A)WSPT4R2141N 140 ± 30%>100 <1 500 2,0002.0×T4.0WSPT4R2201M 200 ± 20%WSPT4R2301M 300 ± 20%WSPT4R2501M 500 ± 20%WSPT7R2141N 140 ± 30%2.6×T7.0WSPT7R2201M 200 ± 20%WSPT7R2301M 300 ± 20%WSPT7R2501M 500 ± 20%Doucument:WTA006, 12/共 12 CESD Partt NumberWorking VoltageVDC(V) MaxClamping Voltage(V)Leakage Current(μA)Capacitance(pF)ESD Contact(KV)MPQ(pcs)SizeWEP060RF0402 6 25 1 0.2810,000 0402WEP120RF0402 12 25 1 0.2WEP140RF0402 14 25 1 0.2WEP180RF0402 18 25 1 0.2WEP240RF0402 24 25 1 0.2WEP060RF0603 6 25 1 0.25,000 0603WEP120RF0603 12 25 1 0.2WEP140RF0603 14 25 1 0.2WEP180RF0603 18 25 1 0.2WEP240RF0603 24 25 1 0.2WEP050BC0201 5 28~38 1 4~915,000 0201WEP090BC0201
上述为过压产品常用型号,望优先选用。0有上百种产品和系列可供选择,但上述型号外产品可联系我们客户代表确认样品规格和货期时间。谢谢!
CYG Wayon Circuit Protection Co., Ltd.一级代理上海长园维安电子线路保护有限公司一级代理
上海长园维安电子线路保护有限公司A级代理上海长园维安电子线路保护有限公司总代理
一级代理长园维安一级代理长园维安代理一级代理CYGWAYON一级代理CYGWAYON代理上海长园维安微电子有限公司授权经销商
一级代理WAYON一级代理WAYON代理CYG WAYON代理一级代理CYG WAYON一级代理 CGY 一级代理WAY-ON一级代理WAY-ON代理
CGY WAYON CGY WAYON上海长园维安电子线路保护有限公司授权代理证长园维安经销证维安代理证维安经销证WAYON经销证WAYON代理证
上海长圆维安微电子总代理上海长圆维安微电子一级代理长园维安授权经销商CYGWYON授权经销商韦安授权代理商
长园维安总代理CGY WAYON总代理WAYON总代理维安A级代理一级代理韦安一级代理韦安代理韦安总代理韦安授权经销商
一级代理WAYON一级代理WAYON代理WAYON授权总代理WAYON A级代理
一级代理CYG WAYON一级代理CYG WAYON代理长园集团[600525]维安微总代理
一级代理CYG WAYON一级代理CGY WAYON代理长园集团[600525]维安微代理
TO深圳市光与电子有限公司 联系人:杨先生电话075582574660邮箱joshua@szkoyu.com
WS05-4R2PCH
WP25151T5
WP25051T5
WP14040P
LPNSM050=RSTSML050
WEOS61089-17HN
WBFBP03E
WE05DSB
WE05D5MC
SMF5.0A
WS24P4S1B
WS05D5B
WS05DLV
WEOS6108917
WS12P4S1B
WS07D3HP
WP25P21T5
0603WCF075A032V
WE12DFB
WE12DF
WP1404P
WP3881
WP3881L
WP3882
WP3891
WP3899
WP3880
LPNSML450/12
WS2.84LVUB
WS7.0P4S1B
WE2.5D5
WE03D3BCB
WE03D5BC
WE03D5BCB
WE03D5LC
WE03D9
WE3.3MB
WE03MF
WE052RT3
WE052RT5
WE054M1T
WE054M2T
WE054RV
WE054RVL
WE054RVLC
WE05D01B1
WE05D01B1B
WE05D01F2B
WE05D02B2
WE05D02B2B
WE05D3BC
WE05D3lLCB
WE05D5
WE05D5B
WE05D5BC
WE05D5BCB
WE05D5LC
WE05DLCB
WE05D5MC
WE05D5UC
WE05D7
WE05D7B
WE05D9
WE05D9B
WE05D9BC
WE05D9BCB
WE05D9LC
WE05D9LCB
WE05D9UC
WE05D9UCB
WE05DB1
WE05DB1B
WE05DBCB1
WE05DLCB1
WE05DLCF2
WE05DUCB2
WE05M01B1
WE05M01B1B
WE05M02B1
WE05M02B1B
WE05M03B1
WE05M03B1B
WE05M3LC
WE05M5LC
WE05M7
WE05MF
WE05MFC
WE05MFCT3
WE05MLC
WE05R
WE07D5
WE07DB1
WE12D3BC
WE12D3BCB
WE12D5
WE12D5BC
WE12D9
WE12DB1
WE12MLC
WE15D3BC
WEF041002F1
WEF041002F2
WEF041005F1
WEF061002F1
WEF081002F1
WEF081002F2
WEF081005F1
WExxDO1F
WE05DO1F1
WE05DO1F1B
WExxD5
WE03D5
WE05D5
WE06D5
WE07D5
WE012D5
WE015D5
WE24D5
WS2.54R3N
WS2.54RV
WS2.84LVU
WS2.84LVUB
WS2.84LVUC
WS2.85LVUC
WS2.88LVU
WS2.8L
WS2.8LUC
WS2.8LVU
WS3.32RDA
WS3.34R2N
WS3.34R4N
WS3.34RDA
WS3.34RV
WS3.3D
WS3.3R
WS03DLC
WS03DLCB
WSO3LUC
WSO3MFC
WS052R2P
WS054R1M
WS054R2F
WS054R2P
WS054R4M
WS054R
WS054RDA
WS054RLC1T
WS054RLC
WS054RM
WS054RUL
WS054RULC
WS054RV
WS055MDACN
WS056MDA3S
WS056MDA
WS05D1C
WS05D2F1
WS05D52F1B
WS05D52F2
WS05D5
WS05D
WS05DB
WS05DLC
WS05DLCB
WS05DLV
WS05LUC
WS05M
WS05MS
WS05MSC
WS05R
WS12DBCB
WS12DLV
WS12R
WS24M1TB
WS24M2TB
WS712M
WSDA1T03
WS054RDA
WS124RDA
WS055MDAC
WS125MDAC
WS155MDAC
WS245MDAC
WS054RDA
WS124RDA
WS055MDAC
WS125MDAC
WS155MDAC
WS245MDAC
WS057MDA
WS127MDA
WS157MDA
WS247MDA
WS128LCDA
WS158LCDA
WS058MCDA
WS128MCDA
WS158MCDA
WS248MCDA
WSxxD01F1
WS03D01F1
WS03D01F1B
WS05D01F1
WS05D01F1B
WS12D01F1
WS12D01F1B
WS15D01F1
WS15D01F1B
WS24D01F1
WS24D01F1B
WSxxD
WS03D
WS03DB
WS05D
WS05DB
WS012D
WS012DB
WS015D
WS15DB
WS24D
WS24DB
WSxxDLC
WS03DLC
WS03DLCB
WS05DLC
WS05DLCB
WS08DLC
WS08DLCB
WS12DLC
WS12DLCB
WS15DLC
WS15DLCB
WS18DLC
WS18DLCB
WS24DLC
WS24DLCB
WS05LCDA
WS12LCDA
WS15LCDA
WS24LCDA
WS2.8LUC
WS05LUC
WS12LUC
WS05M1T
WS12M1T
WS15M1T
WS24M1T
WS36M1T
WSxxM2T
WS05M2T
WS12M2T
WS15M2T
WS24M2T
WS36M2T
WSxxM2TB
WS05M2TB
WS12M2TB
WS15M2TB
WS24M3TB
WS1536M4TB
WSxxM3T
WS05M4T
WS12M5T
WS15M6T
WS24M7T
WS36M8T
WSxxM501T
WS05M502T
WS12M503T
WS15M504T
WS24M505T
WS36M506T
WSxxMB
WS05MB
WS12MB
WS15MB
WS24MB
WS36MB
WSxxMDA
WS05MDA
WS12MDA
WS15MDA
WS24MDA
WSxxMDAC
WS05MDAC
WS12MDAC
WS15MDAC
WS24MDAC
WSxxMF
WS05MF
WS12MF
WS15MF
WS24MF
WSxxMFC
WS05MFC
WS12MFC
WS15MFC
WS24MFC
WSxxP4SMA(B)
UNIPOLAR BIPOLAR
WS5.0P4SMA WS5.0P4SMAB
WS6.0P4SMA WS6.0P4SMAB
WS6.5P4SMA WS6.5P4SMAB
WS7.0P4SMA WS7.0P4SMAB
WS7.5P4SMA WS7.5P4SMAB
WS8.0P4SMA WS8.0P4SMAB
WS8.5P4SMA WS8.5P4SMAB
WS9.0P4SMA WS9.0P4SMAB
WS10P4SMA WS10P4SMAB
WS11P4SMA WS11P4SMAB
WS12P4SMA WS12P4SMAB
WS13P4SMA WS13P4SMAB
WS14P4SMA WS14P4SMAB
WS15P4SMA WS15P4SMAB
WS16P4SMA WS16P4SMAB
WS17P4SMA WS17P4SMAB
WS18P4SMA WS18P4SMAB
WS20P4SMA WS20P4SMAB
WS22P4SMA WS22P4SMAB
WS24P4SMA WS24P4SMAB
WS26P4SMA WS26P4SMAB
WS28P4SMA WS28P4SMAB
WS30P4SMA WS30P4SMAB
WS33P4SMA WS33P4SMAB
WS36P4SMA WS36P4SMAB
WS40P4SMA WS40P4SMAB
WS43P4SMA WS43P4SMAB
WS45P4SMA WS45P4SMAB
WS48P4SMA WS48P4SMAB
WS51P4SMA WS51P4SMAB
WS54P4SMA WS54P4SMAB
WS58P4SMA WS58P4SMAB
WS60P4SMA WS60P4SMAB
WS64P4SMA WS64P4SMAB
WS70P4SMA WS70P4SMAB
WS75P4SMA WS75P4SMAB
WS78P4SMA WS78P4SMAB
WS85P4SMA WS85P4SMAB
WS90P4SMA WS90P4SMAB
WS100P4SMA WS100P4SMAB
WS110P4SMA WS110P4SMAB
WS120P4SMA WS120P4SMAB
WS130P4SMA WS130P4SMAB
WS150P4SMA WS150P4SMAB
WS160P4SMA WS160P4SMAB
WS170P4SMA WS170P4SMAB
WS188P4SMA WS188P4SMAB
WSxxxP6SMB(B)
UNIPOLAR BIPOLAR
WS5.0P6SMB   WS5.0P6SMBB
WS6.0P6SMB  WS6.0P6SMBB
WS6.5P6SMB  WS6.5P6SMBB
WS7.0P6SMB  WS7.0P6SMBB
WS7.5P6SMB   WS7.5P6SMBB
WS8.0P6SMB  WS8.0P6SMBB
WS8.5P6SMB  WS8.5P6SMBB
WS9.0P6SMB   WS9.0P6SMBB
WS10P6SMB   WS10P6SMBB
WS11P6SMB  WS11P6SMBB
WS12P6SMB   WS12P6SMBB
WS13P6SMB   WS13P6SMBB
WS14P6SMB   WS14P6SMBB
WS15P6SMB  WS15P6SMBB
WS16P6SMB  WS16P6SMBB
WS17P6SMB    WS17P6SMBB
WS18P6SMB   WS18P6SMBB
WS20P6SMB   WS20P6SMBB
WS22P6SMB  WS22P6SMBB
WS24P6SMB   WS24P6SMBB
WS26P6SMB   WS26P6SMBB
WS28P6SMB   WS28P6SMBB
WS30P6SMB  WS30P6SMBB
WS33P6SMB   WS33P6SMBB
WS36P6SMB   WS36P6SMBB
WS40P6SMB    WS40P6SMBB
WS43P6SMB   WS43P6SMBB
WS45P6SMB  WS45P6SMBB
WS48P6SMB   WS48P6SMBB
WS51P6SMB   WS51P6SMBB
WS54P6SMB   WS54P6SMBB
WS58P6SMB   WS58P6SMBB
WS60P6SMB   WS60P6SMBB
WS64P6SMB   WS64P6SMBB
WS70P6SMB   WS70P6SMBB
WS75P6SMB   WS75P6SMBB
WS78P6SMB   WS78P6SMBB
WS85P6SMB  WS85P6SMBB
WS90P6SMB  WS90P6SMBB
WS100P6SMB  WS100P6SMBB
WS110P6SMB   WS110P6SMBB
WS120P6SMB  WS120P6SMBB
WS130P6SMB   WS130P6SMBB
WS150P6SMB   WS150P6SMBB
WS160P6SMB   WS160P6SMBB
WS170P6SMB  WS170P6SMBB
WS180P6SMB   WS180P6SMBB
WS200P6SMB   WS200P6SMBB
WS220P6SMB   WS220P6SMBB
WS250P6SMB WS250P6SMBB
WS300P6SMB   WS300P6SMBB
WS350P6SMB   WS350P6SMBB
WS400P6SMB  WS400P6SMBB
WS440P6SMB  WS440P6SMBB
WS5.0P15SMC WS5.0P15SMCB 5.0 6.40 7.00 10 9.2 163 800
WS6.0P15SMC WS6.0P15SMCB 6.0 6.67 7.37 10 10.3 145.7 800
WS6.5P15SMC WS6.5P15SMCB 6.5 7.22 7.98 10 11.2 134 500
WS7.0P15SMC WS7.0P15SMCB 7.0 7.78 8.60 10 12.0 125 200
WS7.5P15SMC WS7.5P15SMCB 7.5 8.33 9.21 1 12.9 116.3 100
WS8.0P15SMC WS8.0P15SMCB 8.0 8.89 9.83 1 13.6 110.3 50
WS8.5P15SMC WS8.5P15SMCB 8.5 9.44 10.40 1 14.4 104.2 20
WS9.0P15SMC WS9.0P15SMCB 9.0 10.00 11.10 1 15.4 97.4 10
WS10P15SMC WS10P15SMCB 10 11.10 12.30 1 17.0 88.3 5
WS11P15SMC WS11P15SMCB 11 12.20 13.50 1 18.2 82.5 1
WS12P15SMC WS12P15SMCB 12 13.30 14.7 1 19.9 75.4 1
WS13P15SMC WS13P15SMCB 13 14.40 15.90 1 21.5 69.8 1
WS14P15SMC WS14P15SMCB 14 15.60 17.20 1 23.2 64.7 1
WS15P15SMC WS15P15SMCB 15 16.70 18.50 1 24.4 61.5 1
WS16P15SMC WS16P15SMCB 16 17.80 19.70 1 26.0 57.7 1
WS17P15SMC WS17P15SMCB 17 18.90 20.90 1 27.6 54.4 1
WS18P15SMC WS18P15SMCB 18 20.00 22.10 1 29.2 51.4 1
WS20P15SMC WS20P15SMCB 20 22.20 24.50 1 32.4 46.3 1
WS22P15SMC WS22P15SMCB 22 24.40 26.90 1 35.5 42.3 1
WS24P15SMC WS24P15SMCB 24 26.70 29.50 1 38.9 38.6 1
WS26P15SMC WS26P15SMCB 26 28.90 31.90 1 42.1 35.7 1
WS28P15SMC WS28P15SMCB 28 31.10 34.40 1 45.4 33.1 1
WS30P15SMC WS30P15SMCB 30 33.30 36.80 1 48.4 31 1
WS33P15SMC WS33P15SMCB 33 36.70 40.60 1 53.3 28.2 1
WS36P15SMC WS36P15SMCB 36 40.00 44.20 1 58.1 25.9 1
WS40P15SMC WS40P15SMCB 40 44.40 49.10 1 64.5 23.3 1
WS43P15SMC WS43P15SMCB 43 47.80 52.80 1 69.4 21.7 1
LAA2111 25.60 26.00 20.75 21.15 1.20 1.80 0.40 Fig.2
LAA1308 14.00 14.50 14.00 14.50 1.20 1.80 0.40 Fig.2
LAA1508 25.60 26.00 20.75 21.15 1.20 1.80 0.40 Fig.2
LAB1508 25.60 26.00 20.75 21.15 1.20 1.80 0.40 Fig.2
LAC1508 25.60 26.00 20.75 21.15 1.20 1.80 0.40 Fig.2
LAD1508 25.60 26.00 20.75 21.15 1.20 1.80 0.40 Fig.2
LAE1508 19.80 20.60 15.70 16.30 1.20 1.80 0.40 Fig.2
LAF1508 19.80 20.60 15.70 16.30 1.20 1.80 0.40 Fig.2
LAG1508 14.65 16.65 14.65 16.65 1.20 1.80 0.40 Fig.2
LAA2111 6.00 12.00 14 50 6 30.00 5~30 0.010 0.020
LAA1308 4.00 8.00 14 50 5.5 20.00 5~30 0.010 0.020
LAA1508 4.00 8.00 16 50 4.5 15.00 4~12 0.020 0.040
LAB1508 4.00 8.00 16 50 5 15.00 7~30 0.015 0.030
LAC1508 4.00 8.00 14 50 5 20.00 4~12 0.010 0.020
LAD1508 4.00 8.00 14 50 5 20.00 7~30 0.010 0.020
LAE1508 4.00 8.00 14 50 5 25.00 4~12 0.010 0.020
LAF1508 4.00 8.00 14 50 5.5 25.00 7~15 0.008 0.016
LAG1508 4.00 8.00 14 50 5 25.00 7~60 0.008 0.016
SAA1508 4.00 8.00 16 50 4.5 15.00 4~25 0.020 0.040
LAA2111 9.00 8.10 7.15 6.00 5.26 4.80 4.32 3.86 3.15 1.28
LAA1308 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
LAA1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
LAB1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
LAC1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
LAD1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
LAE1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
LAF1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
LAG1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
SAA1508 6.00 5.38 4.75 4.00 3.51 3.19 2.88 2.57 2.10 0.86
WS45P15SMC WS45P15SMCB 45 50.00 55.30 1 72.7 20.6 1
WS48P15SMC WS48P15SMCB 48 53.30 58.90 1 77.4 19.4 1
WS51P15SMC WS51P15SMCB 51 56.70 62.70 1 82.4 18.2 1
WS54P15SMC WS54P15SMCB 54 60.00 66.30 1 87.1 17.3 1
WS58P15SMC WS58P15SMCB 58 64.40 71.20 1 93.6 16.1 1
WS60P15SMC WS60P15SMCB 60 66.70 73.70 1 96.8 15.5 1
WS64P15SMC WS64P15SMCB 64 71.10 78.60 1 103 14.6 1
WS70P15SMC WS70P15SMCB 70 77.80 86.00 1 113 13.3 1
WS75P15SMC WS75P15SMCB 75 83.30 92.10 1 121 12.4 1
WS78P15SMC WS78P15SMCB 78 86.70 95.80 1 126 11.9 1
WS85P15SMC WS85P15SMCB 85 94.40 104 1 137 11 1
WS90P15SMC WS90P15SMCB 90 100 111 1 146 10.3 1
WS100P15SMC WS100P15SMCB 100 111 123 1 162 9.3 1
WS110P15SMC WS110P15SMCB 110 122 135 1 177 8.5 1
WS120P15SMC WS120P15SMCB 120 133 147 1 193 7.8 1
WS130P15SMC WS130P15SMCB 130 144 159 1 209 7.2 1
WS150P15SMC WS150P15SMCB 150 167 185 1 243 6.2 1
WS160P15SMC WS160P15SMCB 160 178 197 1 259 5.8 1
WS170P15SMC WS170P15SMCB 170 189 209 1 275 5.5 1
WS180P15SMC WS180P15SMCB 180 201 222 1 292 5.1 1
WS200P15SMC WS200P15SMCB 200 224 247 1 324 4.6 1
WS220P15SMC WS220P15SMCB 220 246 272 1 356 4.2 1
WS250P15SMC WS250P15SMCB 250 279 309 1 405 3.7 1
WS300P15SMC WS300P15SMCB 300 335 371 1 486 3.1 1
WS350P15SMC WS350P15SMCB 350 391 432 1 567 2.6 1
WS400P15SMC WS400P15SMCB 400 447 494 1 648 2.3 1
WS440P15SMC WS440P15SMCB 440 492 543 1 713 2.1 1
LPUSM005 3.43 2.80 1.25 0.25 0.10
LPUSM010 3.43 2.80 1.25 0.25 0.10
LPUSM020 3.43 2.80 1.25 0.25 0.10
LPUSM035 3.43 2.80 0.85 0.25 0.10
LPUSM050 3.43 2.80 0.85 0.25 0.10
LPUSM075 3.43 2.80 0.85 0.25 0.10
LPUSM110 3.43 2.80 1.00 0.25 0.10
LPUSM150 3.43 2.80 1.30 0.25 0.10
LPUSML150 3.43 2.80 0.80 0.25 0.10
LPUSM175 3.43 2.80 1.30 0.25 0.10
LPUSML175 3.43 2.80 0.80 0.25 0.10
LPUSML175/12 3.43 2.80 0.80 0.25 0.10
LPUSML190 3.43 2.80 0.80 0.25 0.10
LPUSML200 3.43 2.80 0.80 0.25 0.10
LPUSML200/12 3.43 2.80 0.80 0.25 0.10
LPUSML210 3.43 2.80 0.80 0.25 0.10
LPUSML230 3.43 2.80 0.80 0.25 0.10
LPUSML250 3.43 2.80 0.80 0.25 0.10
LPUSML260 3.43 2.80 0.80 0.25 0.10
LPUSML260/12 3.43 2.80 0.80 0.25 0.10
LPUSML300 3.43 2.80 1.00 0.25 0.10
LPUSML300/12 3.43 2.80 1.00 0.25 0.10
LPUSML350 3.43 2.80 1.00 0.25 0.10
LPUSML350/12 3.43 2.80 1.00 0.25 0.10
LPUSML380 3.43 2.80 1.00 0.25 0.10
LPUSML380/12 3.43 2.80 1.00 0.25 0.10
LPUSML400 3.43 2.80 1.00 0.25 0.10
LPUSML400/12 3.43 2.80 1.00 0.25 0.10
LPUSML450 3.43 2.80 1.00 0.25 0.10
LPUSML450/12 3.43 2.80 1.00 0.25 0.10
LPUSML500 3.43 2.80 1.00 0.25 0.10
LPUSML550 3.43 2.80 1.00 0.25 0.10
LPUSML600 3.43 2.80 1.00 0.25 0.10
LPUSML650 3.43 2.80 1.00 0.25 0.10
LPUSML700 3.43 2.80 1.40 0.25 0.10
LPUSML750 3.43 2.80 1.40 0.25 0.10
LPUSM005 0.09 0.07 0.06 0.05 0.05 0.04 0.038 0.034 0.03 0.02
LPUSM010 0.16 0.14 0.13 0.11 0.10 0.09 0.07 0.07 0.06 0.05
LPUSM020 0.32 0.26 0.24 0.21 0.20 0.16 0.15 0.14 0.11 0.09
LPUSM035 0.52 0.48 0.41 0.38 0.35 0.32 0.27 0.26 0.23 0.17
LPUSM050 0.76 0.65 0.57 0.51 0.50 0.44 0.37 0.35 0.29 0.24
LPUSM075 1.11 1.00 0.87 0.77 0.75 0.66 0.58 0.53 0.46 0.36
LPUSM110 1.64 1.46 1.29 1.13 1.10 0.96 0.85 0.74 0.63 0.53
LPUSM150 2.25 2.02 1.76 1.54 1.50 1.29 1.10 1.00 0.87 0.67
LPUSML150 2.25 2.00 1.75 1.55 1.50 1.33 1.15 1.05 0.93 0.70
LPUSM175 2.55 2.30 2.01 1.82 1.75 1.52 1.31 1.18 0.98 0.82
LPUSML175 2.55 2.33 2.02 1.79 1.75 1.53 1.35 1.23 1.07 0.85
LPUSML175/12 2.55 2.33 2.02 1.79 1.75 1.53 1.35 1.23 1.07 0.85
LPUSML190 2.81 2.53 2.20 1.95 1.90 1.67 1.47 1.34 1.17 0.91
LPUSML200 2.96 2.67 2.32 2.05 2.00 1.76 1.55 1.41 1.23 0.96
LPUSML200/12 2.96 2.67 2.32 2.05 2.00 1.76 1.55 1.41 1.23 0.96
LPUSML260 3.85 3.47 3.02 2.67 2.60 2.29 2.01 1.84 1.59 1.25
LPUSML260/12 3.85 3.47 3.02 2.67 2.60 2.29 2.01 1.84 1.59 1.25
LPUSML300 4.40 3.98 3.45 3.07 3.00 2.64 2.30 2.15 1.83 1.42
LPUSML300/12 4.40 3.98 3.45 3.07 3.00 2.64 2.30 2.15 1.83 1.42
LPUSML350 5.18 4.67 4.06 3.59 3.50 3.08 2.71 2.47 2.15 1.68
LPUSML350/12 5.18 4.67 4.06 3.59 3.50 3.08 2.71 2.47 2.15 1.68
LPUSML380 5.55 5.02 4.35 3.89 3.80 3.32 2.92 2.65 2.30 1.81
LPUSML380/12 5.55 5.02 4.35 3.89 3.80 3.32 2.92 2.65 2.30 1.81
LPUSML400 5.92 5.33 4.64 4.11 4.00 3.52 3.09 2.83 2.45 1.92
LPUSML400/12 5.92 5.33 4.64 4.11 4.00 3.52 3.09 2.83 2.45 1.92
LPUSML450 6.12 5.39 5.16 4.71 4.50 3.85 3.35 3.00 2.36 1.56
LPUSML450/12 6.12 5.39 5.16 4.71 4.50 3.85 3.35 3.00 2.36 1.56
LPUSML500 7.40 6.67 5.80 5.13 5.00 4.40 3.87 3.53 3.07 2.40
LPUSML550 8.14 7.34 6.38 5.64 5.50 4.84 4.26 3.88 3.38 2.64
LPUSML600 8.65 7.91 6.93 6.14 6.00 5.23 4.45 4.00 3.63 2.85
LPUSML650 9.20 8.45 7.45 6.66 6.50 5.60 4.65 4.30 3.89 3.00
LPUSML700 9.84 9.00 7.95 7.12 7.00 5.96 4.95 4.50 4.16 3.20
LPUSML750 10.50 9.65 8.50 7.63 7.50 6.40 5.30 4.80 4.45 4.42
LPUSM005 0.05 0.15 30 10 0.25 1.50 1.0 3.600 50.000
LPUSM010 0.10 0.30 30 10 0.50 1.50 1.0 1.600 15.000
LPUSM020 0.20 0.40 30 10 8.00 0.02 1.0 0.800 5.000
LPUSM035 0.35 0.70 6 40 8.00 0.20 1.0 0.320 1.300
LPUSM050 0.50 1.00 6 40 8.00 0.10 1.0 0.250 0.900
LPUSM075 0.75 1.50 6 40 8.00 0.10 1.0 0.130 0.400
LPUSM110 1.10 2.20 6 40 8.00 0.30 1.0 0.060 0.210
LPUSM150 1.50 3.00 6 40 8.00 0.50 1.0 0.040 0.110
LPUSML150 1.50 3.00 6 50 8.00 0.50 1.2 0.010 0.060
LPUSM175 1.75 3.50 6 40 8.00 0.80 0.8 0.020 0.080
LPUSML175 1.75 3.50 6 50 8.00 0.80 1.2 0.005 0.040
LPUSML175/12 1.75 3.50 12 50 8.00 0.80 1.2 0.005 0.040
LPUSML190 1.90 4.90 6 50 9.50 5.00 1.2 0.004 0.018
LPUSML200 2.00 4.00 6 50 8.00 5.00 1.2 0.004 0.028
LPUSML200/12 2.00 4.00 12 50 8.00 5.00 1.2 0.004 0.028
LPUSML210 2.10 4.20 6 50 8.00 5.00 1.2 0.004 0.026
LPUSML230 2.30 4.60 6 50 8.00 5.00 1.2 0.004 0.024
LPUSML250 2.50 5.00 6 50 8.00 5.00 1.2 0.004 0.022
LPUSML260 2.60 8.10 6 50 8.00 5.00 1.2 0.004 0.020
LPUSML260/12 2.60 8.10 12 50 8.00 5.00 1.2 0.004 0.020
LPUSML300 3.00 6.00 6 50 15.00 5.00 1.5 0.003 0.020
LPUSML300/12 3.00 6.00 12 50 15.00 5.00 1.5 0.003 0.020
LPUSML350 3.50 7.00 6 50 17.50 2.00 1.5 0.002 0.014
LPUSML350/12 3.50 7.00 12 50 17.50 2.00 1.5 0.002 0.014
LPUSML380 3.80 7.60 6 50 19.00 2.00 1.5 0.002 0.016
LPUSML380/12 3.80 7.60 12 50 19.00 2.00 1.5 0.002 0.016
LPUSML400 4.00 8.00 6 50 20.00 2.00 1.5 0.002 0.012
LPUSML400/12 4.00 8.00 12 50 20.00 2.00 1.5 0.002 0.012
LPUSML450 4.50 9.00 6 50 22.50 5.00 1.5 0.002 0.013
LPUSML450/12 4.50 9.00 12 50 22.50 5.00 1.5 0.002 0.013
LPUSML500 5.00 10.00 6 50 25.00 5.00 1.5 0.002 0.012
LPUSML550 5.50 11.00 6 50 27.50 5.00 1.5 0.002 0.010
LPUSML600 6.00 12.00 6 50 30.00 5.00 1.5 0.001 0.010
LPUSML650 6.50 13.00 6 50 32.50 5.00 1.5 0.001 0.009
LPUSML700 7.00 14.00 6 50 35.00 5.00 1.5 0.001 0.008
LPUSML750 7.50 15.00 6 50 37.50 5.00 1.5 0.001 0.007
LPUSM005 4000 1210A W0 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM010 4000 1210A W1 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM020 4000 1210A W2 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM035 4000 1210A W3 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM050 4000 1210A W4 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM075 4000 1210A W5 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM110 4000 1210A W6 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM150 4000 1210B W7 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML150 4000 1210A W7 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSM175 4000 1210B W9 2.00 (0.081) 1.00 (0.041) 2.50 (0.101)
LPUSML175 4000 1210A W9 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML175/12 4000 1210A W9 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML190 4000 1210A D 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML200 4000 1210A D1 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML200/12 4000 1210A D1 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML210 4000 1210A D2 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML230 4000 1210A D3 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML250 4000 1210A D4 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML260 4000 1210A D6 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML260/12 4000 1210A D6 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML300 4000 1210A D30 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML300/12 4000 1210A D30 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML350 4000 1210A D5 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML350/12 4000 1210A D5 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML380 4000 1210A D38 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML380/12 4000 1210A D38 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML400 4000 1210A D7 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML400/12 4000 1210A D7 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML450 4000 1210A D9 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML450/12 4000 1210A D9 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA
LPUSML500 4000 1210A D 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML550 4000 1210A D9 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML600 4000 1210A B6 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML650 4000 1210A B65 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML700 4000 1210B B7 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LPUSML750 4000 1210B B75 2.00 (0.081) 1.00 (0.041) 2.50 (0.101) UL,CSA,TUV
LR175SUF 24.1 25.6 2.7 2.9  0.65 7.25 8.00 7.25 8.00 2.3 2.5
LR175DTSUF 42.5 44.9 2.7 2.9  0.65 7.5 8.7
LR210 24.0 26.5 3.5 3.9  0.9 4.0 6.0 4.0 6.0 3.1 3.3
LR220 23.0 25.5 2.9 3.3  0.9 5.0 7.0 5.0 7.0 2.4 2.6
LR270 20.9 23.1 4.9 5.3  0.9 4.0 6.0 4.0 6.0 3.9 4.1
LR270SUF 9.9 10.1 5.9 6.1  0.65 7.0 8.0 3.8 4.8
LR175SUF 3.5 2.9 2.4 1.87 1.75 1.3 1.0 0.8 0.3
LR175DTSUF 3.5 2.9 2.4 1.87 1.75 1.3 1.0 0.8 0.3
LR210 4.3 3.6 2.9 2.31 2.1 1.6 1.3 1.0 0.6 0.3 0.1
LR220 4.5 3.8 3.0 2.45 2.2 1.7 1.4 1.1 0.7 0.3 0.1
LR270 5.6 4.7 4.0 3.05 2.7 2.2 1.7 1.4 0.9 0.4 0.1
LR270SUF 5.6 4.7 4.0 3.05 2.7 2.2 1.7 1.4 0.9 0.4 0.1
LR175SUF 1.75 3.9 16 100 1.8 8.75 5.0 0.023 0.041 0.082
LR175DTSUF 1.75 3.9 16 100 1.8 8.75 5.0 0.023 0.041 0.082
LR210 2.1 5.0 16 60 0.8 10.5 5.0 0.018 0.030 0.060
LR220 2.2 5.3 16 60 0.8 11.0 5.0 0.017 0.029 0.058
LR270 2.7 6.5 16 60 1.2 13.5 5.0 0.010 0.018 0.036
LR270SUF 2.7 6.5 16 100 1.2 13.5 5.0 0.012 0.018 0.036
维安主推MOS系列,深圳市光与电子有限公司代理长园维安产品,欢迎厂家或方案企业联系洽谈.
电话075582574660 82542001 电邮joshua@szkoyu.com
Wayon Super Junction MOSFET, updated 2016.10
WMK16N70C2        NChannel SJMOS C2        TO220        700        0.42        12        86        19.4        30        3.3        MP
WML16N70C2        NChannel SJMOS C2        TO220F        700        0.42        12        31        19.4        30        3.3        MP
WMM16N70C2        NChannel SJMOS C2        TO263        700        0.42        12        86        19.4        30        3.3        MP
WMN16N70C2        NChannel SJMOS C2        TO262        700        0.42        12        86        19.4        30        3.3        MP
WMO16N70C2        NChannel SJMOS C2        TO252        700        0.42        12        86        19.4        30        3.3        MP
WMP16N70C2        NChannel SJMOS C2        TO251        700        0.42        12        86        19.4        30        3.3        MP
WMK14N70C2        NChannel SJMOS C2        TO220        700        0.53        11        81        16.9        30        3.3        EN
WML14N70C2        NChannel SJMOS C2        TO220F        700        0.53        11        30        16.9        30        3.3        EN
WMM14N70C2        NChannel SJMOS C2        TO263        700        0.53        11        81        16.9        30        3.3        EN
WMN14N70C2        NChannel SJMOS C2        TO262        700        0.53        11        81        16.9        30        3.3        EN
WMO14N70C2        NChannel SJMOS C2        TO252        700        0.53        11        81        16.9        30        3.3        EN
WMP14N70C2        NChannel SJMOS C2        TO251        700        0.53        11        81        16.9        30        3.3        EN
WMK11N70C2        NChannel SJMOS C2        TO220        700        0.68        8        63        13.3        30        3.3        MP
WML11N70C2        NChannel SJMOS C2        TO220F        700        0.68        8        28        13.3        30        3.3        MP
WMM11N70C2        NChannel SJMOS C2        TO263        700        0.68        8        63        13.3        30        3.3        MP
WMN11N70C2        NChannel SJMOS C2        TO262        700        0.68        8        63        13.3        30        3.3        MP
WMO11N70C2        NChannel SJMOS C2        TO252        700        0.68        8        63        13.3        30        3.3        MP
WMP11N70C2        NChannel SJMOS C2        TO251        700        0.68        8        63        13.3        30        3.3        MP
WMK10N70C2        NChannel SJMOS C2        TO220        700        0.93        6.7        55        10.2        30        3.3        MP
WML10N70C2        NChannel SJMOS C2        TO220F        700        0.93        6.7        27        10.2        30        3.3        MP
WMM10N70C2        NChannel SJMOS C2        TO263        700        0.93        6.7        55        10.2        30        3.3        MP
WMN10N70C2        NChannel SJMOS C2        TO262        700        0.93        6.7        55        10.2        30        3.3        MP
WMO10N70C2        NChannel SJMOS C2        TO252        700        0.93        6.7        55        10.2        30        3.3        MP
WMP10N70C2        NChannel SJMOS C2        TO251        700        0.93        6.7        55        10.2        30        3.3        MP
WML09N70C2        NChannel SJMOS C2        TO220F        700        1.2        5.3        26        6.8        30        3.3        MP
WMM09N70C2        NChannel SJMOS C2        TO263        700        1.2        5.3        45        6.8        30        3.3        MP
WMO09N70C2        NChannel SJMOS C2        TO252        700        1.2        5.3        45        6.8        30        3.3        MP
WMP09N70C2        NChannel SJMOS C2        TO251        700        1.2        5.3        45        6.8        30        3.3        MP
WMG09N70C2        NChannel SJMOS C2        TO251S3        700        1.2        5.3        45        6.8        30        3.3        MP
WMH09N70C2        NChannel SJMOS C2        TO251S2        700        1.2        5.3        45        6.8        30        3.3        MP
WML07N70C2        NChannel SJMOS C2        TO220F        700        1.45        4        23        5.8        30        3.3        MP
WMM07N70C2        NChannel SJMOS C2        TO263        700        1.45        4        42        5.8        30        3.3        MP
WMO07N70C2        NChannel SJMOS C2        TO252        700        1.45        4        42        5.8        30        3.3        MP
WMP07N70C2        NChannel SJMOS C2        TO251        700        1.45        4        42        5.8        30        3.3        MP
WMG07N70C2        NChannel SJMOS C2        TO251S3        700        1.45        4        42        5.8        30        3.3        MP
WMH07N70C2        NChannel SJMOS C2        TO251S2        700        1.45        4        42        5.8        30        3.3        MP
WMO04N70C2        NChannel SJMOS C2        TO252        700        2.45        2.6        29        6.7        30        3.3        MP
WMP04N70C2        NChannel SJMOS C2        TO251        700        2.45        2.6        29        6.7        30        3.3        MP
WMG04N70C2        NChannel SJMOS C2        TO251S3        700        2.45        2.6        29        6.7        30        3.3        MP
WMH04N70C2        NChannel SJMOS C2        TO251S2        700        2.45        2.6        29        6.7        30        3.3        MP
WMJ26N65C2        NChannel SJMOS C2        TO247        650        0.19        22        156        38.6        30        3.3        MP
WMK26N65C2        NChannel SJMOS C2        TO220        650        0.19        22        156        38.6        30        3.3        MP
WML26N65C2        NChannel SJMOS C2        TO220F        650        0.19        22        34        38.6        30        3.3        MP
WMM26N65C2        NChannel SJMOS C2        TO263        650        0.19        22        156        38.6        30        3.3        MP
WMN26N65C2        NChannel SJMOS C2        TO262        650        0.19        22        156        38.6        30        3.3        MP
WMK16N65C2        NChannel SJMOS C2        TO220        650        0.32        13        86        19.9        30        3.3        MP
WML16N65C2        NChannel SJMOS C2        TO220F        650        0.32        13        31        19.9        30        3.3        MP
WMM16N65C2        NChannel SJMOS C2        TO263        650        0.32        13        86        19.9        30        3.3        MP
WMN16N65C2        NChannel SJMOS C2        TO262        650        0.32        13        86        19.9        30        3.3        MP
WMO16N65C2        NChannel SJMOS C2        TO252        650        0.32        13        86        19.9        30        3.3        MP
WMP16N65C2        NChannel SJMOS C2        TO251        650        0.32        13        86        19.9        30        3.3        MP
WMK14N65C2        NChannel SJMOS C2        TO220        650        0.41        11.8        81        16.9        30        3.3        EN
WML14N65C2        NChannel SJMOS C2        TO220F        650        0.41        11.8        30        16.9        30        3.3        EN
WMM14N65C2        NChannel SJMOS C2        TO263        650        0.41        11.8        81        16.9        30        3.3        EN
WMN14N65C2        NChannel SJMOS C2        TO262        650        0.41        11.8        81        16.9        30        3.3        EN
WMO14N65C2        NChannel SJMOS C2        TO252        650        0.41        11.8        81        16.9        30        3.3        EN
WMP14N65C2        NChannel SJMOS C2        TO251        650        0.41        11.8        81        16.9        30        3.3        EN
WMK11N65C2        NChannel SJMOS C2        TO220        650        0.54        9        63        13.7        30        3.3        MP
WML11N65C2        NChannel SJMOS C2        TO220F        650        0.54        9        28        13.7        30        3.3        MP
WMM11N65C2        NChannel SJMOS C2        TO263        650        0.54        9        63        13.7        30        3.3        MP
WMN11N65C2        NChannel SJMOS C2        TO262        650        0.54        9        63        13.7        30        3.3        MP
WMO11N65C2        NChannel SJMOS C2        TO252        650        0.54        9        63        13.7        30        3.3        MP
WMP11N65C2        NChannel SJMOS C2        TO251        650        0.54        9        63        13.7        30        3.3        MP
WMK10N65C2        NChannel SJMOS C2        TO220        650        0.73        7.6        55        10.2        30        3.3        MP
WML10N65C2        NChannel SJMOS C2        TO220F        650        0.73        7.6        27        10.2        30        3.3        MP
WMM10N65C2        NChannel SJMOS C2        TO263        650        0.73        7.6        55        10.2        30        3.3        MP
WMN10N65C2        NChannel SJMOS C2        TO262        650        0.73        7.6        55        10.2        30        3.3        MP
WMO10N65C2        NChannel SJMOS C2        TO252        650        0.73        7.6        55        10.2        30        3.3        MP
WMP10N65C2        NChannel SJMOS C2        TO251        650        0.73        7.6        55        10.2        30        3.3        MP
WML09N65C2        NChannel SJMOS C2        TO220F        650        0.94        6        26        6.8        30        3.3        MP
WMM09N65C2        NChannel SJMOS C2        TO263        650        0.94        6        45        6.8        30        3.3        MP
WMO09N65C2        NChannel SJMOS C2        TO252        650        0.94        6        45        6.8        30        3.3        MP
WMP09N65C2        NChannel SJMOS C2        TO251        650        0.94        6        45        6.8        30        3.3        MP
WMG09N65C2        NChannel SJMOS C2        TO251S3        650        0.94        6        45        6.8        30        3.3        MP
WMH09N65C2        NChannel SJMOS C2        TO251S2        650        0.94        6        45        6.8        30        3.3        MP
WML07N65C2        NChannel SJMOS C2        TO220F        650        1.14        5        23        5.8        30        3.3        MP
WMM07N65C2        NChannel SJMOS C2        TO263        650        1.14        5        42        5.8        30        3.3        MP
WMO07N65C2        NChannel SJMOS C2        TO252        650        1.14        5        42        5.8        30        3.3        MP
WMP07N65C2        NChannel SJMOS C2        TO251        650        1.14        5        42        5.8        30        3.3        MP
WMG07N65C2        NChannel SJMOS C2        TO251S3        650        1.14        5        42        5.8        30        3.3        MP
WMH07N65C2        NChannel SJMOS C2        TO251S2        650        1.14        5        42        5.8        30        3.3        MP
WMO04N65C2        NChannel SJMOS C2        TO252        650        1.9        3        29        6.7        30        3.3        MP
WMP04N65C2        NChannel SJMOS C2        TO251        650        1.9        3        29        6.7        30        3.3        MP
WMG04N65C2        NChannel SJMOS C2        TO251S3        650        1.9        3        29        6.7        30        3.3        MP
WMH04N65C2        NChannel SJMOS C2        TO251S2        650        1.9        3        29        6.7        30        3.3        MP
WMJ26N60C2        NChannel SJMOS C2        TO247        600        0.19        22        156        38.6        30        3.3        MP
WMK26N60C2        NChannel SJMOS C2        TO220        600        0.19        22        156        38.6        30        3.3        MP
WML26N60C2        NChannel SJMOS C2        TO220F        600        0.19        22        34        38.6        30        3.3        MP
WMM26N60C2        NChannel SJMOS C2        TO263        600        0.19        22        156        38.6        30        3.3        MP
WMN26N60C2        NChannel SJMOS C2        TO262        600        0.19        22        156        38.6        30        3.3        MP
WMK16N60C2        NChannel SJMOS C2        TO220        600        0.32        13        86        19.9        30        3.3        MP
WML16N60C2        NChannel SJMOS C2        TO220F        600        0.32        13        31        19.9        30        3.3        MP
WMM16N60C2        NChannel SJMOS C2        TO263        600        0.32        13        86        19.9        30        3.3        MP
WMN16N60C2        NChannel SJMOS C2        TO262        600        0.32        13        86        19.9        30        3.3        MP
WMO16N60C2        NChannel SJMOS C2        TO252        600        0.32        13        86        19.9        30        3.3        MP
WMP16N60C2        NChannel SJMOS C2        TO251        600        0.32        13        86        19.9        30        3.3        MP
WMK14N60C2        NChannel SJMOS C2        TO220        600        0.41        11.8        81        16.9        30        3.3        EN
WML14N60C2        NChannel SJMOS C2        TO220F        600        0.41        11.8        30        16.9        30        3.3        EN
WMM14N60C2        NChannel SJMOS C2        TO263        600        0.41        11.8        81        16.9        30        3.3        EN
WMN14N60C2        NChannel SJMOS C2        TO262        600        0.41        11.8        81        16.9        30        3.3        EN
WMO14N60C2        NChannel SJMOS C2        TO252        600        0.41        11.8        81        16.9        30        3.3        EN
WMP14N60C2        NChannel SJMOS C2        TO251        600        0.41        11.8        81        16.9        30        3.3        EN
WMK11N60C2        NChannel SJMOS C2        TO220        600        0.54        9        63        13.7        30        3.3        MP
WML11N60C2        NChannel SJMOS C2        TO220F        600        0.54        9        28        13.7        30        3.3        MP
WMM11N60C2        NChannel SJMOS C2        TO263        600        0.54        9        63        13.7        30        3.3        MP
WMN11N60C2        NChannel SJMOS C2        TO262        600        0.54        9        63        13.7        30        3.3        MP
WMO11N60C2        NChannel SJMOS C2        TO252        600        0.54        9        63        13.7        30        3.3        MP
WMP11N60C2        NChannel SJMOS C2        TO251        600        0.54        9        63        13.7        30        3.3        MP
WMK10N60C2        NChannel SJMOS C2        TO220        600        0.93        7.6        55        10.2        30        3.3        MP
WML10N60C2        NChannel SJMOS C2        TO220F        600        0.93        7.6        27        10.2        30        3.3        MP
WMM10N60C2        NChannel SJMOS C2        TO263        600        0.93        7.6        55        10.2        30        3.3        MP
WMN10N60C2        NChannel SJMOS C2        TO262        600        0.93        7.6        55        10.2        30        3.3        MP
WMO10N60C2        NChannel SJMOS C2        TO252        600        0.93        7.6        55        10.2        30        3.3        MP
WMP10N60C2        NChannel SJMOS C2        TO251        600        0.93        7.6        55        10.2        30        3.3        MP
WML09N60C2        NChannel SJMOS C2        TO220F        600        0.94        6        26        6.8        30        3.3        MP
WMM09N60C2        NChannel SJMOS C2        TO263        600        0.94        6        45        6.8        30        3.3        MP
WMO09N60C2        NChannel SJMOS C2        TO252        600        0.94        6        45        6.8        30        3.3        MP
WMP09N60C2        NChannel SJMOS C2        TO251        600        0.94        6        45        6.8        30        3.3        MP
WMG09N60C2        NChannel SJMOS C2        TO251S3        600        0.94        6        45        6.8        30        3.3        MP
WMH09N60C2        NChannel SJMOS C2        TO251S2        600        0.94        6        45        6.8        30        3.3        MP
WML07N60C2        NChannel SJMOS C2        TO220F        600        1.14        5        23        5.8        30        3.3        MP
WMM07N60C2        NChannel SJMOS C2        TO263        600        1.14        5        42        5.8        30        3.3        MP
WMO07N60C2        NChannel SJMOS C2        TO252        600        1.14        5        42        5.8        30        3.3        MP
WMP07N60C2        NChannel SJMOS C2        TO251        600        1.14        5        42        5.8        30        3.3        MP
WMG07N60C2        NChannel SJMOS C2        TO251S3        600        1.14        5        42        5.8        30        3.3        MP
WMH07N60C2        NChannel SJMOS C2        TO251S2        600        1.14        5        42        5.8        30        3.3        MP
WMO04N60C2        NChannel SJMOS C2        TO252        600        1.9        3        29        6.7        30        3.3        MP
WMP04N60C2        NChannel SJMOS C2        TO251        600        1.9        3        29        6.7        30        3.3        MP
WMG04N60C2        NChannel SJMOS C2        TO251S3        600        1.9        3        29        6.7        30        3.3        MP
WMH04N60C2        NChannel SJMOS C2        TO251S2        600        1.9        3        29        6.7        30        3.3        MP
Wayon VDMOS
WMK08N70DM        NChannel Enhanced VDMOSFET        TO220        700        1.2        8        140        26.11        30        3        MP
WML08N70DM        NChannel Enhanced VDMOSFET        TO220F        700        1.2        8        52        26.11        30        3        MP
WMM08N70DM        NChannel Enhanced VDMOSFET        TO263        700        1.2        8        140        26.11        30        3        MP
WMN08N70DM        NChannel Enhanced VDMOSFET        TO262        700        1.2        8        140        26.11        30        3        MP
WML06N70DM        NChannel Enhanced VDMOSFET        TO220F        700        1.7        6        45        21.8        30        3        MP
WMM06N70DM        NChannel Enhanced VDMOSFET        TO263        700        1.7        6        130        21.8        30        3        MP
WMN06N70DM        NChannel Enhanced VDMOSFET        TO262        700        1.7        6        130        21.8        30        3        MP
WMO06N70DM        NChannel Enhanced VDMOSFET        TO252        700        1.7        6        128        21.8        30        3        MP
WMP06N70DM        NChannel Enhanced VDMOSFET        TO251        700        1.7        6        128        21.8        30        3        MP
WMG06N70DM        NChannel Enhanced VDMOSFET        TO251S3        700        1.7        6        128        21.8        30        3        MP
WMH06N70DM        NChannel Enhanced VDMOSFET        TO251S2        700        1.7        6        128        21.8        30        3        MP
WML04N70DM        NChannel Enhanced VDMOSFET        TO220F        700        2.7        4        33        10.34        30        3        MP
WMO04N70DM        NChannel Enhanced VDMOSFET        TO252        700        2.7        4        77        10.34        30        3        MP
WMP04N70DM        NChannel Enhanced VDMOSFET        TO251        700        2.7        4        77        10.34        30        3        MP
WMG04N70DM        NChannel Enhanced VDMOSFET        TO251S3        700        2.7        4        77        10.34        30        3        MP
WMH04N70DM        NChannel Enhanced VDMOSFET        TO251S2        700        2.7        4        77        10.34        30        3        MP
WMK10N65DM        NChannel Enhanced VDMOSFET        TO220        650        1        10        150        28.5        30        3        MP
WML10N65DM        NChannel Enhanced VDMOSFET        TO220F        650        1        10        50        28.5        30        3        MP
WMM10N65DM        NChannel Enhanced VDMOSFET        TO263        650        1        10        150        28.5        30        3        MP
WMN10N65DM        NChannel Enhanced VDMOSFET        TO262        650        1        10        150        28.5        30        3        MP
WML07N65DM        NChannel Enhanced VDMOSFET        TO220F        650        1.4        7        46        21.2        30        3        MP
WMM07N65DM        NChannel Enhanced VDMOSFET        TO263        650        1.4        7        120        21.2        30        3        MP
WMN07N65DM        NChannel Enhanced VDMOSFET        TO262        650        1.4        7        120        21.2        30        3        MP
WMO07N65DM        NChannel Enhanced VDMOSFET        TO252        650        1.4        7        89        21.2        30        3        MP
WMP07N65DM        NChannel Enhanced VDMOSFET        TO251        650        1.4        7        89        21.2        30        3        MP
WMG07N65DM        NChannel Enhanced VDMOSFET        TO251S3        650        1.4        7        89        21.2        30        3        MP
WMH07N65DM        NChannel Enhanced VDMOSFET        TO251S2        650        1.4        7        89        21.2        30        3        MP
WML04N65DM        NChannel Enhanced VDMOSFET        TO220F        650        2.7        4        30        12.5        30        3        MP
WMN04N65DM        NChannel Enhanced VDMOSFET        TO262        650        2.7        4        90        12.5        30        3        MP
WMO04N65DM        NChannel Enhanced VDMOSFET        TO252        650        2.7        4        77        12.5        30        3        MP
WMP04N65DM        NChannel Enhanced VDMOSFET        TO251        650        2.7        4        77        12.5        30        3        MP
WMG04N65DM        NChannel Enhanced VDMOSFET        TO251S3        650        2.7        4        77        12.5        30        3        MP
WMH04N65DM        NChannel Enhanced VDMOSFET        TO251S2        650        2.7        4        77        12.5        30        3        MP
WMK10N60DM        NChannel Enhanced VDMOSFET        TO220        600        0.9        10        156        28.3        30        3        MP
WML10N60DM        NChannel Enhanced VDMOSFET        TO220F        600        0.9        10        50        28.3        30        3        MP
WMM10N60DM        NChannel Enhanced VDMOSFET        TO263        600        0.9        10        156        28.3        30        3        MP
WMN10N60DM        NChannel Enhanced VDMOSFET        TO262        600        0.9        10        156        28.3        30        3        MP
WML07N60DM        NChannel Enhanced VDMOSFET        TO220F        600        1.2        7        45        21.1        30        3        MP
WMM07N60DM        NChannel Enhanced VDMOSFET        TO263        600        1.2        7        122        21.1        30        3        MP
WMN07N60DM        NChannel Enhanced VDMOSFET        TO262        600        1.2        7        122        21.1        30        3        MP
WMO07N60DM        NChannel Enhanced VDMOSFET        TO252        600        1.2        7        90        21.1        30        3        MP
WMP07N60DM        NChannel Enhanced VDMOSFET        TO251        600        1.2        7        90        21.1        30        3        MP
WMG07N60DM        NChannel Enhanced VDMOSFET        TO251S3        600        1.2        7        90        21.1        30        3        MP
WMH07N60DM        NChannel Enhanced VDMOSFET        TO251S2        600        1.2        7        90        21.1        30        3        MP
WML04N60DM        NChannel Enhanced VDMOSFET        TO220F        600        2.4        4        33        12.5        30        3        MP
WMN04N60DM        NChannel Enhanced VDMOSFET        TO262        600        2.4        4        95        12.5        30        3        MP
WMO04N60DM        NChannel Enhanced VDMOSFET        TO252        600        2.4        4        77        12.5        30        3        MP
WMP04N60DM        NChannel Enhanced VDMOSFET        TO251        600        2.4        4        77        12.5        30        3        MP
WMG04N60DM        NChannel Enhanced VDMOSFET        TO251S3        600        2.4        4        77        12.5        30        3        MP
WMH04N60DM        NChannel Enhanced VDMOSFET        TO251S2        600        2.4        4        77        12.5        30        3        MP
WMR01N60DM        NChannel Enhanced VDMOSFET        SOT223        600        10        0.4        3.3        4.4        30        3        MP
Wayon LVMOS
WMK115N10T1        NChannel Trench MOSFET        TO220        100        4.5        115        273        90        20        3        MP
WMM115N10T1        NChannel Trench MOSFET        TO263        100        4.5        115        273        90        20        3        MP
WMK115N08T1        NChannel Trench MOSFET        TO220        85        4.5        115        250        71        20        3        MP
WMM115N08T1        NChannel Trench MOSFET        TO263        85        4.5        115        250        71        20        3        MP
WMS11N06T1        NChannel Trench MOSFET        SOP8        60        15        11        3.5        52.5        20        2        MP
KOYU ELECTRONICS CO.,LTD
CYG WAYON长园维安原厂代理寻ODM合作
杨工程师 TEL:075582574660 82542001
EMAIL:JOSHUA@SZKOYU.COM
WE05MFC
WE060RF0603
WE05D9-B
WE08DF-B
WE12DF-B
WMO04N60C2
WMP04N60C2
WMG04N60C2
WMH04N60C2
WMO07N60C2
WMP07N60C2
WMG07N60C2
WMH07N60C2
WML07N60C2
WMK07N60C2
WMO09N60C2
WMP09N60C2
WMG09N60C2
WMH09N60C2
WML09N60C2
WMK09N60C2
WMO10N60C2
WMP10N60C2
WMG10N60C2
WMH10N60C2
WML10N60C2
WMK10N60C2
WMO11N60C2
WMP11N60C2
WML11N60C2
WMK11N60C2
WMM11N60C2
WMN11N60C2
WMO14N60C2
WMP14N60C2
WML14N60C2
WMK14N60C2
WMM14N60C2
WMN14N60C2
WMO16N60C2
WMP16N60C2
WML16N60C2
WMK16N60C2
WMM16N60C2
WMN16N60C2
WML26N60C2
WMK26N60C2
WMM26N60C2
WMN26N60C2
WMJ26N60C2
WMO04N65C2
WMP04N65C2
WMG04N65C2
WMH04N65C2
WMO07N65C2
WMP07N65C2
WMG07N65C2
WMH07N65C2
WML07N65C2
WMK07N65C2
WMO09N65C2
WMP09N65C2
WMG09N65C2
WMH09N65C2
WML09N65C2
WMK09N65C2
WMO10N65C2
WMP10N65C2
WMG10N65C2
WMH10N65C2
WML10N65C2
WMK10N65C2
WMO11N65C2
WMP11N65C2
WML11N65C2
WMK11N65C2
WMM11N65C2
WME04N70C2
WME04N60C2
WME04N65C2
WME07N70C2
WME09N70C2
WME07N60C2
WME07N65C2
WME09N60C2
WME09N65C2
WMN11N65C2
WMO14N65C2
WMP14N65C2
WML14N65C2
WMK14N65C2
WMM14N65C2
WMN14N65C2
WMO16N65C2
WMP16N65C2
WML16N65C2
WMK16N65C2
WMM16N65C2
WMN16N65C2
WML26N65C2
WMK26N65C2
WMM26N65C2
WMN26N65C2
WMJ26N65C2
WMO04N70C2
WMP04N70C2
WMG04N70C2
WMH04N70C2
WMO07N70C2
WMP07N70C2
WMG07N70C2
WMH07N70C2
WML07N70C2
WMK07N70C2
WMO09N70C2
WMP09N70C2
WMG09N70C2
WMH09N70C2
WML09N70C2
WMK09N70C2
WMO10N70C2
WMP10N70C2
WMG10N70C2
WMH10N70C2
WML10N70C2
WMK10N70C2
WMO11N70C2
WMP11N70C2
WML11N70C2
WMK11N70C2
WMM11N70C2
WMN11N70C2
WMO14N70C2
WMP14N70C2
WML14N70C2
WMK14N70C2
WMM14N70C2
WMN14N70C2
WMO16N70C2
WMP16N70C2
WML16N70C2
WMK16N70C2
WMM16N70C2
WMN16N70C2
WMJ26N60FD
WMJ26N65FD
WMK16N65C2
WML14N60FD
WMK14N60FD
WMM14N60FD
WMN14N60FD
WML16N60FD
WMK16N60FD
WMM16N60FD
WMN16N60FD
WML26N60FD
WMK26N60FD
WMM26N60FD
WMN26N60FD
WML14N65FD
WMK14N65FD
WMM14N65FD
WMN14N65FD
WML16N65FD
WMK16N65FD
WMM16N65FD
WMN16N65FD
WML26N65FD
WMK26N65FD
WMM26N65FD
WMN26N65FD
WMA16N65C2
WML16N65C2
WMA07N70C2
WMA09N70C2
WMA07N60C2
WMA07N65C2
WMA09N60C2
WMA09N65C2
WMA11N70C2
WMA11N60C2
WMA11N65C2
WMA16N70C2
WMA16N60C2
WMA16N65C2
WMA26N60C2
WMA26N65C2
WMD07N70C2
WMD09N70C2
WMD07N60C2
WMD07N65C2
WMD09N60C2
WMD09N65C2
WMD11N70C2
WMD11N60C2
WMD11N65C2
WMD16N70C2
WMD16N60C2
WMD16N65C2
WMD26N60C2
WMD26N65C2
WMG07N70C2
WMH06N70DM
WML11N65C2
TK11A65D
11N65
WEOS4100/300AS
WS08DCLB
GDTN3RD5420
WEOS4024GF
GDTN3RD5090
WS2.84LVU
WS03DLCB
WEOS4100/400AD
WS03DLCB
WEOS4100/270AS
WS2.54R7N
14D820K
WS58P6SMBB
WS03DLCB
WS58P50SMCBH
WS03DLCB
WEOS6108917
EOS6108917Q
WS22P15SMCB
WS03DLCB
GDTN2RS390
20D101K
14D820K
GDTN6RS9800,20kA
GDTR3RD6090
WES6106S,SMC,3kA
WES3006S3,SMC,3kA
WECM5412P
WE05DRFB
WE05DFBN
WE05DSBA
WE05DUCFB
WE05DUCSB
WE3.3DFB
WE05DUCFBF
WE15DRFB
WE18DRFB
WE05MUC
WS07D3HP
WS4.5D3HP
WS07P4N3
WS4.5P4N3
WS09PN3
WS4.5P4N3
WS12PN3
WS4.5P4N3
WS24P4S1B
WS4.5P4N3B
WS264R6N
WS4.5D3HP
WS3.35RVP
WS03MFCBP
WS03DPFB
WSxxM2T(B)A1
WSxxxP4SMA(B)A1
P6SMBxxx(C)AA1
WSxxxP6SMB(B)A1
WSxxxP10D(B)A1
WSxxxP15SMC(B)A1
5.0SMDJxxx(C)AA1
SM8SxxA 6600
WS24P4S1B
WSxxP10D(B)
WS15P10DB
WS15P20SMBB
WS58P20SMB
WS58P20SMBBH
WS15P10SMBB3
WS15P30SMCB3
WS054R3P
WE058R3P
WE3.38R2P
WE3.34R2T
WE054R2N
WS052R2P
WE05DGCSB
WE05DUCSB
WE05DGCFB
WE05DRFB
WE18DRFB
WE05DUCFBF
WS3.32PLC
WS062PLC
WS034R2S
WS054R
WS054RUL
WS054R5S
WS3.34RDA
WS4.5DP
WS4.5D3HP3K
WS4.5P4N3
WS07DP
WS07D3HP3K
WS07P4N3
WS09P4N3
DFN20203L
WS09P4N3A
WS12DP
WS12D3HP3K
WS12P4N3
WS15DP
WS15P4N3
WS18P4N3
WS22P4N3
WS24P4N3
WS26P4N3
WS03MFCB
WE05DLVFB
WE05D5LVB
WE3.3DFB
WE3.38R2P
WS4.5DPFB
WS4.5DPB
WS4.5D3HP3KB
WS4.5P4N3B
WS24P4N3B
WS054R3P
WS054TN
WS054TP
WS05DTSB
WS05DTFB
WECM5412P
WECM5213N
WECM5613F
WECM5411P
WES506S,
WES506S2,
WES806S,
WES1006S
ES306SMC,
WES306S2UC,
WES806S2MC,
WES806SUC,
WES1006SMC,
WES1006SUC
WES306S2UC
WES806SUC
WES1006SUC
WES806SMC
WES1006SMC
WS12P6SMB
WS5.0P6SMB
WS12M2T-B
WE05R
WS16P6SMB
WESO4100/6AD
WEOS4100/25AD
WEOS4100/58AD
WEOS4100/275AD
WEOS4100/320AD
WEOS4100/400AD
WEOS4024GF
WEOS5024GF
WEOS6108917
WEOS6108917HN
WEOS61089HN
WES80H6S2
WES806S
WES1006S
WES806S2MC
WES806SUC
WES1006SUC
GDTN3RD590
WEOS4100/275AD
WE3.38R2P
5.0SMDJ58CA
WS58P20SMBBH
WEOS450/25AS
WES506S2
WEOS4100/25AD
WEOS4100/6AD
WS15P10SMBB
WS15P10DB
5.0SMDJ58CA
WS054R3P
WS054R2P
WE05DUCFB
WE05MUC
WE05R
WS05RXLC
WE05DFBN
WS054R5S
WS05D5B
WS05DPFB
WP25051T5
WP25101T5
WP25151T5
WP25P21T5
WP25P20T5
WS12P4N3
WS12P4N3A
WS15P4N3
WS24M2TB
WS05RXLC
WSXXP4SMA(B)
WSXXP6SMB(B)
P6SMBXX(C)A
WSXXP10D(B)
WSXXP15SMB(B)
WSXXP30SMC(B)
5.0SMDJXX(C)A
SM8SXXA
P8SXX(C)A
WSXXP4SMA(B)
WSXXP6SMB(B)
P6SMBXX(C)A
WSXXP10D(B)
WSXXP15SMB(B)
WSXXP30SMC(B)
5.0SMDJXX(C)A
SM8SXXA
P8SXX(C)A
SM8S24A
SM8S36A
P8S24A
P8S36A
WS18P4N3A
WS15P4N3A
WS18P4N3
WS15P4N3
WS12D3HP
WS18DTF
WE24DFB
WE05DLCSB
WS24P4S1BH
热敏电阻 LBN2000F PTC DIP
SMCJ100CA DO214AB
WS18DTFB
WS100P15SMCB
WS05D5-B
WS24P4S1-BH
LSML450
WE05-4RVLC
LP-NSML260
WS03DPF-B
WS05DPF-B
WS4.5DP
WS07DP
WE05DRF-B-02
LPNSM005 3.50 1.80 0.85 0.25 0.10
LPNSM012 3.50 1.80 0.85 0.25 0.10
LPNSM016 3.50 1.80 0.85 0.25 0.10
LPNSM020 3.50 1.80 0.85 0.25 0.10
LPNSM020/24 3.50 1.80 0.85 0.25 0.10
LPNSM025/16 3.50 1.80 0.85 0.25 0.10
LPNSM025/24 3.50 1.80 0.85 0.25 0.10
LPNSM035 3.50 1.80 0.85 0.25 0.10
LPNSM035/16 3.50 1.80 0.85 0.25 0.10
LPNSM035/24 3.50 1.80 0.85 0.25 0.10
LPNSM050 3.50 1.80 0.85 0.25 0.10
LPNSM050/16 3.50 1.80 0.85 0.25 0.10
LPNSM050/24 3.50 1.80 1.30 0.25 0.10
LPNSM075 3.50 1.80 1.00 0.25 0.10
LPNSM075/8 3.50 1.80 1.00 0.25 0.10
LPNSM075/16 3.50 1.80 1.30 0.25 0.10
LPNSM090/8 3.50 1.80 1.00 0.25 0.10
LPNSM100/8 3.50 1.80 1.30 0.25 0.10
LPNSM110 3.50 1.80 1.30 0.25 0.10
LPNSM110/8 3.50 1.80 1.30 0.25 0.10
LPNSML110/8 3.50 1.80 1.30 0.25 0.10
LPNSM125/8 3.50 1.80 1.30 0.25 0.10
LPNSM150 3.50 1.80 1.30 0.25 0.10
LPNSM150/8 3.50 1.80 1.30 0.25 0.10
LPNSML150 3.50 1.80 0.70 0.25 0.10
LPNSM(L) Series Surfacemount devices
LPNSML150/8 3.50 1.80 0.70 0.25 0.10
LPNSML175 3.50 1.80 0.70 0.25 0.10
LPNSM175/8 3.50 1.80 1.70 0.25 0.10
LPNSML175/12 3.50 1.80 1.70 0.25 0.10
LPNSM200/8 3.50 1.80 1.70 0.25 0.10
LPNSML200 3.50 1.80 0.70 0.25 0.10
LPNSML200/8 3.50 1.80 0.70 0.25 0.10
LPNSML200/12 3.50 1.80 0.70 0.25 0.10
LPNSML260 3.50 1.80 0.70 0.25 0.10
LPNSML260/12 3.50 1.80 0.70 0.25 0.10
LPNSML300 3.50 1.80 0.70 0.25 0.10
LPNSML300/12 3.50 1.80 0.70 0.25 0.10
LPNSML350 3.50 1.80 0.70 0.25 0.10
LPNSML350/12 3.50 1.80 0.70 0.25 0.10
LPNSML380 3.50 1.80 0.70 0.25 0.10
LPNSML380/12 3.50 1.80 0.70 0.25 0.10
LPNSML400 3.50 1.80 1.00 0.25 0.10
LPNSML400/12 3.50 1.80 1.00 0.25 0.10
LPNSML450 3.50 1.80 1.00 0.25 0.10
LPNSML450/12 3.50 1.80 1.00 0.25 0.10
LPNSML500 3.50 1.80 1.00 0.25 0.10
LPNSML550 3.50 1.80 1.00 0.25 0.10
LPNSML600 3.50 1.80 1.00 0.25 0.10
LPNSML650 3.50 1.80 1.40 0.25 0.10
LPNSML700 3.50 1.80 1.40 0.25 0.10
LPNSM005 0.09 0.08 0.06 0.05 0.05 0.04 0.036 0.033 0.029 0.02
LPNSM012 0.19 0.16 0.14 0.13 0.125 0.10 0.09 0.08 0.07 0.04
LPNSM016 0.25 0.20 0.18 0.16 0.16 0.14 0.12 0.11 0.09 0.06
LPNSM020 0.31 0.26 0.22 0.21 0.20 0.18 0.16 0.15 0.13 0.07
LPNSM020/24 0.31 0.26 0.22 0.21 0.20 0.18 0.16 0.15 0.13 0.07
LPNSM025/16 0.38 0.33 0.28 0.26 0.25 0.23 0.20 0.19 0.16 0.10
LPNSM025/24 0.38 0.33 0.28 0.26 0.25 0.23 0.20 0.19 0.16 0.10
LPNSM035 0.51 0.46 0.39 0.36 0.35 0.30 0.27 0.26 0.20 0.16
LPNSM035/16 0.51 0.46 0.39 0.36 0.35 0.30 0.27 0.26 0.20 0.16
LPNSM035/24 0.51 0.46 0.39 0.36 0.35 0.30 0.27 0.26 0.20 0.16
LPNSM050 0.77 0.64 0.56 0.52 0.50 0.45 0.40 0.35 0.32 0.23
LPNSM050/16 0.77 0.64 0.56 0.52 0.50 0.45 0.40 0.35 0.32 0.23
LPNSM050/24 0.77 0.64 0.56 0.52 0.50 0.45 0.40 0.35 0.32 0.23
LPNSM075 1.12 1.01 0.88 0.78 0.75 0.66 0.58 0.53 0.46 0.33
LPNSM075/8 1.12 1.01 0.88 0.78 0.75 0.66 0.58 0.53 0.46 0.33
LPNSM075/16 1.12 1.01 0.88 0.78 0.75 0.66 0.58 0.53 0.46 0.33
LPNSM090/8 1.39 1.15 1.01 0.93 0.90 0.81 0.71 0.63 0.58 0.41
LPNSM100/8 1.54 1.28 1.13 1.04 1.00 0.90 0.81 0.70 0.62 0.45
LPNSM110 1.61 1.44 1.27 1.12 1.10 0.94 0.85 0.77 0.63 0.48
LPNSM110/8 1.61 1.44 1.27 1.12 1.10 0.94 0.85 0.77 0.63 0.48
LPNSML110/8 1.61 1.44 1.27 1.12 1.10 0.94 0.85 0.77 0.63 0.48
LPNSM125/8 1.93 1.60 1.40 1.30 1.25 1.13 1.00 0.88 0.80 0.58
LPNSM150 2.03 1.80 1.63 1.55 1.50 1.24 1.11 1.03 0.88 0.69
LPNSM150/8 2.03 1.80 1.63 1.55 1.50 1.24 1.11 1.03 0.88 0.69
LPNSML150 2.01 1.77 1.62 1.53 1.50 1.22 1.12 1.04 0.87 0.61
LPNSML150/8 2.03 1.80 1.63 1.55 1.50 1.24 1.11 1.03 0.88 0.69
LPNSML175 2.34 2.05 1.89 1.80 1.75 1.44 1.31 1.20 1.00 0.72
LPNSM175/8 2.34 2.05 1.89 1.80 1.75 1.44 1.31 1.20 1.00 0.72
LPNSML175/12 2.34 2.05 1.89 1.80 1.75 1.44 1.31 1.20 1.00 0.72
LPNSM200/8 2.68 2.33 2.15 2.03 2.00 1.66 1.49 1.37 1.44 0.80
LPNSML200 2.68 2.33 2.15 2.03 2.00 1.66 1.49 1.37 1.44 0.80
LPNSML200/8 2.68 2.33 2.15 2.03 2.00 1.66 1.49 1.37 1.44 0.80
LPNSML200/12 6.74 5.11 4.47 4.21 4.00 3.37 2.95 2.62 2.16 1.51
LPNSML260 3.49 3.05 2.82 2.63 2.60 2.15 1.93 1.78 1.49 1.04
LPNSML260/12 3.49 3.05 2.82 2.63 2.60 2.15 1.93 1.78 1.49 1.04
LPNSML300 4.03 3.51 3.26 3.04 3.00 2.49 2.23 2.06 1.71 1.20
LPNSML300/12 4.03 3.51 3.26 3.04 3.00 2.49 2.23 2.06 1.71 1.20
LPNSML350 4.70 4.10 3.80 3.55 3.50 2.90 2.60 2.40 2.00 1.40
LPNSML350/12 4.70 4.10 3.80 3.55 3.50 2.90 2.60 2.40 2.00 1.40
LPNSML380 6.40 4.85 4.25 4.00 3.80 3.20 2.80 2.49 2.05 1.43
LPNSML380/12 6.40 4.85 4.25 4.00 3.80 3.20 2.80 2.49 2.05 1.43
LPNSML400 6.74 5.11 4.47 4.21 4.00 3.37 2.95 2.62 2.16 1.51
LPNSML400/12 6.74 5.11 4.47 4.21 4.00 3.37 2.95 2.62 2.16 1.51
LPNSML450 6.85 5.92 5.47 4.72 4.50 3.73 3.34 3.00 2.35 1.55
LPNSML450/12 6.85 5.92 5.47 4.72 4.50 3.73 3.34 3.00 2.35 1.55
LPNSML500 7.30 6.34 5.66 5.07 5.00 4.42 3.85 3.47 3.12 2.38
LPNSML550 8.03 6.97 6.32 5.58 5.50 4.86 4.24 3.82 3.43 2.62
LPNSML600 8.46 7.60 6.75 6.09 6.00 5.15 4.25 4.00 3.44 2.86
LPNSML650 9.15 8.20 7.30 6.58 6.50 5.58 4.62 4.20 3.75 3.12
LPNSML700 9.80 8.78 7.85 7.07 7.00 5.95 4.95 4.50 4.00 3.30
LPNSM005 0.05 0.15 60 10 1.00 1.20 0.6 2.000 50.000
LPNSM012 0.125 0.29 30 20 1.00 0.20 0.6 1.500 6.000
LPNSM016 0.16 0.37 30 20 1.00 0.30 0.6 1.200 4.500
LPNSM020 0.20 0.40 16 40 8.00 0.05 0.6 0.600 2.500
LPNSM020/24 0.20 0.40 24 40 8.00 0.05 0.6 0.600 2.500
LPNSM025/16 0.25 0.50 16 40 8.00 0.08 0.6 0.550 2.300
LPNSM025/24 0.25 0.50 24 40 8.00 0.08 0.6 0.550 2.300
LPNSM035 0.35 0.75 6 40 8.00 0.10 0.6 0.300 1.200
LPNSM035/16 0.35 0.75 16 40 8.00 0.10 0.6 0.300 1.200
LPNSM035/24 0.35 0.75 24 40 8.00 0.10 0.6 0.300 1.200
LPNSM050 0.50 1.00 6 40 8.00 0.10 0.6 0.150 0.700
LPNSM050/16 0.50 1.00 16 40 8.00 0.10 0.6 0.150 0.700
LPNSM050/24 0.50 1.00 24 40 8.00 0.10 0.6 0.150 0.700
LPNSM075 0.75 1.50 6 40 8.00 0.20 0.6 0.100 0.290
LPNSM075/8 0.75 1.50 8 40 8.00 0.20 1.2 0.100 0.290
LPNSM075/16 0.75 1.50 16 40 8.00 0.20 1.2 0.100 0.290
LPNSM090/8 0.90 1.80 8 40 8.00 0.20 1.2 0.080 0.260
LPNSM100/8 1.00 2.00 8 40 8.00 0.30 1.2 0.060 0.230
LPNSM110 1.10 2.20 6 40 8.00 0.30 0.6 0.055 0.210
LPNSM110/8 1.10 2.20 8 40 8.00 0.30 1.2 0.055 0.210
LPNSML110/8 1.10 2.20 8 50 8.00 0.30 1.2 0.015 0.100
LPNSM125/8 1.25 2.50 8 40 8.00 0.40 1.2 0.050 0.180
LPNSM150 1.50 3.00 6 40 8.00 1.00 0.6 0.040 0.120
LPNSM150/8 1.50 3.00 8 40 8.00 1.00 1.2 0.040 0.120
LPNSM Series
A = LPNSM012 B = LPNSM016 C = LPNSM020 ,LPNSM020/24
D = LPNSM035 ,LPNSM035/16 LPNSM035/24
E = LPNSM050, LPNSM050/16 LPNSM050/24
F = LPNSM075,LPNSM075/8 LPNSM075/16 LPNSM090/8
G = LPNSM100/8,LPNSM110 LPNSM110
H = LPNSM150, LPNSM150/8
I = LPNSM200/8
LPNSML150 1.50 3.00 6 50 8.00 5.00 1.2 0.010 0.065
LPNSML150/8 1.50 3.00 8 50 8.00 5.00 1.2 0.010 0.065
LPNSML150/12 1.50 3.00 12 50 8.00 5.00 1.2 0.010 0.065
LPNSML175 1.75 3.50 6 50 8.00 5.00 1.2 0.010 0.060
LPNSM175/8 1.75 3.50 8 40 8.00 5.00 1.2 0.010 0.060
LPNSML175/12 1.75 3.50 12 40 8.00 5.00 1.2 0.010 0.060
LPNSM200/8 2.00 4.00 8 40 8.00 5.00 1.2 0.008 0.040
LPNSML200 2.00 4.00 6 50 8.00 5.00 1.2 0.008 0.040
LPNSML200/8 2.00 4.00 8 50 8.00 5.00 1.2 0.008 0.040
LPNSML200/12 2.00 4.00 12 50 8.00 5.00 1.2 0.008 0.040
LPNSML260 2.60 5.20 6 50 8.00 5.00 1.2 0.004 0.025
LPNSML260/12 2.60 5.20 12 50 8.00 5.00 1.2 0.004 0.025
LPNSML300 3.00 6.00 6 50 8.00 5.00 1.5 0.004 0.020
LPNSML300/12 3.00 6.00 12 50 8.00 5.00 1.5 0.004 0.020
LPNSML350 3.50 7.00 6 50 8.00 5.00 1.5 0.004 0.018
LPNSML350/12 3.50 7.00 12 50 8.00 5.00 1.5 0.004 0.018
LPNSML380 3.80 7.60 6 50 8.00 5.00 1.5 0.004 0.016
LPNSML380/12 3.80 7.60 12 50 8.00 5.00 1.5 0.004 0.016
LPNSML400 4.00 8.00 6 50 8.00 5.00 1.5 0.004 0.014
LPNSML400/12 4.00 8.00 12 50 8.00 5.00 1.5 0.004 0.014
LPNSML450 4.50 9.00 6 50 22.50 5.00 1.5 0.002 0.012
LPNSML450/12 4.50 9.00 12 50 22.50 5.00 1.5 0.002 0.012
LPNSML500 5.00 10.00 6 50 25.00 5.00 1.5 0.002 0.011
LPNSML550 5.50 11.00 6 50 27.50 5.00 1.5 0.002 0.010
LPNSML600 6.00 12.00 6 50 30.00 5.00 1.5 0.002 0.009
LPNSML650 6.50 13.00 6 50 32.50 5.00 1.5 0.001 0.009
LPNSML700 7.00 14.00 6 50 35.00 5.00 1.5 0.001 0.008
LPNSM005 4000 1206A / 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL Pending
LPNSM012 4000 1206A P 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM016 4000 1206A T 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM020 4000 1206A C 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM020/24 4000 1206A C 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM025/16 4000 1206A G 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM025/24 4000 1206A G 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM035 4000 1206A W 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM035/16 4000 1206A W 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM035/24 4000 1206A W 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM050 4000 1206A A 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM050/16 4000 1206A A 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM050/24 4000 1206A A 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM075 4000 1206A Y 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM075/8 4000 1206A Y 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM075/16 3500 1206B Y 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM090/8 4000 1206A S 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM100/8 3500 1206B M 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM110 3500 1206B O 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM110/8 3500 1206B O 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML110/8 4000 1206A O 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM125/8 3500 1206B Z 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM150 3500 1206B N 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM150/8 3500 1206B N 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML150 4000 1206A I 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML150/8 4000 1206A I 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML150/12 4000 1206A I 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML175 4000 1206A J 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSM175/8 4000 1206A J 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML175/12 4000 1206A J 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSM200/8 4000 1206A F 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML200 4000 1206A F 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML200/8 4000 1206A F 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML200/12 4000 1206A F 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML260 4000 1206A K 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML260/12 4000 1206A K 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML300 4000 1206A R 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML300/12 4000 1206A R 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML350 4000 1206A E 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML350/12 4000 1206A E 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML380 4000 1206A H 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML380/12 4000 1206A H 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML400 4000 1206A L4 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML400/12 4000 1206A L4 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML450 4000 1206A L6 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML450/12 4000 1206A L6 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA
LPNSML500 4000 1206A Q 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML550 4000 1206A L5 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML600 4000 1206A L7 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML650 4000 1206A L65 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
LPNSML700 4000 1206A L70 1.80 (0.071) 1.00 (0.041) 1.80 (0.071) UL,CSA,TUV
WS015K03 15 16 19 10 28 3000 20
WS030K03 30 32 37 10 80 3000 20
WS058K03 58 64 70 10 110 3000 20
WS066K03 66 72 80 10 120 3000 20
WS076K03 76 85 95 10 140 3000 20
WS100K03 100 110 122 10 165 3000 20
WS170K03 170 180 220 10 260 3000 20
WS190K03 190 200 245 10 290 3000 20
WS240K03 240 250 285 10 340 3000 20
WS380K03 380 401 443 10 520 3000 20
WS430K03 430 440 490 10 625 3000 20
SM8S10 10 11.1 14.1 5 18.8 351 15
SM8S10A 10 11.1 12.8 5 17.0 388 15
SM8S11 11 12.2 15.4 5 20.1 328 10
SM8S11A 11 12.2 14.0 5 18.2 363 10
SM8S12 12 13.3 16.9 5 22.0 300 10
SM8S12A 12 13.3 15.3 5 19.9 332 10
SM8S13 13 14.4 18.2 5 23.8 277 10
SM8S13A 13 14.4 16.5 5 21.5 307 10
SM8S14 14 15.6 19.8 5 25.8 256 10
SM8S14A 14 15.6 17.9 5 23.2 284 10
SM8S15 15 16.7 21.1 5 26.9 245 10
SM8S15A 15 16.7 19.2 5 24.4 270 10
SM8S16 16 17.8 22.6 5 28.8 229 10
SM8S16A 16 17.8 20.5 5 26.0 254 10
SM8S17 17 18.9 23.9 5 30.5 216 10
SM8S17A 17 18.9 21.7 5 27.6 239 10
SM8S18 18 20.0 25.3 5 32.2 205 10
SM8S18A 18 20.0 23.3 5 29.2 226 10
SM8S20 20 22.2 28.1 5 35.8 184 10
SM8S20A 20 22.2 25.5 5 32.4 204 10
SM8S22 22 24.4 30.9 5 39.4 168 10
SM8S22A 22 24.4 28.0 5 35.5 186 10
SM8S24 24 26.7 33.8 5 43.0 153 10
SM8S24A 24 26.7 30.7 5 38.9 170 10
SM8S26 26 28.9 36.6 5 46.6 142 10
SM8S26A 26 28.9 33.2 5 42.1 157 10
SM8S28 28 31.1 39.4 5 50.1 132 10
SM8S28A 28 31.1 35.8 5 45.4 145 10
SM8S30 30 33.3 42.2 5 53.5 123 10
SM8S30A 30 33.3 38.3 5 48.4 136 10
SM8S33 33 36.7 46.5 5 59.0 112 10
SM8S33A 33 36.7 42.2 5 53.3 124 10
SM8S36 36 40.0 50.7 5 64.3 103 10
SM8S36A 36 40.0 46.0 5 58.1 114 10
SM8S40 40 44.4 56.3 5 71.4 92.4 10
SM8S40A 40 44.4 51.1 5 64.5 102 10
P15S15A P15S15CA 15 16.7 19.2 5 24.4 614 500
P15S16A P15S16CA 16 17.8 19.7 5 26.0 576 500
P15S17A P15S17CA 17 18.9 21.7 5 27.6 543 500
P15S18A P15S18CA 18 20.0 23.3 5 29.2 513 200
P15S20A P15S20CA 20 22.2 25.5 5 32.4 462 200
P15S22A P15S22CA 22 24.4 28.0 5 35.5 422 200
P15S24A P15S24CA 24 26.7 30.7 5 38.9 385 200
P15S26A P15S26CA 26 28.9 33.2 5 42.1 356 200
P15S28A P15S28CA 28 31.1 35.8 5 45.4 330 10
P15S30A P15S30CA 30 33.3 38.3 5 48.4 309 10
P15S33A P15S33CA 33 36.7 42.2 5 53.3 281 10
P15S36A P15S36CA 36 40.0 46.0 5 58.1 258 10
P15S40A P15S40CA 40 44.4 51.2 5 64.5 232 10
P15S43A P15S43CA 43 47.8 52.8 5 69.4 216 10
P8S10A P8S10CA 10.0 11.1 12.30 5 17.0 470 50
P8S11A P8S11CA 11.0 12.20 13.50 5 18.2 439.5 50
P8S12A P8S12CA 12.0 13.30 14.70 5 19.9 402 50
P8S13A P8S13CA 13.0 14.40 15.90 5 21.5 372 20
P8S14A P8S14CA 14.0 15.60 17.20 5 23.2 344 20
P8S15A P8S15CA 15.0 16.70 18.50 5 24.4 327.8 10
P8S16A P8S16CA 16.0 17.80 19.70 5 26.0 307.6 10
P8S17A P8S17CA 17.0 18.90 20.90 5 27.6 289.8 5
P8S18A P8S18CA 18.0 20.00 22.10 5 29.2 273.9 5
P8S20A P8S20CA 20.0 22.20 24.50 5 32.4 246.9 5
P8S22A P8S22CA 22.0 24.40 26.90 5 35.5 225.3 5
P8S24A P8S24CA 24.0 26.70 29.50 5 38.9 205.6 5
P8S26A P8S26CA 26.0 28.90 31.90 5 42.1 190.0 5
P8S28A P8S28CA 28.0 31.10 34.40 5 45.4 176.2 5
P8S30A P8S30CA 30.0 33.30 36.80 5 48.4 165.2 5
P8S33A P8S33CA 33.0 36.70 40.60 5 53.3 150 5
P8S36A P8S36CA 36.0 40.00 44.20 5 58.1 137.7 5
P8S40A P8S40CA 40.0 44.40 49.10 5 64.5 124 5
P8S43A P8S43CA 43.0 47.8 52.8 5 69.4 115 5
WEOS450/350AS1        350        460        50        2500        10
WEOS4100/25AS        25        40        100        6000        802500        SMB
WEOS4100/58AS        58        77        100        6000        100
WEOS4100/65AS        65        88        100        6000        40
WEOS4100/220AS        220        300        100        6000        60
WEOS480/58AS        58        77        80        4000        50
WEOS480/270AS        270        350        80        4000        35
WEOS4100/400AS3        400        530        100        6000        352500        SMB3
WEOS4100/6AD        6        25        100        6000        605000        DFN
WEOS4100/25AD        25        40        100        6000        305000        DFN
WEOS4100/400AD        400        530        100        6000        305000        DFN
WEOS4100/6AD 8DC 6 5 25 50 800 2.2 5 35 75
WEOS4100/25AD 03DC 25 5 40 50 800 2.2 5 25 45
WEOS4100/58AD 06DC 58 5 77 150 800 2.2 5 55 85
WEOS4100/65AD 07DC 65 5 88 150 800 2.2 5 50 75
WEOS4100/75AD 09DC 75 5 98 150 800 2.2 5 45 70
WEOS4100/90AD 11DC 90 5 130 150 800 2.2 5 45 70
WEOS4100/120AD 13DC 120 5 160 150 800 2.2 5 40 60
WEOS4100/140AD 15DC 140 5 180 150 800 2.2 5 35 55
WEOS4100/170AD 18DC 170 5 220 150 800 2.2 5 35 50
WEOS4100/190AD 23DC 190 5 260 150 800 2.2 5 30 50
WEOS4100/220AD 26DC 220 5 300 150 800 2.2 5 30 45
WEOS4100/275AD 31DC 275 5 350 150 800 2.2 5 30 45
WEOS4100/320AD 35DC 320 5 400 150 800 2.2 5 25 40
WEOS4100/400AD 45DC 400 5 530 50 800 2.2 5 25 45
WEOS4100/400AS3 400 5 520 800 4 2.2 35 10
WEOS4100/15AS W 02SC 15 5 25 800 4 2.2 110 50
WEOS4100/25AS W 03SC 25 5 40 800 4 2.2 110 50
WEOS4100/58AS W 06SC 58 5 77 800 4 2.2 100 120
WEOS4100/65AS W 07SC 65 5 88 800 4 2.2 40 120
WEOS4100/75AS W 09SC 75 5 98 800 4 2.2 90 120
WEOS4100/90AS W 11SC 90 5 130 800 4 2.2 80 120
WEOS4100/100AS W 12SC 100 5 130 800 4 2.2 80 120
WEOS4100/120AS W 14SC 120 5 160 800 4 2.2 80 120
WEOS4100/140AS W 15SC 140 5 180 800 4 2.2 80 120
WEOS4100/170AS W 18SC 170 5 220 800 4 2.2 60 120
WEOS4100/180AS W 20SC 180 5 220 800 4 2.2 60 120
WEOS4100/190AS W 23SC 190 5 260 800 4 2.2 60 120
WEOS4100/220AS W 26SC 220 5 300 800 4 2.2 60 120
WEOS4100/230AS W 28SC 230 5 290 800 4 2.2 60 120
WEOS4100/270AS W 31SC 270 5 350 800 4 2.2 60 120
WEOS4100/300AS W 35SC 320 5 400 800 4 2.2 60 120
WEOS4100/350AS W 36SC 350 5 460 800 4 2.2 45 120
WEOS4100/400AS W 42SC 400 5 540 800 4 2.2 45 120
WEOS4100/440AS W 45SC 440 5 600 800 4 2.2 45 120
WEOS450/350AS1 350 5 460 800 4 2.2 120 10
WES306S2        6        15        30        2000        105000        SMA
WES506S2        6        15        50        2500        45
WES806S2        6        15        80        4000        30
WES806S2MC        6        15        75        4000        15
WES806SUC        6        25        80        4000        92500        SMB
WES1006SMC        6        15        100        6000        30
WES1006SUC        6        25        100        6000        15
WES1006S        6        15        100        6000        100
WES306S1        6        15        30        2000        103000        SOD123
WES506S2 6 5 9.5 15 800 4 2.2 50 45
WES806S2 6 5 18 800 4 2.2 30 5
0WES806S2MC 6 5 9.5 15 800 4 2.2 15 15
WES806SUC 6 5 17 25 800 4 2.2 15 9
WES1006SMC 6 5 6 9.5 13 15 25 800 4 2.2 50 30 40
WES1006SUC 6 5 17 25 800 4 2.2 18 15
WES1006S 6 5 6 9.5 13 15 25 15 800 4 2.2 30 50 95 120
WES306S1 6 5 9 25 800 4 2.2 20 10
WSR6003CWSR4003A
WSR4002A
WS3.32PLC        3.3        3.7        10        100        20        0.15        30        1800        SOP8
WS062PLC        6        6.7        14        100        20        0.16        30        2000        SOP8
WS4.5DP        4.5        6        700        100        15        0.05        30        1500        DFN16102L
WS05DP        5        5.7        750        100        18        0.05        30        2000        DFN16102L
WS07DP        7        8        485        100        25        0.03        30        2500        DFN16102L
WS07DP01        7        8        800        110        25        0.07        30        2100        DFN16102L
WS12DP        12        13        265        50        30        0.03        30        1500        DFN16102L
WS4.5D3HP        4.5        5        700        100        15        0.05        30        1500        SOD323F
WS4.5D3HQ        4.5        4.6        800        150        12        0.1        30        1800        SOD323F
WS07D3HP        7        8        485        80        20        0.02        30        1600        SOD323F
WS12D3HP        12        13        265        50        30        0.08        30        1500        SOD323F
WS4.5D3HP3K        4.5        4.6        1000        140        16        0.05        30        2200        SOD323
WS4.5D3HP3KB        4.5        4.6        200        135        15        0.11        30        2500        SOD323
WS07D3HP3K        7        8        700        130        22        0.055        30        3000        SOD323
WS26P4N        26        28.5        800        124        49        0.07        30        6000        DFN20202L
WS4.5P4N3        4.5        5        2400        260        15        0.01        30        3500        DFN20203L
WS4.5P4N3B        4.5        4.6        400        220        15        0.07        30        3000        DFN20203L
WS4.5P4N3BH        4.5        4.6        1450        300        15        0.06        30        4000        DFN20203L
WS07P4N3C        7        8        450        145        17        0.05        30        2300        DFN20203L
WS07P4N3        7        8        1500        250        18        0.04        30        4400        DFN20203L
WS09P4N3        9        10        1200        190        26        0.04        30        5000        DFN20203L
WS12P4N3        12        13.4        900        130        30        0.08        30        4000        DFN20203L
WS12P4N3A        12        13.3        1535        240        25        0.05        30        5800        DFN20203L
WS15P4N3        15        16.6        725        100        35        0.07        30        4000        DFN20203L
WS15P4N3A        15        16.7        1230        200        30        0.03        30        5800        DFN20203L
WS18P4N3A        18        20        1060        180        37        0.06        30        6500        DFN20203L
WS22P4N3A        22        24.3        890        140        44        0.035        30        5600        DFN20203L
WS26P4N3        26        28        800        140        51        0.07        30        7000        DFN20203L
WE05DGCSB        5        6        0.12        3        15        2        20        60        DFN06032L
WE05DUCSB        5        5.5        0.5        5        26        1        18        150        DFN06032L
WE05DUCSBV        5        6        0.5        4        10        0.5        18        50        DFN06032L
WS05DTSB        5        6        0.6        4        8        0.5        15        30        DFN06032L
WS18DTSB        18        18.5        0.5        /        /        0.45        15        30        DFN06032L
WE05DLCSB        5        5.5        2.5        2        13        0.58        18        30        DFN06032L
WE05DGCFB        5        5.6        0.15        3        20        2        15        60        DFN10062L
WE05DRFB        5        6        0.3        4        15        0.95        20        80        DFN10062L
WE08DRFB        8        8.5        0.45        2.7        28        0.95        12        70        DFN10062L
WE12DRFB        12        13.3        0.6        4        35        0.95        10        150        DFN10062L
WE15DRFB        15        16.7        0.45        3        34        0.95        12        150        DFN10062L
WE05DUCFB        5        6        0.5        3        20        1        10        60        DFN10062L
WE05DUCFBF        5        6        0.4        3        13        0.5        30        40        DFN10062L
WE05DUCFBV        5        6        0.5        4        10        0.5        18        50        DFN10062L
WE05DUCF        5        6        0.5        4        15        0.56        20        60        DFN10062L
WE05DUCFC        5        5.6        0.7        3.5        11        0.32        30        40        DFN10062L
WS05DTFB        5        6        0.6        4        8        0.5        15        30        DFN10062L
WS18DTFB        18        18.5        0.5        /        /        0.45        15        30        DFN10062L
WE05DLCFB        5        5.6        2.5        2        13        0.58        15        50        DFN10062L
WE12DLCFB        12        13.3        1.25        3        28        1        15        100        DFN10062L
WE05MUC        5        6        0.5        4        12        0.56        30        50        DFN10063L
WE05D5UCB        5        6        0.5        /        /        0.9        10        50        SOD523
WE05D5UC        5        6        0.5        5        13.6        0.77        12        100        SOD523
WE05D5LCB        5        6        2.5        2        13        0.6        20        40        SOD523
WS03DLCB        3.3        4        1        20        19        0.3        30        350        SOD323
WS03DLCXB        3        4        1.5        13        25        0.7        30        260        SOD323
WS05DLCB        5        6        1        17        18.3        0.4        30        350        SOD323
WS08DLCB        8        8.5        1        20        26.8        0.4        30        500        SOD323
WS12DLCB        12        13.3        1        11        28.6        0.6        30        350        SOD323
WS15DLCB        15        16.7        1        10        40        0.6        30        500        SOD323
WS24DLCB        24        26.7        1        9        54        0.6        30        500        SOD323
WE05R        5        6        0.8        6.5        17.6        0.62        12        100        SOT143
WS05RXLC        5        6        2.5        13        15        0.5        30        300        SOT143
WE05M2UC        5        6        0.6        5        15        0.8        12        100        SOT23
WE054RVLC        5        6        1        4        15        0.7        12        60        SOT236
WE054RVLCH        5        6        1.5        7        17.5        0.58        20        120        SOT236
WS054R        5        6        1.5        15        23        0.35        30        350        SOT236
WS054RUL        5        6        3        24        18        0.25        30        500        SOT236
WS054R5S        5        6        4.5        35        25        0.2        30        900        SOT236
WS034R2S        3.3        3.7        1.5        14        16        0.28        30        250        SOT236
WE055RV        5        6        1.5        3        25        /        8        80        SOT236
WE05M5LC        5        6        1        /         /        /        22        100        SOT523
WE054RT3        5        6        0.6        6        18        0.65        25        120        SOT363
WS2.84LVUB        2.8        3        1.6        22        28        0.6        30        620        SOP8
WE3.34R2P        3.3        3.7        0.6        5        12        0.4        25        80        DFN20105L
WS052R2P        5        5.6        0.6        5        15        0.8        30        100        DFN16106L
WE3.34R2T        3.3        3.7        0.8        4.5        12        0.45        12        50        DFN17106L
WS2.54R1P        2.5        3        1.3        5        13        0.6        30        100        DFN20108L
WE3.38R2P        3.3        3.7        0.6        6        18        0.33        20        100        DFN38109L
WS054R2P        5        6        0.6        5        15        0.5        22        100        DFN251010L
WS3.34R1N        3.3        3.5        3.8        25        18        0.28        30        450        DFN262610L
WS2.54R7N        2.5        2.7        3.8        40        20        0.37        30        1000        DFN302010L
WS3.34R7N        3.3        3.5        3.5        30        18        /        30        600        DFN302010L
WE054R1M        5        6        0.5        4        13        0.43        30        50        DFN13085L
WE0514R2P        5        6        0.6        5        15        /        8        100        DFN551518L
WE03DSB        3.3        3.7        8.5        7        10        0.3        30        100        DFN06032L
WE05DSBA        5        6        8        5        15        0.3        30        90        DFN06032L
WE12DSB        12        13.4        5        5.5        26        0.95        30        150        DFN06032L
WE05DLVFB        5        5.8        7        4        11        0.25        20        50        DFN10062L
WE3.3DFB        3.3        3.7        10        7        11        0.28        30        100        DFN10062L
WE05DFBN        5        6        7        5        15        0.42        30        100        DFN10062L
WE12DFB        12        13.3        11        5        26        0.56        30        150        DFN10062L
WS03DPFB        3.3        4        60        30        15        0.15        30        450        DFN10062L
WS03DPFBA        3.3        4        50        35        11.8        0.15        30        400        DFN10062L
WS4.5DPFB        4.5        4.7        65        30        14        0.16        30        450        DFN10062L
WS05DPFB        5        6        40        20        15        0.2        30        300        DFN10062L
WS07DF        7        8        160        30        18        0.15        30        540        DFN10062L
WS12DF        12        13.3        100        16        29        0.17        30        500        DFN10062L
WE05MFB        5        5.6        7        5        15        0.3        30        90        DFN10063L
WE05D9B        5        6        7        4        13        0.25        30        60        SOD923
WE05D5LVB        5        5.8        5.5        4        11        0.24        20        50        SOD523
WE05D5BCB        5        5.6        11        5        15        0.35        30        100        SOD523
WE05D5BC        5        6        90        14        17        0.36        30        250        SOD523
WE03D5B        3.3        3.7        15        7        16.8        0.32        30        120        SOD523
WS05D5B        5        6        40        20        15        0.15        30        300        SOD523
WS03D5        3.3        4        110        15        17        0.2        15        250        SOD523
WS05D5        5        6        80        12        17        0.45        30        200        SOD523
WE12D5        12        13.3        40        6        31        0.5        30        200        SOD523
WE24D5        24        26.7        45        9        52        0.34        30        500        SOD523
WE36D5        36        40        25        6        100        /        8        600        SOD523
WS03DB        3.3        4        37        30        15        0.3        30        450        SOD323
WS05DB        5        6        30        22        20        0.2        30        450        SOD323
WS12DB        12        13.3        25        12        35        0.42        30        500        SOD323
WS15DB        15        16.7        25        10        33        0.35        30        350        SOD323
WS24DB        24        26.7        7        8        50        0.5        12        500        SOD323
WS36DB        36        40        15        5        105        /        15        540        SOD323
WS03D        3.3        4        40        27        12        0.2        30        500        SOD323
WS15D        15        16.7        70        12        40        0.24        30        500        SOD323
WS24D        24        26.7        45        9        51        0.34        30        580        SOD323
WS36D        36        40        25        6        105        /        15        540        SOD323
WS05DLV        5        6        210        28        17        0.2        30        500        SOD323
WS12DLV        12        13.3        140        15        25        0.2        30        380        SOD323
WS03M2TB        3.3        4        100        25        15        0.2        30        350SOT23
WS05M2TB        5        6        75        20        25        0.16        30        350SOT23
WS12M2TB        12        13.3        30        12        30        0.26        30        350SOT23
WS15M2TB        15        16.7        25        10        35        0.34        30        350SOT23
WS24M2TB        24        26.7        15        6        55        0.42        30        350SOT23
WS36M2TB        36        40        15        6        95        /        30        350SOT23
WS03M2T        3.3        4        200        25        15        0.12        30        350        SOT23
WS05M2T        5        6        150        20        25        0.49        30        350        SOT23
WS12M2T        12        13.3        50        12        30        0.5        30        350        SOT23
WS15M2T        15        16.7        45        10        35        0.42        30        350        SOT23
WS24M2T        24        26.7        30        6        55        0.34        30        350        SOT23
WS36M2T        36        40        25        6        95        /        30        350        SOT23
WS05MS        5        6        150        24        15        0.33        30        350        SOT236
WS05MSC        5        6        90        14        17        0.28        30        250        SOT236
WS03MFCB        3.3        3.7        15        15        12        0.2        30        200SOT563
WE05MF        5        6        6.5        2        15        /        15        30        SOT553
WS05MF        5        6        90        14        17        0.28        30        250        SOT353
WE3.3DFB        3.3        3.7        10        7        11        0.28        30        100DFN10062L
WS03DPFB        3.3        4        60        30        15        0.15        30        450DFN10062L
WS03DPFBA        3.3        4        50        35        11.8        0.15        30        400DFN10062L
WS4.5DPFB        4.5        4.7        65        30        14        0.16        30        450DFN10062L
WS03DLCB        3.3        4        1        20        19        0.3        30        350SOD323
WS03DLCXB        3        4        1.5        13        25        0.7        30        260SOD323
WS034R2S        3.3        3.7        1.5        14        16        0.28        30        250SOT236
WS2.84LVUB        2.8        3        1.6        22        28        0.6        30        620SOP8
WS3.32PLC        3.3        3.7        10        100        20        0.15        30        1800SOP8
WS18P4N3        18        20        650        80        40        0.04        30        3200        DFN20203L
WS22P4N3        22        24        545        60        52        0.07        30        3200        DFN20203L
长园维安深圳代理店CYG WAY-ON深圳代理店
光与电子(香港)有限公司深圳办事处
电话0755-82574660 82542001
Part Number Reverse Stand off Voltage VRWM (Volts) Breakdown Voltage VBR(Volts)@IT Test Current IT (mA) Maximum Clamping Voltage Vc@IPP (Volts) Maximum Peak Pulse Current IPP (Amps) Maximum Reverse Leakage IR@VRWM UNI (μA) -POLAR BI-POLAR MIN MAX 5.0SMDJ15AL 5.0SMDJ15CAL 15 16.7 18.5 1 24.4 205.0 100 5.0SMDJ16AL 5.0SMDJ16CAL 16 17.8 19.7 1 26.0 193.0 50 5.0SMDJ17AL 5.0SMDJ17CAL 17 18.9 20.9 1 27.6 181.0 20 5.0SMDJ18AL 5.0SMDJ18CAL 18 20.0 22.1 1 29.2 172.0 10 5.0SMDJ20AL 5.0SMDJ20CAL 20 22.2 24.5 1 32.4 155.0 5 5.0SMDJ22AL 5.0SMDJ22CAL 22 24.4 26.9 1 35.5 141.0 5 5.0SMDJ24AL 5.0SMDJ24CAL 24 26.7 29.5 1 38.9 129.0 5 5.0SMDJ26AL 5.0SMDJ26CAL 26 28.9 31.9 1 42.1 119.0 5 5.0SMDJ28AL 5.0SMDJ28CAL 28 31.1 34.4 1 45.4 110.0 5 5.0SMDJ30AL 5.0SMDJ30CAL 30 33.3 36.8 1 48.4 103.0 5 5.0SMDJ33AL 5.0SMDJ33CAL 33 36.7 40.6 1 53.3 93.9 5 5.0SMDJ36AL 5.0SMDJ36CAL 36 40.0 44.2 1 58.1 86.1 5 5.0SMDJ40AL 5.0SMDJ40CAL 40 44.4 49.1 1 64.5 77.6 5 5.0SMDJ43AL 5.0SMDJ43CAL 43 47.8 52.8 1 69.4 72.1 5 5.0SMDJ45AL 5.0SMDJ45CAL 45 50.0 55.3 1 72.7 68.8 5 5.0SMDJ48AL 5.0SMDJ48CAL 48 53.3 58.9 1 77.4 64.7 5 5.0SMDJ51AL 5.0SMDJ51CAL 51 56.7 62.7 1 82.4 60.7 5 5.0SMDJ54AL 5.0SMDJ54CAL 54 60.0 66.3 1 87.1 57.5 5 5.0SMDJ58AL 5.0SMDJ58CAL 58 64.4 71.2 1 93.6 53.5 5
WEP240LC0402 WEP120LC0402 WEP060LC0402 WEP050LC0402 WEP140UC0402 WEP120UC0402 WEP060UC0402
WEP240RF0402 WEP180RF0402 WEP140RF0402 WEP120RF0402 WEP060RF0402
WEP050HF0603 WEP120HF0603 WEP240LC0603 WEP060LC0603 WEP240RF0603 WEP140RF0603  20D180K
20D182K 20D152K 20D112K 20D102K 20D911K 20D821k 20D781K 20D751K 20D681K 20D621K 20D561K
20D511K20D471K 20D431K 20D391K 20D361K 20D331K 20D301K 20D271K 20D241K 20D221K 20D201K
20D181K 20D151K20D121K 20D101K 20D820K 20D680K 20D560K 20D470K 20D390K 20D330K 20D270K
20D220K 20D121K 20D101K 20D820K 20D680K 20D560K 20D470K 20D390K 20D330K 20D270K 20D220K
WSP380A1812 WSP380A1206 WSP380A0805 WSP300A0805 WSP260A0805 WSP220A0805 WSP180A0805
WSP140A0805 WSP090A0805 WSP5V5A0805 WSP300A0603 WSP220A0603WSP180A0603 WSP140A0603
WSP090A0603 WSP5V5A0603 WSP180A0402 WSP140A0402 WSP090A0402 WSP5V5A0402LV WSP5V5A0402
WSPT4R2141N WSPT4R2181N WSPT4R2201M WSPT4R2301M WSPT4R2401M WSPT4R2501M WSPT4R2601M
WSPT5R2S141N WSPT5R2S201M WSPT5R2S301M WSPT5R2S401M WSPT5R2S501M WSPT4R2102M WSPT4R2152M
0603WCS500A032V 0603WCS400A032V 0603WCS300A032V 0603WCS200A032V 0603WCS100A032V
1206WCS800A024V 1206WCS700A024V 1206WCS600A024V 1206WCS500A032V 1206WCS400A032V 1206WCS300A032V
1206WCS250A032V 1206WCS200A063V 1206WCS150A063V 1206WCS100A063V 1206WCS075A063V 1206WCS050A063V
0603WCF600A024V 0603WCF500A032V 0603WCF400A032V 0603WCF300A032V 0603WCF200A032V 0603WCF100A032V
1206WCF800A024V 1206WCF700A024V 1206WCF600A024V 1206WCF500A032V 1206WCF400A032V 1206WCF300A032V
1206WCF250A032V 1206WCF200A063V 1206WCF150A063V 1206WCF100A063V 1206WCF075A063V 1206WCF050A063V
SAA1508 LAG1508 LAF1508 LAE1508 LAD1508 LAC1508 LAB1508 LAA1508 LAA1308
LPUSML750 LPUSML700 LPUSML650 LPUSML600 LPUSML550 LPUSML500 LPUSML450/12 LPUSML450 LPUSML400/12 LPUSML400 LPUSML380/12 LPUSML380
LPUSML350/12 LPUSML350 LPUSML300/12 LPUSML300 LPUSML260/12 LPUSML260 LPUSML250 LPUSML230 LPUSML210 LPUSML200/12 LPUSML200
LPUSML175/12 LPUSML175 LPUSM175 LPUSML150 LPUSM150 LPUSM110 LPUSM075 LPUSM050 LPUSM035 LPUSM020 LPUSM010 LPUSM005 LPNSM175/8
LPTSML300 LPTSML260 LPTSML250 LPTSML200 LPTSML175 LPTSML150 LPTSML125 LPTSML100/8 LPTSML100 LPTSML075/8 LPTSML075 LPTSML050/8
LPTSML050 LPTSML035 LPTSM020 LPTSM016 LPTSM010 LPTSM005 LPTSM004LPSM250 LPSM200 LPSM185 LPSM150 LPSM130 LPSML650 LPSML600 LPSML550
LPNSML175/12LPNSML175LPUSML190LPNSML450/12 LPNSML450 LPNSML400/12 LPNSML400 LPNSML380/12LPSM110 LPSM075 LPSM050 LPSM030LPNSML700
LPNSML650 LPNSML600 LPNSML550 LPNSML500 LPSM075CLPSM050C LPSM030C LPSM300 LPSM260 LPSM125 LPISML200 LPISML175/12 LPISML175
LPSM300C/16 LPSM300CLPSM260C/24 LPSM260C LPSM250C LPSM200C/24 LPSM200C LPSM185C/33 LPSM185C LPSM150C LPSM130C LPSM125C LPSM110C
LPNSML380 LPNSML350/12LPNSML350 LPNSML300/12 LPNSML300 LPNSML260/12 LPNSML260 LPNSML200/12 LPNSML200/8 LPNSML200 LPNSM200/8
LPNSML150/12 LPNSML150/8 LPNSML150 LPNSM150/8 LPNSM150 LPNSM125/8 LPNSML110/8 LPNSM110/8 LPNSM110 LPNSM100/8 LPNSM090/8 LPNSM075/16LPNSM075/8 LPNSM075 LPNSM050/24 LPNSM050/16 LPNSM050 LPNSM035/24 LPNSM035/16 LPNSM035 LPNSM025/24 LPNSM025/16 LPNSM020/24 LPNSM020LPNSM016 LPNSM012 LPNSM005LPMSML900 LPMSML850 LPMSML800 LPMSML750 LPMSML700 LPMSML650 LPMSML600/12 LPMSML600 LPMSML550/12 LPMSML550 LPMSML500/12 LPMSML500LPMSML450/12 LPMSML450 LPMSML400/12 LPMSML400 LPMSML350/12 LPMSML350LPMSM150/8
LPMSM260/16 LPMSM260/8 LPMSM260 LPMSML250/12 LPMSML250 LPMSM200/16LPMSM150 LPMSM125/24 LPMSM125/16 LPMSM125/8 LPMSM125 LPMSM110/24 LPMSM110/16 LPMSM110/8 LPMSM075 LPMSM050/24LPMSM200/8 LPMSM200 LPMSML190/12 LPMSML190 LPMSM175/16 LPMSM175/8 LPSML500 LPSM400C/16LPMSM110 LPMSM075/24
LPMSM050 LPMSM020 LPMSM014 LPISML450 LPISML400 LPISML380 LPISML350 LPISML300 LPISML260/12 LPISML260 LPISML200/12 LPISM010 LPMSM150/16 LPISML160LPISM035LPISM020
LPISML150/12 LPISML150 LPISML125/12 LPISML125 LPISML110/12 LPISML110 LPISML075/12 LPISML075 LPISM110 LPISM075 LPISM050 LPISM005LPMSM160/16 LPMSM160/8 LPMSM160 LPMSM150/24
LV230 LV175TF LV175NUF LV175NLUF LV175ALF LV175 LV170LR270SUF LR270 LR220 LR210 LR175DTSUF LR175SUFLPCW250SUF LPCW240SUF LPCW240 LPCW210 LPCW200 LPCW175SNDUF LPCW175SNUF LPCW175 LPCW170TUF LPCW170 LPCW145SLUF LPCW145UFLPCW110SLUF LPCW110LP340 LP300 LP260 LP190 LP180 LP100 LP070 LP1410 LP1300 LP900 LP880 LP730LP600 LP550 LP450 LP420 LP380 LP350 LP260 LP200 LP190N LP175 LP170 LP120LPD37 LPD35 LPD34 LPD33 LPD21 LPD20 LPD19 LPD18 LPD16 LPD15 LPD14 LPD12LPD11 LPD10 LPD9 LPD8 LPD7 LPD5 LPD4 LPD3
LPD2 LPD1LTH 1000 LTH 900 LTH 800 LTH 700 LTH 650 LTH 600 LTH 550 LTH 500 LTH 450 LTH 420 LTH 400 LTH 350LTH 300 LTH 250LN500 LN450 LN400 LN370 LN350 LN310 LN300 LN270 LN250 LN210 LN190 LN170LN140 LN110LP60030F LP60025F LP60020F LP60017F LP60010F LP60005FLP33120F LP33110F LP33090FLP75020SFLPH200F LPH100F LPH070F LPH050FLP06120F LP06110F LP06090F LP06075F
LPH1500F LPH1400F LPH1300F LPH1100F LPH1000F LPH900F LPH800F LPH750F LPH700F LPH650F LPH600F LPH550FLPH450F LPH400F LPH300F
LP75375F LP75300F LP75250F LP75185F LP75160F LP75135F LP75110F LP75090F LP75075F LP75065F LP75050F LP75040SFLP75030SF LP75025SF
LP60375F LP60300F LP60250F LP60185F LP60160F LP60135F LP60110F LP60090F LP60075F LP60065F LP60050F LP60040F
LP33900F LP33800F LP33700F LP33600F LP33500F LP33400F LP33300F LP33250F LP33190F LP33185F LP33160F LP33135FLP30090F
LP30900F LP30800F LP30700F LP30600F LP30500F LP30400F LP30300F LP30250F LP30185F LP30160SF LP30135F LP30110F
LP16075F LP161400F LP161200F LP161100F LP161000F LP16900F LP16800F LP16700F LP16600F LP16500F LP16400F LP16300F
LP16250F LP16200F LP16185F LP16160F LP16135F LP16120F LP16110F LP16090FLP06250F LP06185F LP06160F LP06135F
LM130 LM080LBV160F LBV150FLBR200F LBR900F LBR750F LBR550F LBR350F LBR250FLB080LVF LB050LVFLB120LVFLB050F LB180UF LB180F
LBN 3750F LBN 3000F LBN 2500F LBN 2000F LBN 1850F LBN 1600F LBN 1350F LBN 1250F LBN 1100F LBN 900F LBN 800F LBN 750F
LBN 650F LBN 550F LBN 500F LBN 400F LBN 350F LBN 330F LBN 300F LBN 250F LBN 200F LBN 160F LBN 150F LBN 120FLB145UF LB145F
LBN 100F LBN 080F LBN 050FLB2000LVF LB1250LVF LB1000LVF LB800LVF LB750LVF LB600LVF LB550LVF LB400LVF LB330LVF LB250LVF LB160LVF LB120UF LB120F LB110UF LB110F LB080UF LB080F LB030FWT1102ME WT1062ME WT0922ME WT1022ME WT1102ME WT1062ME WT0922ME WT1022MEWT0982ME
GDTN2RD8B3000 GDTN2RD8B2500 GDTN2RD8B1000 GDTN2RD8B800 GDTN2RD8B600 GDTN2RD8B470 GDTN2RS51000 GDTN2RS5800 GDTN2RS5600 GDTN2RS5470 GDTN2RS5420 GDTN2RS5300 GDTN2RS5230 GDTN2RS5200 GDTN2RS5150 GDTN2RS590 GDTN2RS575 GDTN3RD5470 GDTN3RD5420 GDTN3RD5400 GDTN3RD5400LV GDTN3RD5350 GDTN3RD5300GDTN3RD5230 GDTN3RD5150 GDTN3RD590 GDTN3RD575 GDTN2RS3B400LV GDTN2RS3B400+ GDTN2RS3B400 GDTN2RS3B350 GDTN2RS3B230 GDTN2RS3B200 GDTN2RS3B150 GDTN2RS3B90GDTN2RS3B75 GDTN2RS3800 GDTN2RS3600 GDTN2RS3470 GDTN2RS3420 GDTN2RS3400+ GDTN2RS3400 GDTN2RS3300H GDTN2RS3300 GDTN2RS3200H GDTN2RS3200 GDTN2RS3150HGDTN2RS3150 GDTN2RS390H GDTN2RS390 GDTN2RS375H GDTN2RS375 GDTN2RD81000 GDTN2RD8800 GDTN2RD8600 GDTN2RD8470 GDTN2RD8350 GDTN2RD8230 GDTN2RD8150GDTN2RD890 GDTN2RD875 GDTN2RD5A350 GDTN2RD5A230 GDTN2RD5A150 GDTN2RD890 GDTN2RD875 GDTN2RD5A350 GDTN2RD5A230 GDTN2RD5A150 GDTN2RD5A90GDTN2RD890 GDTN2RD875 GDTN2RD5A350 GDTN2RD5A230 GDTN2RD5A150 GDTN2RD5A90 GDTN2RD5A75GDTA2RD5A75 GDTR3RD8600 GDTR3RD8420 GDTR3RD8350 GDTR3RD8230 GDTR3RD890 GDTR3RD875 GDTR3RD7600 GDTR3RD7470 GDTR3RD7350 GDTR3RD7230 GDTR3RD7150GDTR3RD790 GDTR3RD775 GDTRF3RD6420 GDTRF3RD6350 GDTRF3RD6230 GDTRF3RD6150 GDTRF3RD690 GDTRF3RD675 GDTR3RD6420 GDTR3RD6350 GDTR3RD6260 GDTR3RD6230GDTR3RD6150 GDTR3RD690 GDTR3RD675 GDTR3RD5420 GDTR3RD5350 GDTR3RD5230 GDTR3RD5150 GDTR3RD590 GDTR3RD575 GDTA2RD5B600 GDTA2RD5B470 GDTA2RD5B420GDTA2RD5B350 GDTA2RD5B300 GDTA2RD5B230 GDTA2RD5B150 GDTA2RD5B90 GDTA2RD5B75 GDTA2RD5A600 GDTA2RD5A470 GDTA2RD5A350 GDTA2RD5A230 GDTA2RD5A150 GDTA2RD5A90GDTA2RD5230 GDTA2RD5150 GDTA2RD590 GDTA2RD575 GDTA2RD8800N GDTA2RD8600N GDTA2RD8470N GDTA2RD8350N GDTA2RD8230N GDTA2RD8150N GDTA2RD890N GDTA2RD875NGDTA2RD8B600 GDTA2RD8B47GDTA2RD8800 GDTA2RD8600 GDTA2RD8470 GDTA2RD8350 GDTA2RD8230 GDTA2RD8150 GDTA2RD890 GDTA2RD875 GDTA2RD8B3000 GDTA2RD8B2500 GDTA2RD8B1000 GDTA2RD8B800
一级代理陆海一级代理陆海代理一级代理pptc168一级代理pptc168代理一级代理Sea & Land一级代理Sea & Land代理
一级代理SeaLand一级代理SeaLand代理
23
14
发表于 2018-12-12 15:11:14 | 显示全部楼层
Super Junction MOSFET 650V
Part Number        Description        Package        VDS(V)
RDS(on) (Ω)
@VGS=10V(max.)
ID (A)
@TA=25℃
PD (W)
@TA=25℃
Qg (nC)        VGS (V)
VGS(th)
(V) (Typ.)
Product Status        Data sheet
WMJ80N65C2        N-Channel SJ-MOS C2        TO-247        650        0.04        80        480        260        30        3        ENG
WMJ53N65C2        N-Channel SJ-MOS C2        TO-247        650        0.07        53        378        88.5        30        3        MP
WML53N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.07        53        34        88.5        30        3        MP
WMJ38N65C2        N-Channel SJ-MOS C2        TO-247        650        0.099        38        277        60        30        3        MP
WMK38N65C2        N-Channel SJ-MOS C2        TO-220        650        0.099        38        277        60        30        3        MP
WML38N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.099        38        34        60        30        3        MP
WMM38N65C2        N-Channel SJ-MOS C2        TO-263        650        0.099        38        277        60        30        3        MP
WMN38N65C2        N-Channel SJ-MOS C2        TO-262        650        0.099        38        277        60        30        3        MP
WMJ26N65C2        N-Channel SJ-MOS C2        TO-247        650        0.19        20        147        34.5        30        3.3        MP
WMK26N65C2        N-Channel SJ-MOS C2        TO-220        650        0.19        20        147        34.5        30        3.3        MP
WML26N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.19        20        34        34.5        30        3.3        MP
WMM26N65C2        N-Channel SJ-MOS C2        TO-263        650        0.19        20        147        34.5        30        3.3        MP
WMN26N65C2        N-Channel SJ-MOS C2        TO-262        650        0.19        20        147        34.5        30        3.3        MP
WMK20N65C2        N-Channel SJ-MOS C2        TO-220        650        0.3        15        86        20.3        30        3.3        MP
WML20N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.3        15        31        20.3        30        3.3        MP
WMM20N65C2        N-Channel SJ-MOS C2        TO-263        650        0.3        15        86        20.3        30        3.3        MP
WMN20N65C2        N-Channel SJ-MOS C2        TO-262        650        0.3        15        86        20.3        30        3.3        MP
WMO20N65C2        N-Channel SJ-MOS C2        TO-252        650        0.3        15        86        20.3        30        3.3        MP
WMP20N65C2        N-Channel SJ-MOS C2        TO-251        650        0.3        15        86        20.3        30        3.3        MP
WMK16N65C2        N-Channel SJ-MOS C2        TO-220        650        0.32        13        86        19.9        30        3.3        MP
WML16N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.32        13        31        19.9        30        3.3        MP
WMM16N65C2        N-Channel SJ-MOS C2        TO-263        650        0.32        13        86        19.9        30        3.3        MP
WMN16N65C2        N-Channel SJ-MOS C2        TO-262        650        0.32        13        86        19.9        30        3.3        MP
WMO16N65C2        N-Channel SJ-MOS C2        TO-252        650        0.32        13        86        19.9        30        3.3        MP
WMP16N65C2        N-Channel SJ-MOS C2        TO-251        650        0.32        13        86        19.9        30        3.3        MP
WMK14N65C2        N-Channel SJ-MOS C2        TO-220        650        0.405        11        85        18.7        30        3.3        MP
WML14N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.405        11        31        18.7        30        3.3        MP
WMM14N65C2        N-Channel SJ-MOS C2        TO-263        650        0.405        11        85        18.7        30        3.3        MP
WMN14N65C2        N-Channel SJ-MOS C2        TO-262        650        0.405        11        85        18.7        30        3.3        MP
WMO14N65C2        N-Channel SJ-MOS C2        TO-252        650        0.405        11        85        18.7        30        3.3        MP
WMP14N65C2        N-Channel SJ-MOS C2        TO-251        650        0.405        11        85        18.7        30        3.3        MP
WMK11N65C2        N-Channel SJ-MOS C2        TO-220        650        0.54        9        63        13.7        30        3.3        MP
WML11N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.54        9        28        13.7        30        3.3        MP
WMM11N65C2        N-Channel SJ-MOS C2        TO-263        650        0.54        9        63        13.7        30        3.3        MP
WMN11N65C2        N-Channel SJ-MOS C2        TO-262        650        0.54        9        63        13.7        30        3.3        MP
WMO11N65C2        N-Channel SJ-MOS C2        TO-252        650        0.54        9        63        13.7        30        3.3        MP
WMP11N65C2        N-Channel SJ-MOS C2        TO-251        650        0.54        9        63        13.7        30        3.3        MP
WMK10N65C2        N-Channel SJ-MOS C2        TO-220        650        0.69        8        57        13.6        30        3.3        MP
WML10N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.69        8        27        13.6        30        3.3        MP
WMM10N65C2        N-Channel SJ-MOS C2        TO-263        650        0.69        8        57        13.6        30        3.3        MP
WMN10N65C2        N-Channel SJ-MOS C2        TO-262        650        0.69        8        57        13.6        30        3.3        MP
WMO10N65C2        N-Channel SJ-MOS C2        TO-252        650        0.69        8        57        13.6        30        3.3        MP
WMP10N65C2        N-Channel SJ-MOS C2        TO-251        650        0.69        8        57        13.6        30        3.3        MP
WML09N65C2        N-Channel SJ-MOS C2        TO-220F        650        0.94        6        26        6.8        30        3.3        MP
WMM09N65C2        N-Channel SJ-MOS C2        TO-263        650        0.94        6        45        6.8        30        3.3        MP
WMO09N65C2        N-Channel SJ-MOS C2        TO-252        650        0.94        6        45        6.8        30        3.3        MP
WMP09N65C2        N-Channel SJ-MOS C2        TO-251        650        0.94        6        45        6.8        30        3.3        MP
WMG09N65C2        N-Channel SJ-MOS C2        TO-251S3        650        0.94        6        45        6.8        30        3.3        MP
WMH09N65C2        N-Channel SJ-MOS C2        TO-251S2        650        0.94        6        45        6.8        30        3.3        MP
WMK09N65C2        N-Channel SJ-MOS C2        TO-220        650        0.94        6        45        6.8        30        3.3        MP
WMN09N65C2        N-Channel SJ-MOS C2        TO-262        650        0.94        6        45        6.8        30        3.3        MP
WMF09N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        0.98        6        6        6.8        30        3.3        MP
WML07N65C2        N-Channel SJ-MOS C2        TO-220F        650        1.14        5        23        5.8        30        3.3        MP
WMM07N65C2        N-Channel SJ-MOS C2        TO-263        650        1.14        5        42        5.8        30        3.3        MP
WMO07N65C2        N-Channel SJ-MOS C2        TO-252        650        1.14        5        42        5.8        30        3.3        MP
WMP07N65C2        N-Channel SJ-MOS C2        TO-251        650        1.14        5        42        5.8        30        3.3        MP
WMG07N65C2        N-Channel SJ-MOS C2        TO-251S3        650        1.14        5        42        5.8        30        3.3        MP
WMH07N65C2        N-Channel SJ-MOS C2        TO-251S2        650        1.14        5        42        5.8        30        3.3        MP
WMK07N65C2        N-Channel SJ-MOS C2        TO-220        650        1.14        5        42        5.8        30        3.3        MP
WMN07N65C2        N-Channel SJ-MOS C2        TO-262        650        1.14        5        42        5.8        30        3.3        MP
WMF07N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        1.2        5        5        5.8        30        3.3        MP
WMO04N65C2        N-Channel SJ-MOS C2        TO-252        650        1.9        3        29        6.7        30        3.3        MP
WMP04N65C2        N-Channel SJ-MOS C2        TO-251        650        1.9        3        29        6.7        30        3.3        MP
WMG04N65C2        N-Channel SJ-MOS C2        TO-251S3        650        1.9        3        29        6.7        30        3.3        MP
WMH04N65C2        N-Channel SJ-MOS C2        TO-251S2        650        1.9        3        29        6.7        30        3.3        MP
WML04N65C2        N-Channel SJ-MOS C2        TO-220F        650        1.9        3        20        6.7        30        3.3        MP
WMK04N65C2        N-Channel SJ-MOS C2        TO-220        650        1.9        3        29        6.7        30        3.3        MP
WMM04N65C2        N-Channel SJ-MOS C2        TO-263        650        1.9        3        29        6.7        30        3.3        MP
WMN04N65C2        N-Channel SJ-MOS C2        TO-262        650        1.9        3        29        6.7        30        3.3        MP
WMF04N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        2        3        4.6        6.7        30        3.3        MP
WMK15N65VD        N-Channel SJ-MOS VD        TO-220        650        0.53        10.5        63        13.7        30        3.3        MP
WML15N65VD        N-Channel SJ-MOS VD        TO-220F        650        0.53        10.5        28        13.7        30        3.3        MP
WMM15N65VD        N-Channel SJ-MOS VD        TO-263        650        0.53        10.5        63        13.7        30        3.3        MP
WMN15N65VD        N-Channel SJ-MOS VD        TO-262        650        0.53        10.5        63        13.7        30        3.3        MP
WMO15N65VD        N-Channel SJ-MOS VD        TO-252        650        0.53        10.5        63        13.7        30        3.3        MP
WMP15N65VD        N-Channel SJ-MOS VD        TO-251        650        0.53        10.5        63        13.7        30        3.3        MP
WMK12N65VD        N-Channel SJ-MOS VD        TO-220        650        0.69        10        57        13.6        30        3.3        MP
WML12N65VD        N-Channel SJ-MOS VD        TO-220F        650        0.69        10        27        13.6        30        3.3        MP
WMM12N65VD        N-Channel SJ-MOS VD        TO-263        650        0.69        10        57        13.6        30        3.3        MP
WMN12N65VD        N-Channel SJ-MOS VD        TO-262        650        0.69        10        57        13.6        30        3.3        MP
WMO12N65VD        N-Channel SJ-MOS VD        TO-252        650        0.69        10        57        13.6        30        3.3        MP
WMP12N65VD        N-Channel SJ-MOS VD        TO-251        650        0.69        10        57        13.6        30        3.3        MP
WML10N65VD        N-Channel SJ-MOS VD        TO-220F        650        0.92        8        26        6.8        30        3.3        MP
WMM10N65VD        N-Channel SJ-MOS VD        TO-263        650        0.92        8        45        6.8        30        3.3        MP
WMO10N65VD        N-Channel SJ-MOS VD        TO-252        650        0.92        8        45        6.8        30        3.3        MP
WMP10N65VD        N-Channel SJ-MOS VD        TO-251        650        0.92        8        45        6.8        30        3.3        MP
WMG10N65VD        N-Channel SJ-MOS VD        TO-251S3        650        0.92        8        45        6.8        30        3.3        MP
WMH10N65VD        N-Channel SJ-MOS VD        TO-251S2        650        0.92        8        45        6.8        30        3.3        MP
WMK10N65VD        N-Channel SJ-MOS VD        TO-220        650        0.92        8        45        6.8        30        3.3        MP
WMN10N65VD        N-Channel SJ-MOS VD        TO-262        650        0.92        8        45        6.8        30        3.3        MP
WML09N65VD        N-Channel SJ-MOS VD        TO-220F        650        1.13        6.5        23        5.8        30        3.3        MP
WMM09N65VD        N-Channel SJ-MOS VD        TO-263        650        1.13        6.5        42        5.8        30        3.3        MP
WMO09N65VD        N-Channel SJ-MOS VD        TO-252        650        1.13        6.5        42        5.8        30        3.3        MP
WMP09N65VD        N-Channel SJ-MOS VD        TO-251        650        1.13        6.5        42        5.8        30        3.3        MP
WMG09N65VD        N-Channel SJ-MOS VD        TO-251S3        650        1.13        6.5        42        5.8        30        3.3        MP
WMH09N65VD        N-Channel SJ-MOS VD        TO-251S2        650        1.13        6.5        42        5.8        30        3.3        MP
WMK09N65VD        N-Channel SJ-MOS VD        TO-220        650        1.13        6.5        42        5.8        30        3.3        MP
WMN09N65VD        N-Channel SJ-MOS VD        TO-262        650        1.13        6.5        42        5.8        30        3.3        MP
WMO05N65VD        N-Channel SJ-MOS VD        TO-252        650        1.89        4        29        6.7        30        3.3        MP
WMP05N65VD        N-Channel SJ-MOS VD        TO-251        650        1.89        4        29        6.7        30        3.3        MP
WMG05N65VD        N-Channel SJ-MOS VD        TO-251S3        650        1.89        4        29        6.7        30        3.3        MP
WMH05N65VD        N-Channel SJ-MOS VD        TO-251S2        650        1.89        4        29        6.7        30        3.3        MP
WML05N65VD        N-Channel SJ-MOS VD        TO-220F        650        1.89        4        20        6.7        30        3.3        MP
WMF10N65C2        N-Channel SJ-MOS C2        SOT-223-2L        650        0.72        8        57        13.6        30        3.3        MP
23
14
发表于 2018-12-12 15:15:03 | 显示全部楼层
深圳市光与电子有限公司0755-82574660 82542001
PESDNC9D3V3U        3.3        1        5.0~6.0        35        100        SOD-923        ESD9X3.3ST5GPRSB6.8C
PESDNC9D3V3B        3.3        1        5.0~7.0        15        100        SOD-923        ESD9B3.3ST5G
PESDNC9D5VU        5        1        6.2~7.1        30        100        SOD-923        ESD9X5.0ST5GESDALC6V1-1M2P5V0S1UL/PLW0501D
PESDNC9D5VB        5        1        5.8~7.8        15        100        SOD-923        ESD9B5.0ST5GESDALC6V1-1BM2P5V0S1ULCPESD5V0S1BL
PESDNC9D7VU        7        1        7.5~8.5        30        100        SOD-923        ESD9X7.0ST5G
PESDNC9D7VB        7        1        8.0~9.0        15        100        SOD-923
PESDNC9D12VU        12        1        13.5~14.5        25        100        SOD-923        ESD9X12ST5GESDALC12-1T2
PESDNC9D12VB        12        1        13.5~15.0        12        100        SOD-923
PESDNC5D3V3U        3.3        1        5.0~6.0        35        200        SOD-523        ESD5Z3.3T1G
PESDNC5D3V3B        3.3        1        5.0~7.0        15        200        SOD-523
PESDNC5D5VU        5        1        6.2~7.1        60        200        SOD-523        ESD5Z5.0T1G
PESDNC5D5VB        5        1        5.8~7.8        30        200        SOD-523        ESD5B5.0T1GPESD5V0S1BB
PESDNC5D7VU        7        1        7.5~8.5        55        200        SOD-523
PESDNC5D7VB        7        1        8.0~9.0        27        200        SOD-523
PESDNC5D12VU        12        1        13.5~14.5        50        200        SOD-523        ESD5Z12T1G
PESDNC5D12VB        12        1        13.5~15.0        25        200        SOD-523
PESDNC3D5VU        5        1        6.2~7.1        250        350        SOD-323        SD05T1G                PSD05        SD05
PESDNC3D5VB        5        1        5.8~7.8        125        350        SOD-323        PSD05C        SD05CPESD5V0S1BA
PESDNC3D7VU        7        1        7.5~8.5        220        350        SOD-323
PESDNC9D7VB        7        1        8.0~9.0        110        350        SOD-323
PESDNC3D12VU        12        1        13.5~14.5        180        350        SOD-323        SD12T1G        PSD12        SD12
PESDNC3D12VB        12        1        13.5~15.0        90        350        SOD-323        PSD12C        SD12C
PESDNC523T5VU        5        1        6.2~7.1        1.5        150        SOT-523        NZL6V8XV3T31G
PESDNC23T5VU        5        1        6.2~7.1        120        300        SOT-23
PESDNC553T5VU        5        1        6.2~7.1        40        100        SOT-553        NZQA6V8XV5T1G        ESDA6V1P6        MSMF05
PESDNC563T5VU        5        1        6.2~7.1        40        100        SOT-563                ESDA6V1P-5P6        MSMF05C
PESDNC353T5VU        5        1        6.2~7.1        60        100        SOT-353        SMF05C        ESDA6V1W5        PSMF05        SMF05
PESDNC363T5VU        5        1        6.2~7.1        60        100        SOT-363        SMF05        ESDA6V1-5W6        SMF05C        SMF05C
PESDA6V1L        5        1        6.2~7.1        120        300W        SOT-23        DF3A6.8FUT1G/SM05T1G        ESDA6V1LLP05CSM05
PESDUC9D5VU        5        1        5.4~8.5        0.5        100        SOD-923        ESDAXLC6-1MY2
PESDUC9D5VB        5        1        5.4~8.5        0.88        100        SOD-923
PESDLC9D5VU        5        1        5.4~8.5        3        100        SOD-923        ESD9L5VT5GESDAVLC6V1L-1BM2
PESDLC9D5VB        5        1        5.4~8.5        5        100        SOD-923
PTVSLC3D5VU        5        1        5.4~8.5        3        500        SOD-323        SL05T1G        GBLC05
PTVSLC3D5VB        5        1        5.4~8.5        5        500        SOD-323                GBLC05C
PTVSLC3D8VB
PTVSLC3D12VB
PTVSLC3D24VB
PTVSUC3D5VU        5        1        5.4~8.5        0.6        500        SOD-323        GBLC05LC
PTVSUC3D5VB        5        1        5.4~8.5        0.88        500        SOD-323        GBLC05CLC
PTVSLC523T5VU        5        1        5.4~8.5        2        125        SOT-523        NZL6V8AXV3T1GESDALC6V1P3
PTVSLC23T5VU        5        1        5.4~8.5        3        200        SOT-23
PESDLC363T5VU        5        1        6.2~7.1        10        100        SOT-363        ESDALC61-5W6
PESDLC353T5VU        5        1        6.2~7.1        10        100        SOT-353        NSQA6V8AW5T2GESDALC6V1W5
PESDALC363T5VU        5        1        6.2~7.1        3        100        SOT-363        PLR0504FRCLAMP0504F
PESDLC553T5VU        5        1        6.2~7.1        10        100        SOT-553        NZQA6V8AXV5        MSMF05LCESDALC6V1P5
PESDLC563T5VU        5        1        6.2~7.1        10        100        SOT-563        MSMF05LCCESDALC6V1-5P6        ESDALC6V1P6
PESDALC236T5VU        5        1        6.2~7.1        10        200        SOT-23-6LHDMIULC6-4SC6USBLC6-4
PESDALC8P5VU        5        1        6.2~7.1        8        500        SOP-8
SLVU2.8        2.8        1        3.0~4.5        3.5        500        SOT-23                SLVU2.8
SLVU2.8-4        2.8        1        3.0~4.5        3.5        500        SOP-8                SLVU2.8-4
SLVU2.8-8        2.8        1        3.0~4.5        5        500        SOP-8                SLVU2.8-8
SRV05-4        5        1        6.2~7.1        3        300        SOT-23-6L                SRV05-4        SRV05-4
SRDA05-4        5        1        6.2~7.1        3        500        SOP-8        SRDA05-4        PSRDA05-4
PSR05        5        1        6.2~7.1        10        500        SOT-143                PSR05        PSR05
PPMT20V3        SI2301
PNMT20V3        SI2302
PPMT30V3        SI3401
PEMI4402MN        5        1        6.2~7.1        24        DFN-8        EM4D-100L
PEMI6401MN        5        1        6.2~7.1        24        DFN-12        EM6D-100L
PEMI68402MN        5        1        6.2~7.1        24        DFN-16        EM8D-100L
POV3500        POV3500SA        320        240        4        1        SMB        SMTPA320        TISP4400F3        P3500SA        TVB320NSC-L
        POV3500SB        320        240        4        1        SMB        SMP80-320        TISP4400M3BJ        P3500SB        TVB320NSB-L
        POV3500SC        320        240        4        1        SMB        SMP100LC-320        TISP4395H3        P3500SC        TVB320NSA-L
POV3100        POV3100SA        275        350        4        1        SMB        SMTPA270        TISP4389F3        P3100SA        TVB275NSC-L
        POV3100SB        275        350        4        1        SMB        SMP80-270         TISP4350M3BJ        P3100SB        TVB275NSB-L
        POV3100SC        275        350        4        1        SMB        SMP100LC-270         TISP4350H3        P3100SC        TVB275NSA-L
POV2600        POV2600SA        220        300        4        1        SMB        SMTPA220        TISP4300F3        P2600SA        TVB220NSC-L
        POV2600SB        220        300        4        1        SMB        SMP80-220        TISP4300M3BJ        P2600SB        TVB220NSB-L
        POV2600SC        220        300        4        1        SMB        SMP100LC-220         TISP4290H3        P2600SC        TVB220NSA-L
POV2300        POV2300SA        190        260        4        1        SMB        SMTPA200        TISP4260F3        P2300SA        TVB190NSC-L
        POV2300SB        190        260        4        1        SMB        SMP80-200        TISP4265M3BJ        P2300SB        TVB190NSB-L
        POV2300SC        190        260        4        1        SMB        SMP100LC-200         TISP4250H3        P2300SC        TVB190NSA-L
POV1800        POV1800SA        170        220        4        1        SMB        SMTPA180        TISP4220F3        P1800SA        TVB170NSC-L
        POV1800SB        170        220        4        1        SMB        TISP4220M3BJ        P1800SB        TVB170NSB-L
        POV1800SC        170        220        4        1        SMB        SMP100LC-160        TISP4220H3        P1800SC        TVB170NSA-L
POV1500        POV1500SA        140        180        4        1        SMB        SMP50-140        TISP4180F3        P1500SA        TVB140NSC-L
        POV1500SB        140        180        4        1        SMB        TISP4180M3BJ        P1500SB        TVB140NSB-L
        POV1500SC        140        180        4        1        SMB        SMP100LC-140        TISP4180H3        P1500SC        TVB140NSA-L
POV1300        POV1300SA        120        160        4        1        SMB        SMTPA130        TISP4150F3        P1300SA        TVB120NSC-L
        POV1300SB        120        160        4        1        SMB        TISP4145M3BJ        P1300SB        TVB120NSB-L
        POV1300SC        120        160        4        1        SMB        SMP100LC-120        TISP4145H3        P1300SC        TVB120NSA-L
POV1100        POV1100SA        90        130        4        1        SMB        SMTPA100        TISP4125F3        P1100SA        TVB090NSC-L
        POV1100SB        90        130        4        1        SMB        TISP4125M3BJ        P1100SB        TVB090NSB-L
        POV1100SC        90        130        4        1        SMB        SMP100LC-90        TISP4115H3        P1100SC        TVB090NSA-L
POV0900        POV0900SA        75        98        4        1        SMB        TISP4095F3        P0900SA        TVB075NSC-L
        POV0900SB        75        98        4        1        SMB        TISP4095M3BJ        P0900SB        TVB075NSB-L
        POV0900SC        75        98        4        1        SMB        TISP4095H3        P0900SC        TVB075NSA-L
POV0720        POV0720SA        65        88        4        1        SMB        SMTPA68        TISP4082F3        P0720SA        TVB065NSC-L
        POV0720SB        65        88        4        1        SMB        TISP4080M3BJ        P0720SB        TVB065NSB-L
        POV0720SC        65        88        4        1        SMB        SMP100LC-65        TISP4080H3        P0720SC        TVB065NSA-L
POV0640        POV0640SA        58        77        4        1        SMB        SMTPA62        TISP4072F3        P0640SA        TVB058NSC-L
        POV0640SB        58        77        4        1        SMB        TISP4070M3BJ        P0640SB        TVB058NSB-L
        POV0640SC        58        77        4        1        SMB        TISP4070H3        P0640SC        TVB058NSA-L
POV0300        POV0300SA        25        40        4        1        SMB        P0300SA
        POV0300SB        25        40        4        1        SMB        P0300SB
        POV0300SC        25        40        4        1        SMB        SMP100LC-25                P0300SC
POV0080        POV0800SA        6        25        4        1        SMB        P0800SA
        POV0800SB        6        25        4        1        SMB        SMP75-8                P0800SB        TVB006SB-L
        POV0800SC        6        25        4        1        SMB        SMP100LC-8                P0800SC
PDTC143TM        50        50        5        0.5        0.5        4.7        0.3        250
PDTC563-6        -15        -12        -6        -100        -100        6.5        -100        260
PDTC563-6L        -15        -12        -6        -100        -100                -100        260
PDTC143ZM        0.5        1.3        0.1        1.8        0.5        4.7        10        250
PDTC143ZE        0.5        1.3        0.1        1.8        0.5        4.7        10        250
PDTC123JM        0.5        1.1        0.1        3.6        0.5        2.2        21        250
PDTC123JUA        0.5        1.1        0.1        3.6        0.5        2.2        21        250
PDTC563-12        0.5        3        0.1        0.18        0.5        47        1        250
PPV61089A        120        120        30        5        SO-8        LCDP1511D        TISP61089A
PPV61089B        170        170        30        5        SO-8        LCP1251、LCDP1251        TISP61089B
PPV61089M        170        170        55        5        SO-8
PPV61089H        170        170        100        5        DFN-8                TISP61089HDM
PPV9110        VG1 120V        VG2 -120V        45        5        DFN-8        LCP02-150B1        TISP9110
P2G8SS-301M-E10   P3G5SS-900M-E01   P2G8SA-750M-E05   P2G8SS-151M-E10 P3G8SA-900M-E10
Ethernet protection
Part No.        VRWM(V)        IR(uA)        VBR(V)        C(pF)        PPK(W)        Package        ONSEMI        Protek        Semtech        ST
PESDALC236T5VU        5        1        6.2~7.1        10        200        SOT-23-6L        HDMIULC6-4SC6        USBLC6-4
SDI ; VDSL
T1/E1 ; Scart ; Audio/Video ;L-VDS
IEEE1394 ; USB2.0-dual ; LCD ; SIM ; Diplay port(power)
PESDALC363T5VU        5        1        6.2~7.1        3        100        SOT-363                PLR0504F        RCLAMP0504F
USB2.0-single
PTVSLC523T5VU        5        1        5.4~8.5        2        125        SOT-523        NZL6V8AXV3T1G        ESDALC6V1P3
Audio/Video;RS232
PESDLC353T5VU        5        1        6.2~7.1        10        100        SOT-353        NSQA6V8AW5T2G        ESDALC6V1W5
HDMI ; Display port(data line);USB3.0
PESDUC363T5VU        5        1        6.2~7.1        0.5        100        SOT-363
PESDUC9D5VU        5        1        5.4~8.5        0.4        100        SOD-923                ESDAXLC6-1MY2
Keyboard
Part No.        VRWM(V)        IR(uA)        VBR(V)        C(pF)        PPK(W)        Package        Onsemi        ST        PROTEK        Semtech
PESDNC9D5VB        5        1        5.8~7.8        15        100        SOD-923        ESD9B5.0ST5G        ESDALC6V1-1BM2        P5V0S1ULC
Speaker
RS485
RS-MMC Card
Part No.        VRWM(V)        IR(uA)        VBR(V)        C(pF)        Package        Protek        Semtech        CMD
SD-Card
Epon protection(China Telecom 4KV standard----Don`t need GDT)
Part No.        VDRM(V)        VGKRM(V)        ITSP(10/1000)(A)        IG(uA)        Package        ST        BOURNS
SLIC protection
General Part No. for Mobile
TVS(The most common)
PESDNC9D5VU        5        1        6.2~7.1        30        100        SOD-923        ESD9X5.0ST5G        ESDALC6V1-1M2        P5V0S1UL/PLW0501D
Digital Transistor
Part No.        VCBO(V)        VCEO(V)        VEBO(V)        ICBO(uA)        IEBO(uA)        R1(KΩ)        VCE(V)        fT(MHz)
Zener
Part No.        VZ(V)        ZZT(Ω)        ZZK(Ω)        IR(uA)        C(pF)        PD(mW)        PHILIPS
PZ3D5V1U        5.1        60        500        1        220        200        1PS79SB30
PZ3D5V6U        5.6        40        200        1        200        200
PZ3D5V1UH        5.1        60        500        1        220        500
PSBD520S-30        0.6        30        200        1        1
PSBD521S-30        0.5        30        200        1        30
PSBD521CS-30        0.35        30        200        1        10
Part No.        Package        韦尔        Onsemi        ST        ROHM        TOSHIBA        COMCHIP        SINO-IC
PESDNC9D5VU        SOD-923        ESD9X5V / ESD9X5VD        ESD9X5.0ST5G        ESDALC6V1-1M2
PESDNC9D5VB        SOD-923        ESD9B5V / ESD9B5VD        ESD9B5.0ST5G        ESDALC6V1-1BM2
PESDNC5D5VU        SOD-523        ESD5Z5VA-2/TR        ESD5Z5.0T1G
PESDNC5D5VB        SOD-523        ESD5B5V-2/TR        ESD5B5.0T1G
PESDNC5D7VU        SOD-523        ESD5Z7V-2/TR
PESDNC553T5VU        SOT-553        ESDA6V8AV5-5/TR        NZQA6V8XV5T1G        ESDA6V1P6
PESDUC9D5VU        SOD-923        ESD9X5VU / ESD9X5VL
PDTC143ZM        SDTC143ZM
PDTC143TM        SDTC143TM
PZ3D4V2H        CZRU52C5V1 /  CDZ55C5V1SM        MM3Z5V1-5
PZ5D4V2H        MM5Z5V1-5
PT236T30E2 STT818B
PNM723T703E0-2        SSM3K35MFV
PESDNC2FD12VBH
PES1JF-12
PESDUC3FD5VU
PPM723T201E0
PESDHC2FD5VBH
PPT3FD503E0-2
PPT3FD503E0-2
PS3AF
PS3AF
PS3BF
PS3BF
PS3DF
PS3DF
PS3GF
PS3GF
PS3JF
PS3JF
PS3KF
PS3KF
PS3MF
PS3MF
PBAT54AT
PBAT54AT
PESDALC10N3V3U
PESDALC10N3V3U
PES2BBF
PES2CBF
PES2CBF
PES2DBF
PES2DBF
PES2EBF
PES2EBF
PES2GBF
PES2GBF
PES2JBF
PES2JBF
PRS1BF
PRS1BF
PRS1DF
PRS1DF
PRS3AF
PRS3AF
PRS3BF
PRS3BF
PRS3DF
PRS3DF
PRS3GF
PRS3GF
PRS3JF
PRS3JF
PRS3KF
PRS3KF
PRS3MF
PRS3MF
PRS1GF
PRS1GF
PRS1JF
PRS1JF
PRS1KF
PRS1KF
PRS1MF
PRS1MF
PRS2BBF
PRS2BBF
PRS2BBF
PRS2DBF
PRS2DBF
PRS2GBF
PRS2GBF
PRS2JBF
PRS2JBF
PRS2KBF
PRS2KBF
PRS2MBF
PRS2MBF
PUS2BBF
PUS2BBF
PUS2DBF
PUS2DBF
PUS2GBF
PUS2GBF
PUS2JBF
PUS2JBF
PUS2KBF
PUS2KBF
PUS2MBF
PUS2MBF
PES2BF
PES2BF
PES2CF
PES2CF
PES2DF
PES2DF
PES2EF
PES2EF
PES2GF
PES2GF
PES2JF
PES2JF
PES3BF
PES3BF
PES3CF
PES3CF
PES3DF
PES3DF
PES3EF
PES3EF
PES3GF
PES3GF
PES3JF
PES3JF
PBAT54CT
PBAT54CT
PBAT54ST
PBAT54ST
PBAT54T
PBAT54T
PESDNC2XD4V5B
2SC3356
2SC3356
PS2BBF
PESDNC2XD5V5B
PESDLC5D5VB
PESDMC2FD5VB
PESDMC2FD5VB
PESDMC2FD10VB
PESDMC2FD10VB
PESDMC3D12VB
PESDMC3D12VB
PTVSHC3N7VUL1
PTVSHC3N7VUL1
PTVSHC3N10VU
PTVSHC3N10VU
PESDUC2FD5VB2
PTVSHC3D4V5B2
PTVSHC3D12VUH
PZ2FD5V6H
PZ2FD5V6H
PNMIP100V10
PZ2FD14VH
PTVSHC1DF4V8U
PTVSHC1DF4V8U
PSBD2FD20V1H
PSBD2FD40V02
PTVSHC1DF15VU
PTVSHC1DF18VB
PZ5D8V2H
PTVSHC1DF18VB
PSC5415
PSC5415
PPM6N20V5
PPM6N20V5
PPM6N30V4
PPM6N30V4
PPM6N30V7
PPM6N30V7
PPM6N30V9
PPM6N30V9
PSBDBF40V2
PSBDBF40V2
PSBDBF40V3
PSBDBF40V3
PSBDBF40V5
PSBDBF40V5
PSBDBF60V2
PSBDBF60V2
PSBDBF60V3
PSBDBF60V3
PSBDBF60V5
PSBDBF60V5
PSBDBF80V2
PSBDBF80V2
PPMIP100V10
PSBDBF80V3
PSBDBF80V3
PSBDBF80V5
PSBDBF80V5
PSBDBF100V2
PSBDBF100V2
PSBDBF100V3
PSBDBF100V3
PSBDBF100V5
PSBDBF100V5
PSBDBF120V2
PSBDBF120V2
PSBDBF120V3
PSBDBF120V3
PSBDBF120V5
PSBDBF120V5
PSBDBF150V2
PSBDBF150V2
PSBDBF150V3
PSBDBF150V3
PSBDBF150V5
PSBDBF150V5
PSBDBF200V2
PSBDBF200V2
PSBDBF200V3
PSBDBF200V3
PSBDBF200V5
PSBDBF200V5
PESDUC2FD5VB
PESDMC9D5VU
PTVSHC3N12VU
PTVSHC1SF24VBH
PESDNC2FD24VB
PESDUC2XD5VB
PSBD9D30V01H
PNM723T201E0
一级代理PRISEMI芯导
一级代理PIRSEMI一级代理PIRSEMI代理
一级代理芯导一级代理芯导代理
上海芯导电子科技有限公司总代理商
芯导授权经销商PRISEMI授权经销商
芯导总代理商PRISEMI总代理商
PRIMSEI A级代理芯导A级代理
